South West Region South West regional discussion board.
fuel pump
Old May 23, 2005 | 12:50 PM
SchwarzCamaroRS's Avatar
fuel pump
anyone around here ever changed one? mine went out, i got a walboro 255lph on the way... id really appreciate it if anyone knows how and would share the wealth of knowlege... thanks in advance!!
Old May 23, 2005 | 02:29 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: fuel pump
All I can tell you is that I didn't have to drop my rearend as most claim you do. I did cut the exhaust tho and dropped the tank that way. You will have to "manuever" the tank to get it out because of the neck. Other than that it's pretty easy once it's down. Do it on an empty tank if you can.
Old May 23, 2005 | 04:02 PM
hmmm.. well, i had planned on taking off the exhaust soon anyways... and crap... ive got 1/4 tank left... at least its not full!!! where/how do i drain it?
Old May 23, 2005 | 04:10 PM
Hmmm. I can't remember how I drained it...maybe I shouldn't of responded...LOL... Have you tried a search as to how to do it? I know there are several threads that would explain how to drain it. I'm just gonna shut up now.
Old May 23, 2005 | 04:28 PM
90_WS6_Formula's Avatar
Car: 91 Z28
drop it with the gas that's in there... it's not too hard. I ***WATCHED*** Joe do it in like 15 minutes but that was with the rear end dropped. You don't have to drop the rear to do it but it's much easier. The main thing is to get the rear of the car as high as possible.
Old May 23, 2005 | 11:33 PM
lol, not lookin forward to doing that... i just swapped rearends...
Old May 24, 2005 | 12:04 AM
Car: 91 Z28
did your rearend have a crack in it???
Old May 24, 2005 | 12:35 AM
AZ406TPI's Avatar
Car: 1986 IROC-Z/28
Engine: 406 CID SBC
Transmission: 700R4 A4
ur best thing 2 do is lift up the rear carpet, cut a hole over where the fuel pump goes, and make a"flap" so in the future, when u WILL have 2 do it again, its a 30 mins job.. not a drop the rear end or cut the exhaust job.
Old May 24, 2005 | 12:47 AM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
That being the "best thing" is all opinion. And before the post goes anymore in the wrong direction, read what happened the last time this came up.
https://www.thirdgen.org/techbb2/sho...hreadid=264787
It's not hard, just time consuming.
Old May 24, 2005 | 12:57 AM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Ahh yes, I remember reading that thread, quite a bit of mindless bantering and a little bit of technical help but yeah, I say do it the right way, going in from underneath, cuz "saving" yourself the time by cutting the top will end up taking you twice as much time to do it "right" (meaning get a proper cover for the hole and make it professional) so yeah, in the long run it won't do you any good really.
Old May 24, 2005 | 01:34 AM
I agree....I had my car jacked so high it was scary.
Old May 24, 2005 | 01:44 AM
AZ406TPI's Avatar
Car: 1986 IROC-Z/28
Engine: 406 CID SBC
i guess. all i know is everyone i know who has done it via going thru the top, when a fuel pump goes out, its a snap 2 change them out. u dont have 2 get under the car, cut anything up, drop anything, just lift up, take out, and drop in. but hey...
Old May 24, 2005 | 02:25 PM
mines a vert, if i wash it i comprimise structural integrity... i dont think ill be cutting any holes in it... The two things ive learned while working on this thing are "anything worth doing, is worth doing right... the 1st time!" and "shortcuts have side effects that usually make the trip longer..." thx for that other post
Old May 25, 2005 | 02:29 AM
UmmaGumma's Avatar
Car: 2007 Infiniti G35 SEDAN
Engine: 306HP 3.5L V6
Transmission: Auto Pilot Baby!!!!
Axle/Gears: Don't care!
you could say that....
Old May 25, 2005 | 06:35 AM
AZ406TPI's Avatar
Car: 1986 IROC-Z/28
Engine: 406 CID SBC
jesus.. and i though i never washed my car
Old May 25, 2005 | 10:08 AM
lol, not then i didnt, she was DIRTY... lol, not exactly clean now either, but its been so hot when ive been home the water would dry on the car as soon as i sprayed it...
Old May 25, 2005 | 12:08 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
So you did it already then?
Old May 25, 2005 | 12:25 PM
I believe I had mine higher than that...lol
Old May 25, 2005 | 03:21 PM
oh no, that was swapping rearends... but im not even going to mess around with rigging anything up, im gunna drop the whole exhaust (ive got headers to put on anyways...) drop the rearend ( i need to fix my springs) so, im doing it the long and SAFE and tediously easy way... no cuttin holes, no choppin off crap.. just a clean teardown and rebuild pretty much...
Old May 25, 2005 | 06:16 PM
Car: 91 Z28
you do ***HAVE*** to cut the exhaust to get the tank down....
Old May 25, 2005 | 06:33 PM
84L69TA's Avatar
Car: 4 Mopars total
Unless you slide the muffler off the pipe and swing the pipe out of the way. Need a torch though to heat the muffler uo get it off.
Old May 25, 2005 | 06:34 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
No you do not. All you have to do is disconnect it. My old setup was welded up solid. All I did was disconnect it from the manifolds and then removed the panhard bar and shocks. After letting the rear end hang, the exhaust will drop. From there you can use the muffler as a head rest and have plenty of room to remove the tank. You just need to get the rear of the car off the ground far enough.
Old May 26, 2005 | 12:02 AM
or unless i drop off the rearend 1st and then the whole exhaust... i have to re-do the pinion seal on the rear anyways. im takin the whole shabang off. Also im more than likely gunna pull the motor apart and do the cam/head swap as well... its gunna be a week or two of nonstop work on the camaro, then it will run worse than before until i get it tuned!!! hahaha, the joys of thirdgens..
