Help!!! Not firing!!
Old Jun 13, 2005 | 09:38 PM
flexyj's Avatar
Car: 1990 YJ
Engine: 406 TPI
Got the new engine running, everything was well until while idling, it died. It seemed as if it just lost spark and now it will not even attemp to fire. I have fuel pressure and I have spark, what happened? The only thing that I haven't had a chance to check was if the injectors are firing, I am getting a set of noid lights tommorow to check that out, but I did replace the ingintion module with no changes. Someone please help me sleep tonight!!!! If it helps at all, it is a very fresh 406 (less than 45 minutes of run time), speed density system, all new sensors, all new parts in distributor, new computer, and chip was burnt to engine specs by TPIS. Please help!!!!!
Old Jun 15, 2005 | 06:27 AM
flexyj's Avatar
Car: 1990 YJ
Engine: 406 TPI
I got it running, for anyone who happens to search and find this later it turned out to be the pickup in the distributor. I replaced the module with no change and eventually changed the pickup and it fired right up. Hope this helps in the future!
Old Jun 16, 2005 | 10:01 AM
Vader's Avatar
Thanks for the update. It's always nice to see what the solution is.
Should be interesting to see what the car will do with those few extra cubes.
KCG
Jun 24, 2020 04:33 AM
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
indygene
Sep 26, 2015 11:21 AM
