C5 calipers, LS1 rotors, stock rims
Old Jul 9, 2005 | 12:38 AM
cormyr's Avatar
Car: 89 Formula 350 WS6
Engine: 383 miniram
yes, you can fit C5/Z06 calipers with LS1 rotors under stock rims. the benefit over the LS1 caliper is you will never have to worry about it spreading. the stiffening ribs make it a tight squeeze but as long as you clearance your spindle adequately there is no problem. there is about a 4mm clearance between the stock pontiac rims and the C5 calipers. here's the proof:
Attached Thumbnails C5 calipers, LS1 rotors, stock rims-c5-caliper-stock-rim.jpg
Old Jul 10, 2005 | 12:57 PM
cormyr's Avatar
Engine: 383 miniram
btw thanks to ed for some very high quality parts at a reasonable price. i'd recommend him to anyone upgrading their brakes.
Old Jul 15, 2005 | 01:57 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Re: C5 calipers, LS1 rotors, stock rims
Tell that to the C5 guys. They may be stronger, but they will spread if you go racing.
Old Jul 16, 2005 | 06:00 PM
cormyr's Avatar
Engine: 383 miniram
Re: Re: C5 calipers, LS1 rotors, stock rims
you're the first one ive heard say that. maybe you could be more specific and link us to the thread you are talking about. if you do a search here seems the consensus is the ls1 calipers spread under heavy racing but the c5 calipers hold up ok from what ive read.
Old Jul 17, 2005 | 04:40 AM
Re: Re: Re: C5 calipers, LS1 rotors, stock rims
Sorry, no thread to point to when your at a race and see the results.
Old Jul 17, 2005 | 05:37 AM
ebmiller88's Avatar
I'm sure most of the dual piston calipers would spread over time if you use them hard enough, it's just that no one has complained about the C5 calipers doing it yet. It's a good thing to know they'll fit under that wheel too.
Ed
Old Jul 19, 2005 | 03:51 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Sweet! Good to know that you can use a c5 caliper and clear a 16" rim.....looks awesome.
Old Jul 19, 2005 | 09:56 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
Looks to me like you are running a wheel spacer to make it work. The wheel studs look pretty shallow in the lugs.
Old Jul 20, 2005 | 02:09 PM
cormyr's Avatar
Engine: 383 miniram
nope, no spacers necessary. fits perfectly as is. the motormite lugs that ed supplied with the hubs come right about to the top of the lugnut which is all you need.
Old Jul 30, 2005 | 08:40 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Has anyone here experienced caliper spread? A race car team I worked for use c5 calipers on the rear brakes for a 06 zo6 we were racing and never ever experienced a problem
Old Jul 30, 2005 | 10:24 PM
cormyr's Avatar
Engine: 383 miniram
well i had to dig but i did find this:
http://frrax.com/rrforum/index.php?a...ter&f=2&t=1300
apparently they will spread but its rare.
Old Jul 30, 2005 | 10:33 PM
cormyr's Avatar
Engine: 383 miniram
btw heres another pic with the wheel off
Old Aug 1, 2005 | 01:04 AM
cormyr's Avatar
Engine: 383 miniram
really...
Old Aug 2, 2005 | 04:15 PM
sjc115's Avatar
Car: 1984 Camaro
Engine: 350, 4bbl
Axle/Gears: GM, 3.23 posi
cormyr: Where did you buy your C5 setup from?
link?
Old Aug 3, 2005 | 12:52 AM
cormyr's Avatar
Engine: 383 miniram
link?
got alot of the conversion parts from our very own ebmiller88 right here on this board. great stuff, everything was perfect and the price was good. i got the calipers and rotors from autozone, they are pretty cheap there plus i have a connec. earl's ss 1le brake hoses from summit and axxis ultimate ceramic pads from www.mr-auto-parts.com but you can choose whatever pads and source you prefer.
Old Aug 3, 2005 | 12:55 AM
cormyr's Avatar
Engine: 383 miniram
Old Aug 6, 2005 | 12:53 PM
irocdan's Avatar
Car: 88 Iroc vert
Engine: 305 tpi. cts-v brakes
Transmission: Tremec T-56
what did the swap set you back?
Old Aug 7, 2005 | 01:19 AM
cormyr's Avatar
Engine: 383 miniram
all new parts, about $600 including pads and stainless hoses but i modded my own spindles
Old Nov 16, 2005 | 08:48 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
I think I already know the answer (won't fit), but has anyone tried GTA wheels over this setup?
Old Nov 17, 2005 | 07:21 PM
ebmiller88's Avatar
I doubt it...you need a spacer to get the LS1 calipers to clear anyway, and I think the ribs may hit also. If I can get the chance I'll try to fit it up soon, I have an LS1 kit ready to go out but if I can find a GTA wheel close I'll try to fit the C5 caliper on it to see.
Ed
Old Nov 17, 2005 | 08:22 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
really...
Ok so it wasnt a really c6 zo6. It was a c5 zo6 with c6 body pannels. The c6 frame is made out of aluminum so its doesnt make for the safest race car. But we use stock c5 front brakes on the rear. Up front we use apracing 6 piston calipers.
