can i see some pics of an 87+ 2.8 or 3.1 motor that has serp belt and no AC
Old Mar 20, 2005 | 10:06 AM
V6camaroman's Avatar
hey guys can someone show me a couple good pics of any 87 on up 2.8 or 3.1 that has the serp set up and doesnt run AC or smog. i want to see how the belt runs
Old Mar 20, 2005 | 02:07 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Scroll down to the "riddle me this" post, 'project: 85 2.8 bird' has a good photo of a 3.4 without a/c and smog..
https://www.thirdgen.org/techbb2/sho...hreadid=282657
Old Mar 20, 2005 | 02:55 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
does the waterpump pulley rotate the same direction, counter clockwise, like the 3.4 does??? IIRC, the v-belt equiped 85 2.8 roataed clockwise, but not sure how the serp only 2.8s went. Yeah, gotta stir up som estuff on a Sunday.
Old Mar 20, 2005 | 03:22 PM
bru333's Avatar
Car: 1987 Camaro SC
Yup! CCW water pump. But the tensioner is up by the alternator, and the power steering pump is lower. If you delete a/c you need an a/c delete pulley or a really short belt that keeps the tensioner up high enough for the belt to clear the water pump on the it's way to the PS pump, or fab a bracket to raise the PS pump.
Attached Thumbnails can i see some pics of an 87+ 2.8 or 3.1 motor that has serp belt and no AC-enginetopserp2.jpg
Old Mar 20, 2005 | 07:56 PM
bru thats what i did. i got a 80.5" belt and she just snuck on. there is maybe less that a 1/4" between the power steering and the water pump. i do see that the ps pump bracket has two different holes in it so if i put it to the other bolt hole it will tilt it a little and raise it a bit more. not so sure if its going on the road right now. got damn its just started snowing about an hour ago here.
Old Apr 3, 2005 | 03:40 PM
bru333's Avatar
Car: 1987 Camaro SC
I just took a good look at the decal for the drive belt routing. This is exactly what it shows for no A/C. Now we know what size belt to use.
Attached Thumbnails can i see some pics of an 87+ 2.8 or 3.1 motor that has serp belt and no AC-drivebelt.jpg
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Cleotiz
Jan 6, 2018 08:56 PM
Mickeyruder
Sep 2, 2015 02:45 PM
E Rod
Aug 28, 2015 05:17 AM
