Superram owners......
Car: 1992 Z28
All Superram owners, please check this out.......
I'm sure some of you aware of this, but.........
A while ago Accel shipped a batch of Superram gaskets that have an incorrect base-to-runner gasket included in the set. The gasket in question is the drivers side front gasket with the EGR port opening in it. The gasket should have a hole that is 1 3/4" long. Instead, some of the gaskets shipped had a hole that is 1 7/8" long. This will cause a vacuum leak on the majority of installations. Apparently, the faulty gasket is actually the correct gasket for the Accel LTR setup gasket set.
Anyway, check your gaskets if the car runs poorly or if you have a set sitting on the shelf.
Here's the offending gasket.........
And here you can see the compression area on the gasket. The area that is compressed is where the runner sits (duh).......
Axle/Gears: 4.11 posi Ford 9"
Have you talked to them about this yet?
Car: 1992 Z28
http://forums.corvetteforum.com/show...perram+gaskets
Car: 1987 Iroc-z
Engine: 355/Edelbrkhds/lpe219cam/MiniRam/
Transmission: 700R4/3.27 9bolt
This happened to me when I ordered gaskets last summer. I cought the issue when I mocked it up on the bench. Huge vacuum leak. I got some gasket paper and made my own.
Car: 1992 Z28
I just got my new gasket set from Summit.
It has the wrong ****ing gasket in it too
Somebody at Accel is going to get it big time on Monday. I'm going to shoot the messenger and then some. They've known about this for over a year.
Car: 1987 Iroc-z
Dude, make your own... Trace it, cut it out with an exacto blade and cean up the port holes with a sanding wheel on your dremel tool. Accel sucks.
Car: 1992 Z28
Here's the thing.....I shouldn't have to. I shouldn't have to make a gasket set either. They've know about this problem since 2003, maybe earlier. The fact that the bad sets are still sitting in inventory is what pisses me off. Hell, they even managed to change the packaging in between my old flawed set and the new flawed set.
At least the new set came with a sticker
Accel sucks? No, Mr. Gasket sucks, therefore Accel sucks by association. They'll probably **** up Jacobs and anybody else they buy out too.
Car: 1992 Z28
Originally posted by 91wtROH17's
Acceld, I have a new complete set at home. I will check it tonight for this problem. If you are in a rush I'll sell them.
Oh, and,..............don't sell your car.
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
Originally posted by Acceld Z
Nah, I should be good for now. Thanks for the offer though.
Well, my 383SR hasn't been running that great, so I checked for this vac leak gasket problem - and found I have the same gasket set as pictured here in this thread. D@MN!!!
I made up a temporary set from gasket paper at AZ, and am using RTV on both sides of the gasket during installation. Got the passneger's side on now, hoping to do the driver's side tonight.
I also found three of the four intake manifold bolts were no where near the correct 25 ft-lbs of torque. Actually not sure any of them were that tight. But they are now!
I need a good permanent set of these gaskets if anyone still has any laying around for a decent/fair price..... Pretty Please?
Car: 1992 Z28
Lingenfelter is where I got this gasket set last summer.....
Car: 1992 Z28
Try Cruzin or Thunder. I bet they'd be willing to check the box before shipping. I wouldn't trust buying them from Summit or Jegs.
Car: 86 Camaro Z28
Engine: 5.3 LM7
Transmission: TH400
I just checked an extra set I have on the shelf from LPE and it has the same problem, I am sure my currently installed set has it too. My car runs alright but every now and then it does act funny. I will eventually take mine off and check and make my own gasket for it.
Car: 1992 Z28
Originally posted by irocz
It took them that long to figure it out???
Mine was put together in '00 so I guess I'm alright.
Car: 1992 Z28
I bought another set and it has the bad one. This is the third set in a row that has come in a different box. Maybe they have switched manufacturers or something.
Car: 1992 Z28
I just modify the bad gasket with a few cuts. I found a local source for the gasket set that can get them cheaply and quickly.
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Just a FYI, I ordered a Superram gasket set, ACC-74196G from Summit last week and received the correct gasket.
FWIW - the set I got from Summit today are the CORRECT ones as well. Hurray!!!!!
Tkae the pic at the top of this thread, and imagine measuring the hole so it comes out at 1 3/4 inches instead of the 1 7/8th shown in the pic. Don't have a camera here at work, but all the info is at the top.
Car: 1992 Z28
I mainly wanted to see if that whole corner is oriented differently.
Sorry, answered too quickly!!!
I'll get some pix tonight. WIll that help?
My apologies,,,,,
My apologies,,,,,
Here's what they look like now...
There are some changes though - the runner to plenum gaskets are now "siamesed" for the runner ports. Each gasket has two large holes so that 1&3 share a gasket hole, as do 5 & 7, etc.
ONE PROBLEM HAS BEEN DISCOVERED THOUGH!!!
The rear passenger side gasket with the curled over EGR type slot has the same very small compression area as Acceld Z shows on the driver's side front gasket. The problem is the hole is so long, only 1/32nd or maybe 1/16th of an inch of gasket gets used before you hit the outside circumference of the runners.
I think I solved this problem though, I built up the outside if the runners about 1/4 of an inch with JB Weld stick, let it set up, and then filed it down so I have a nice straight and smooth gasket mating surface.
Who ever talked to Accel about the other problem before needs to do the same thing with this new gasket problem. I compared it to a set of gaskets I was keepng for emergency spares and it looks like they've always been this way...
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
oh man... this sucks
i have a accel base that i'm already 80% done porting and i want to go with the superram uppers..... I am NOT going TPI anymore... but i might have to if this gasket thing isnt sorted out.
what should i do? why does accel suck at quality control... all the stories i hear on the superram makes me really want to ditch that idea
It's not the SR that's the problem, it appears to be Accel trying to cut corners on gaskets and use a lot of the same ones for the SR and their LTR's.
Check out the fit of the gasket on your SR runners. Worse case is you build up the Runners on this one corner by welding or J-B welding.
Believe me, especially if you have to be emissions legal, the performance is worth the effort IMO.
Car: 89 Iroc-z
Transmission: TH400
i am seriously considering going HSR and gettin my collectible plate so i can scrap emissions. its cheaper anyway
Car: 71 Nova
Axle/Gears: 8.2 posi 3.08
You guys are lucky you even got this gasket. I just opened up my gasket set that came with my Superram and it didnt even contain this gasket. It came with only 3 runner gaskets so it looks like I got stiffed. I guess Ill have to make my own because I dont want to end up spending more money ordering a crap set like the ones you got.
Pac J
May 17, 2020 10:44 AM
doc
Apr 22, 2003 11:41 PM
'87FAKE-IROC-Z
Aftermarket Product Review
Oct 9, 2001 03:31 PM