Old May 26, 2005 | 12:27 AM
Synapsis's Avatar
Car: Sexy
Engine: Stock
No no... all you have to do is trade mrt89rs a set of used slicks and a 40 of Mickey's and....
Old May 26, 2005 | 12:19 PM
lol, well, i guess if that was one of my options... lol, my school has lifts, but they wont let me do it cuz it will take too long...
Old May 26, 2005 | 02:24 PM
90RS305's Avatar
Something about that picture just looks sick and disturbing....
Old May 26, 2005 | 02:27 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
It's like looking at Goatse, but for cars.
The rear was only held up by the driveshaft and a jack, so it shifted a little to the left. That's why it looks odd.
Old May 26, 2005 | 08:43 PM
3GTAs1TA1Z28's Avatar
Car: 85 87 87 91 92
Engine: 305 TPI 350 TPI 350 Carb
Transmission: B/W T-5 and 700R4
I have personally changed Fuel Pumps "The proper way" from under neath the car on my 92' its not that hard .....Actually I found it easier that installing my Edlebrock Headers....If you need any inof or maybe a little help let me know
Old May 27, 2005 | 01:57 AM
He needs help. He's gotta finish in time to drive it to the BBQ.
Old May 27, 2005 | 01:59 AM
Car: 91 Z28
installing the Edelbrock headers sucks... but atleast everything fit
Old May 27, 2005 | 08:42 PM
Z28IROC's Avatar
Car: 1988 IROC
Engine: 350CI
Axle/Gears: 9 bolt 3:70
Thats how I did mine.
Old May 28, 2005 | 02:27 AM
damn right i do... i gotta represent the Vert crowd!!! both the verts i know of are both Birds... that and im 350'd both of them are not... if everything goes as planned, ill have headers/heads and a cam by then too goin for a total build... then jon can tune me when he comes ouf if i can convince him to
Old May 28, 2005 | 10:38 AM
UmmaGumma's Avatar
You 'd never know it though with your track record of getting smoked by all the 305's on this board...
Old May 28, 2005 | 11:47 AM
OMG...that's gotta hurt.............
Old May 28, 2005 | 12:37 PM
90RS305's Avatar
Old May 28, 2005 | 01:51 PM
WHOA WHOA WHOA!!! that was WAYYY below the belt.. lol.... only two have beat me, and one of which has been corrected... that and one of them was a decently modified TPI with a T5 and a performance rear... its all in the tune though... whats worse is if i get all my mods on, my car will probably barely run cuz the tune will be so off... haha. I dont care if i gotta push it, ill be there.
Old May 28, 2005 | 07:31 PM
UmmaGumma's Avatar
excuses...excuses...
Haha... sorry dude! I just had to give ya a little jab for that one. Even though your STILL not representing the 350 very well.
Were either of those before the posi?
Old May 29, 2005 | 01:13 AM
yes... bruce was a loss before the posi, a win after... sebastian just kicked my a$$... lol
Old May 29, 2005 | 02:35 PM
mrt89rs's Avatar
From: Tucson AZ where the 3k ft of elevation kills your time
Car: 89 camaro rs
Engine: 383 .06 over
Transmission: th350
Axle/Gears: 3.73 10 bolt
hahaha lol, DId you ever get those traction bars fixed after that?
Old May 29, 2005 | 11:09 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Nah, not yet. I still have to order the heim joints.
Old Jun 1, 2005 | 02:53 PM
anyone have monday/tuesday off? i could use the help and i think im doing it then... it needs to get done if im going to make it to the party on the 11th
Old Jun 1, 2005 | 07:58 PM
Car: 85 87 87 91 92
I am off in the evening....LOL
Old Jun 2, 2005 | 12:41 AM
monday/tuesday? cuz ill be workin on it all day both days
Old Jun 2, 2005 | 01:04 AM
Car: 85 87 87 91 92
Just call me to remind me and I will come help ya
Old Jun 2, 2005 | 01:44 AM
Car: 85 87 87 91 92
What do you just pop in for like 2 secs. throw up a couple posts and bail or what?
And how come you never call me back when I leave you a message?
Geez am I starting to sound like my wife or what? LOL
Old Jun 3, 2005 | 01:58 AM
lol, pretty much just post and leave... lol, my phone = retarded and i dont get messages until like weeks later sometimes... i will deffinately call you though, i need all the help i can get... but thats even IF i get to it this monday/tues... got lotsa stuff to do... ill keep you updated
Old Jun 10, 2005 | 04:54 AM
ok, fuel pump not in yet... TGO meet, T-minus 36 hours... I NEED HELP... callin anyone who has any free time at all!!! im probably calling in sick for work tomorrow so i can get this done... for the love of all that is sacred, i need my car!!!!
yes, this is a desperate cry for help...
Old Jun 10, 2005 | 09:00 PM
Car: 85 87 87 91 92
I thought I told you to call me I would help..
Old Jun 10, 2005 | 09:48 PM
i know, work called me today, tomorrow morning, im getting up bright and early... im going to try to get it done... if not, ill just ride with someone else. If youd be willing to help out tomorrow, ill call you, but seeing as how its saturday and all, i dunno if you wanted to use your day off. Anyway, thanks, i will call, wish me luck
Old Jun 11, 2005 | 10:49 AM
well, crap, my exhaust would need to be dropped from the manifolds back cuz its all one solid piece, but the air tube that goes into the CAT is welded on too... i need a couple more jackstands to get any further than I am... looks like im ridin with someone...
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
