90-92 Camaro White Face Gauges & Brushed Aluminum Trim
Old Jul 2, 2005 | 09:22 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
I got both off of ebay, all together it ran me $43.44 USD after shipping. I had to hand cut the hole for the fuel needle on the gauge set. Needles do not have to be removed to install these, which is great. lines up perfectly to OEM holes and fits like its stock. The brushed aluminum bezel is affixed with ultra thin double sided tape. The trim needed a light sanding to smoothe the edges of where the gauge openings were cut out, but other than that, its awesome!
The only thing that I did not like was the gauges come with a seperate on/off button, and dont power on via the headlight switch. I'm working on a fix for that, but I need it in the car to play with it more. All around, I'd say that the weren't the best of the best I have experienced. For the money, you cant beat it. It gives a totally new, awesome look to the 90-92 Camaro cluster!
White face gauges:
Ebay Seller ID: rmkspeed
Total Price After Shipping: $24.95 USD
Aluminum Cluster Bezel
Ebay Seller ID: fireandicemotorsports
Total Price After Shipping: $18.49 USD
All around, both are great items and make the stock cluster look 100% better than stock. I'm gonna toss it back in the car tomorrow so I can power it up. (I already tested it with a 12V power supply in the house... looks GREAT!)
Attached is what my cluster looks like after installing both items:
Attached Thumbnails 90-92 Camaro White Face Gauges & Brushed Aluminum Trim-dscf0736.jpg
Old Jul 2, 2005 | 10:04 PM
KintaroOe's Avatar
Car: '91 bird '87 Z28 '86 T/A
Engine: LO3 LG4(ls1 in works) 350
Transmission: 700R in all
Axle/Gears: wimpy 10 bolts
thats real nice
Old Jul 2, 2005 | 10:41 PM
92RZ's Avatar
Car: 92 Camaro RS
Looks great. I want to eventually order those, but I wasn't sure how good they'd look, but wow that really looks great. Post some pics once you get it installed in your car, that'd be great.
Old Jul 2, 2005 | 10:43 PM
venom's Avatar
Car: 1992 RS
Engine: 305tbi
Axle/Gears: 3.08
I just bought those same gauges off ebay myself. I also had to cut a hole for the fuel gauge, I just thought they forgot to cut mine. How did you manage to get those on without removing the needles? I think they're pretty good quality too, but paying $13.95 for shipping and when I got them, the shipping was only like $1.52, total ripoff
Old Jul 2, 2005 | 10:46 PM
92RZ's Avatar
Car: 92 Camaro RS
yeah, that's how most ebay buissness's make their money by charging you 10x the shipping.
Old Jul 2, 2005 | 10:59 PM
Genopsyde's Avatar
Car: 91 RS
I got the same setup except i got the silver face gauges instead of white.
Old Jul 2, 2005 | 11:51 PM
92RZ's Avatar
Car: 92 Camaro RS
Any pics genopsyde?
Old Jul 3, 2005 | 09:34 AM
jimp2001's Avatar
Engine: LO3 305 TBI
I snipped the hole around the fuel gauge using a tiny pair of dikes. The slid right over the needle and dropped right on no problem. the hole for the fuel gauge was a little smaller, and I had to push it over the needle hard to get it on there.
Yes, it was expensive shipping, but that is just to attract cheap buyers. I would say that a $24.95 total price is very fair for the set. It would be another story if it was $24.95 + S&H.
Old Jul 3, 2005 | 10:41 AM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
That looks really good.
Suggestion: Take it all apart again. I powered it up outside the car too, and figured everything would be okay because it looked good. What I forgot was that the brake, check engine, oil level, and infl rest lights light up on the gauges, not on the overlays. So, the openings for the words on the overlays have to line up exactly with the ones on the faces of the stock gauges. I made this mistake and didn't correct it until I took the whole dash out again, and it bugged me every time any of those lights were on. I just took apart the cluster, and held up each of the faces that lit up to the sunlight, so I could see through to make sure they lined up. They're perfect now.
Old Jul 4, 2005 | 02:57 PM
venom's Avatar
Car: 1992 RS
Engine: 305tbi
Axle/Gears: 3.08
I had the same prob with a set of el gauges I had for my 96 beretta Z26, just took a little adjusting and was perfect
Old Jul 4, 2005 | 06:52 PM
jimp2001's Avatar
Engine: LO3 305 TBI
i popped in the gauges and the letters didnt line up, I lined it up, and didnt like it because it was so dim, so i removed the factory overlay for the tach, now the letters light up white, but looks great and it more noticeable during the daytime.
While I was wiring my gauges, I went to power on the parking light wire in the kick panel, and grounded it with a self tapper in the kick. I pullled the carpet back and saw the ground underneath my car Time to find another car. I just bought this one for $900, fixed the fuel leak, and I'll see if I can flip it for $1500. The body is in fair shape, As long as they dont look underneath the car, I'll get 1500 for it, I hope.
Old Jul 5, 2005 | 04:04 PM
jimp2001's Avatar
Engine: LO3 305 TBI
heres what it looks like installed in the car
Old Jul 6, 2005 | 12:26 AM
92RZ's Avatar
Car: 92 Camaro RS
wow that looks awsome
I'm definetly going to consider taking the same route as soon as I get some extra cash.
Old Jul 6, 2005 | 07:12 PM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Looks great... but you need more aluminum
Old Jul 6, 2005 | 08:37 PM
jimp2001's Avatar
Engine: LO3 305 TBI
that looks hot, where'd you get the kit? is it real brushed aluminum?
Old Jul 7, 2005 | 07:15 PM
Car: 92 Z28
I made it, and yes its real aluminum.. I'll see if I can dig up the thread for ya.
I brought my thread back from the dead but here is a link in case you dont see it
https://www.thirdgen.org/techbb2/sho...65#post2423665
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Reddeath210
Oct 6, 2015 08:20 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
