high idle and hiss after putting car in drive? and intermittent miss
Old Jun 27, 2005 | 07:40 AM
XThree's Avatar
Car: 91 RS
Transmission: TH 700 R4
I have 2 problems actually one is this strange problem. when I start my car the idle goes up, then down when its starts to warm up, when its warm idle is about 750 rpm. If I put the car in drive, the idle starts to go up over 2000 rpm, and it starts to hiss, I have to keep my foot on the brake hard to keep it from driving off.
the other is an intermittent miss at idle.
91 RS 5.0 lo3
no cat
what I have done,
checked trouble codes, code 54, and another one(forgot, im at work now) about low coolant temperature.
I replaced the fuel pump relay.
I replaced the Coolant Temperature Sensor.
Full Tune-up (plugs, wires, distributor cap, rotor button, pcv, fuel filter, checked timing)
cleared ECM of codes, and started it back up... still same two problem and now no codes.
I also replaced the TPS and re-adjusted that but no changed.
P.S
I'm using WINALDL I use the 'dash board' to set my TPS via the "TPS" box in the WINALDL dash window but I can't ever seem to get it to .5 barely moving it like a milimeter and it will change from like .7 to -.3, or from .7 to 1.2
.7 is closest I can get it.
I was thinking MAP sensor but would that only act up when I put the car in drive? I'm not seeing teh connection why this only happends when I put the car in drive. As far as the miss I was thinking ignition module. but I hate to keep throughing money at it without knowing exactly what the problem is, is there a way to find out with data logging?
any help would be apreciated.
I haven't ruled out doing a compression check, I just did one a couple thousand miles ago and they were all still above 100 psi, since then I have only driven it to work in traffic. It never runs hot, I have it setup to pretty much run at about 160 all the time.
Old Oct 26, 2005 | 11:51 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Hey, this is the same problem I have.
What helped with my hiss was actually screwing in the idle screw a bit in to open it more.
That took care of the hiss.
I replaced every sensor, and distributor and wires, and pluggs and it did not help. I have new coil and it did not help. I am running out of ideas.
One thing to replace was a fuel pump and I am doing that pretty soon, so i'll let you know what happens.
You let me know what happened to your car, and what did you do!
Thanks.
Old Dec 9, 2005 | 07:28 AM
XThree's Avatar
Car: 91 RS
Hello, I haven't done anything else to it since the first info in my post. I was goind to replace the fuel pump, and check again, then do distributor next. but then the battery died, and I decided if I'm going to have to drop the rearend to replace the fuel pump, and/or replace the distributor I'm going to wait until I get a walbro fuel pump, and a different rear end and replace the springs and stuff while I'm in there. Also I want to put a high performance distributor instead of factory. So I decided to put it in the garage indefinatley as a long term project and do it the way I want when I get the money which hasn't been since.
specialized
Jun 18, 2022 09:26 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Wade787b
Sep 29, 2015 01:15 PM
Exxon Limited
Aug 9, 2015 08:13 PM
