Oil consumption problem
Old Jul 7, 2005 | 10:47 PM
87350IROC's Avatar
Car: 87' IROC
Ok guys bear with me. I have a lot of data here. My engine is burning an extreme amount of oil, around 1 quart for every 200 miles. A little blue smoke at start up but mostly when the engine is under heavy load. Here is the story of the engine.
L98
10:1 compression
rebuilt 4000 miles ago
bored .030"
L98 heads with .010" shaved off to ensure flat surface
intake manifold not shaved to match
new valve seals
high volume oil pump
new pcv valve
stock valve covers
the rings were replaced and block honed again 2000 miles after the rebuild because of the oil problem but this did not solve it. I believe my engine builders are idiots, so i wouldn't put it past them to screw up the rings twice.
Note, the cylinders were compression tested on the first set of rings and all were around 175psi.
Also, i noticed a SMALL pubble of oil on the outside of the intake manifold near where the runners meat the manifold. If i remember correctly, last time i had the runners off there was a small puddle of oil on the inside and at the bottom of each runner.
Also, the oil and coolant are clean, they have not mixed.
Also, my spark plugs have oil on them. Each plug has wet oil on the threads and solid crud on the ceramic and electrode. The majority of the solid crud seems to be facing the intake valve for each cylinder.
Also, the rubber hoses for the pcv system do not SEEM to have an excessive amount of oil in them.
I appreciate any help you guys can give. Let my know if you need any other information.
John
Old Jul 7, 2005 | 11:38 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I would suggest a wet/dry compression test. That will test the rings.
Old Jul 8, 2005 | 12:01 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
A leak between the manifold and heads is drawing oil from the lifter valley?
Old Jul 8, 2005 | 08:57 AM
87350IROC's Avatar
Car: 87' IROC
This is one of the things i was considering, but it doesn't explain oil at the bottom of the runners. I may have more than one problem contributing too.
Old Jul 8, 2005 | 01:37 PM
87350IROC's Avatar
Car: 87' IROC
Yeah i know i should do this. I just don't have the equiptment. I'll see if i can find someone with the right stuff. In the meantime i appreciate any other ideas.
Old Jul 10, 2005 | 01:03 PM
87350IROC's Avatar
Car: 87' IROC
Hey guys i could really use a few more oppinions on this. I appreciate the help from others so far.
John
Street Lethal
Apr 30, 2019 12:14 PM
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
