VSS Part No.
Old May 15, 2005 | 11:39 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
VSS Part No.
Does anyone have the part no., or application from a x8 inliine VSS?. There's supposed to be a jeep/ diamler chrysler that use one.
How about a part no. for the x4 inline one?.
TIA
Old May 15, 2005 | 12:17 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Here ya go... This is a 8X. 91 Wrangler.
The sensor pictured was gathered from Pirate4x4.com in a post made by “gripguru”
He provided the following part numbers:
5/8"x7/8" speedo apapter #9400012
vehicle speed sensor #56027015
Old May 15, 2005 | 09:44 PM
LKJR's Avatar
I had a question similar to this one. I'm seting up to run a prominator with the 7730 ecm on mine (tpi swap on k5 using th350 tranny) is this the vss to get?
8 pulse?
Old May 27, 2005 | 09:00 PM
JP86SS's Avatar
You need 4 pulses per rev that will equal out to 4000 pulses per mile.
Look into a site called "jags that run" (without spaces)
Google it and there should be something there that will work.
Most of them are less than $100 but you need to change the gears to match your setup. They have a whole listing of what gears for what trans, rear and tire size.
they are very helpful too if you call.
Old May 27, 2005 | 10:30 PM
shaggy56's Avatar
Car: 71 Nova
Axle/Gears: 8.2 posi 3.08
For second question
They are getting expensive. I paid $69 for mine.http://store.summitracing.com/defaul...get=emain.asp&
search for speed sensor
As for the 8 pulse version. Well I never knew it but now i know i have one sitting in my parking space.
Old May 27, 2005 | 11:36 PM
JP86SS's Avatar
LINK
Here's the link to the pdf info file on the site.
Very detailed and shows the different styles so you can find out at least what you should be looking for.
http://www.jagsthatrun.com/V8-chapte...ed-Sensors.pdf
I am using the "4PAC" cause I have a cable driven speedo and still needed the pulse output.
Then you can go to the price list page and see how much they sell them for. If you can't get back to the page then heres that link too.
https://shell7.tdl.com/~jags/SpeedSensors_Order.html
Not trying to advertise for them but they were super helpful and I've had no problems with the unit I bought.
LT1Formula
20
Nov 14, 2015 12:02 AM
The_Phoenix
Sep 3, 2015 10:56 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
