Need SD TPI VSS info
Old Apr 19, 2005 | 04:52 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
I need a VSS as part of my swap to SD (730 ECM) with a T-5.
The trans in there had a cable VSS...
Both the dealer and the parts stores say there are two options:
First: RPO Code D81 or D89 (original GM part # of 10456022 or 10456089)
Second: RPO Code D8M or D8G (GM Parts # of 10456020 or 10456087)
The cost of one is $42 while the other is $90...Is one for a TBI and the other for TPI?
Tell me I can use the cheaper option...
TIA,
Old Apr 19, 2005 | 06:03 PM
Engine: LS3
Transmission: 6L80E
Also...after doing some more checking around...there are two different VSS's for an auto and one for the manual...but no one can tell me which one I need!
Any input would be welcome...
Thanks,
Old Apr 20, 2005 | 09:05 PM
Engine: LS3
Transmission: 6L80E
Still no answer...
Also, I found a VSS that a friend had that I believe is from a 91 Chevy truck with the 350/700F4 combo...it has the bolt hole in the wrong spot and a larger diameter body...Will that work?
I am going tomorrow to pick up both of the VSS options that I ordered...I just wish I knew which one was correct...
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
fonzie85
Aug 13, 2015 11:50 AM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
mizz0313
Aug 12, 2015 06:45 AM
