LED rear spoiler brake light install
Old May 2, 2005 | 08:26 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
first off... if you're wondering why it all looks melted and burnt, go here:
https://www.thirdgen.org/techbb2/sho...hreadid=295064
ok, this is the "kit"... its 6 LEDs and a resistor in a plastic baggie... doesnt look like much, but it costs less then ONE bulb, and it works... great.
i had my doubts as ive tried this before... all i got were little LED dots... but these LEDS work. the entire housing lights up very bright, and it is more then bright enough for daytime brake light use......
btw, do NOT look directly into the LEDs when they are not behind the lense.... they are that bright.
ok, heres my install pics...
first, the LED bulbs.
REALLY easy. you just put them into the sockets. if they're upside down, they wont light... but it wont hurt them, just flip em back around.
real easy.. they do come with instructions btw...
Old May 2, 2005 | 08:32 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
heres where i changed from the directions.
to run the LEDs, you NEED a resistor inline before the LEDs... otherwise, they'll blow.
ok, so heres what i did:
the instructions say to cut the wire on the car, and put the resistor inline there...
i didnt want to cut up my car... the housing however.... well, if i mess that up, no loss... i need a new one anyway (see link in first post)
so i cut the power strip where it comes in from the connector.. the cut is where the arrow is pointing.
the wire is soldered to the input pin.. power goes thru the resistor, and back to the strip..
all the power is still going thru the resistor.. i know it doesnt LOOK like it in that pic, but thats because the wire covers it.
i paid only a couple bucks for this kit, and it works really well.... shipped right away too.. im pretty happy about it.. no more burnt bulbs, no more overheating lights. just cool, reliable LEDs..
Old May 2, 2005 | 02:32 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
hey man...long time. I was just at radioshack the other day checking out their leds for my vert third brake light. Glad this came up.
So its custom-led.com where u got them?
Old May 2, 2005 | 02:38 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
yup... $2 plus shipping... great deal.
http://www.custom-leds.com
Old May 3, 2005 | 07:05 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Thanks MrDude!!!
My third brake light has never worked lol.
Old May 5, 2005 | 06:52 PM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
I need a bulb!! for my 3rd brake light does anyone know where I can get em?
Old May 6, 2005 | 07:41 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
if you have the spoiler type light, get the one linked to above.
if you have the hatch mount type, goto your local autoparts store. (or the link above for a custom LED one)
the spoiler mounted 3rd brake lights have wierd, hard to find bulbs. the hatch ones use common bulbs.
Old May 6, 2005 | 09:47 AM
Benm109's Avatar
Car: 1991 Chevy Camaro
Yep, MrDude_1 is right. Since your car is a 91, you can go to any auto parts store and get a 3156 bulb.
But, why keep it stock?
Old May 7, 2005 | 01:04 PM
Fast-Tony's Avatar
Car: 85' IROC & 87' IROC conv
Engine: Both have Vortec TPI 350
Transmission: T-50
Axle/Gears: 3:42 & 3:73
Great info I have been wanting to change over for quite a while, I just ordered 3 kits one for both of my Camaros and one extra kit for my growing pile of spare stuff only $10.50 cheaper than replacing the Halogen bulbs.
Tony
Old May 13, 2005 | 12:49 AM
FerrMaro's Avatar
How far did your L.E.D.'s go into the socket? Mine don't go all the way in. And do you happen to know what kind of resistor this kit uses?...I kinda lost mine...
Old May 13, 2005 | 07:58 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
just enough so they seat.. they wont sit flush with the socket.
looking at my fuzzy out of focus pic in this thread, id say its Brown-black-brown.. and big. lol.
Old May 13, 2005 | 08:25 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Its 100 ohm, probably 1 or 2 watts. I don't know what the LEDs are rated at so I can't really say, but 1W should be fine in most cases. Running a single resistor inline is a poor design, but I suppose cost effectiveness and simplicity goes a long way.
Old May 13, 2005 | 08:50 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
why would you call it a poor design? much better design then a multi resistor setup.... such as one for each light.
Old May 13, 2005 | 09:08 AM
Car: 86 T/A
Engine: HSR 355
How's it better? Putting the LEDs in line has a very good chance that each LED will vary in brightness due to inconsistancies in manufacturing. And if one burns out the whole thing goes out.
Old May 13, 2005 | 11:06 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
i think you're confused about the circuit.
all LEDs are in parallel.
Old Jul 18, 2007 | 12:51 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Re: LED rear spoiler brake light install
for the record... 2+ years later.. still works great!
LilHot
South Central
Apr 13, 2026 11:46 PM
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
Omega
Aug 10, 2015 12:46 PM