Old Nov 17, 2005 | 10:37 PM
nape's Avatar
Ed
Thanks Ed. I'm trying to find someone local that has them to help. I'm going to run a spacer for track width anyway, but I'm guesstimating it's going to run out of room radially first.
Old Nov 18, 2005 | 02:10 AM
Gr89RS's Avatar
Car: '02 Z06
Ed
What exactly is the reason for them not fitting under the GTA wheels? Will this work for the stock 91 Z28 16" wheels? Sorry if I'm asking a stupid question, but thanks for the help.
Old Dec 1, 2005 | 03:55 PM
vernw's Avatar
Axle/Gears: 4.11 posi Ford 9"
ED - I've got a 16x8 GTA wheel with a bent lip (looks like someone rammed a curb with it) that I'll send you FOR FREE to check the GTA fitment issues. Sounds like the only way I can be sure I get the right stuff to up grade my fronts to LS1 or whatever you think is best. Don't need road racing capabilities, just want a better "stopper" and better looking rotors size-wise.....
Old Dec 1, 2005 | 07:41 PM
ebmiller88's Avatar
Sounds great, Vern, I'll take you up on that. I'll send the info in my e-mail response to you tomorrow..today was too hectic and I didn't get to it.
Thanks!
Ed
Old Dec 5, 2005 | 03:36 PM
baymarauder's Avatar
Car: '92 Camaro RS - gone
I thought the C5 and LS1 calipers were identical gravity cast units. I was under the impression that only the Z06 calipers were different (pressure cast).
Old Dec 5, 2005 | 09:06 PM
ebmiller88's Avatar
Nope...LS1 and C5/ZO6 are different. It's the C5/ZO6 calipers that are identical except for the "paint job".
Ed
Old Dec 5, 2005 | 10:48 PM
Ed
Oh, I suppose I got them mixed up a bit. Thanks for straightening me out.
Old Jan 18, 2006 | 04:25 AM
ebmiller88's Avatar
Cormyr,
Did you have to grind the lower cast vane off of the C5 caliper? I'm trying to fit my LS1/C5 combo setup and it won't fit due to that last fin on the back side, it contacts the lower part of the spindle where the bracket bolts on. Please advise..
Thanks!
Ed
Old Jan 25, 2006 | 01:01 PM
ebmiller88's Avatar
OK, here's my pics of my LS1 rotor setup using a C5 caliper. I'm using a standard LS1 bracket and the LS1 carrier. I had hoped to use the C5 carrier for a few reasons..one being the price. An LS1 carrier is $60, a newe C5 carrier is $35. The second reason is the fact that you may need to grind the head of the lower spindle bolt to get it to clear the LS1 carrier, the C5 carrier has more clearance in that area and it's not an issue with the C5 carrier. I have a different design and it's not an issue with my setups either, no grinding required. THe problem is that the C5 carrier simply wouldn't bolt up as easily and doesn't fit between the rotor and bracket as well as the LS1 carrier does.
Here's the interference I have, I've had to totally remove the lower two ribs on the C5 caliper. No big deal, just a little time to cut it off. With those two ribs gone, it fits up very well although I will be moving the carrier holes a bit on the bracket to get it to fit like I like it to.
Ed
Attached Thumbnails C5 calipers, LS1 rotors, stock rims-c5-caliper-interference-1
Old Jan 25, 2006 | 01:02 PM
ebmiller88's Avatar
Closer view of the ribs to be removed. Notice how the caliper slider bolt is not installed in the top hole as pictured, it won't line up due to the ribs. I have taken them off and I'll have more pics later.
Ed
Attached Thumbnails C5 calipers, LS1 rotors, stock rims-c5-caliper-interference-3
Old Jan 25, 2006 | 09:22 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
Ed,
Are those the C5/LS1 brackets Serpent99 makes? I'm ready to bolt mine up as soon as I have some time and these are all that I need now!
Old Feb 5, 2006 | 06:56 PM
ebmiller88's Avatar
That's just a test LS1 bracket I have on hand.
I'll have more pics up in a bit.
Ed
Old Feb 5, 2006 | 07:49 PM
ebmiller88's Avatar
OK, here's how I got the caliper to fit. Please note that I don't like modifying stock parts in any way but in this case, considering the options, I feel it's necessary to get the caliper to fit with the least amount of hassle: remove the two lower fin castings on the back of the caliper, easy. I still need to massage a new bracket since I don't really like how the LS1 bracket locates the caliper so I'm working on a new one. I'll post pics of that when I have it figured out.
Ed
Old Feb 25, 2006 | 03:57 PM
ebmiller88's Avatar
Ok fellas, my setup is done. The bracket I made for it is an all new bracket so to speak, patternted after a modified C4 bracket. I rotated the caliper a bit for clearance on the caliper piston bores and to make it fit better in my opinion. Here's pics of my finalized setup. First off is a pic of the bracket I made compared to a standard C4 bracket. I trimmed the new bracket for better clearance and a better fit:
Attached Thumbnails C5 calipers, LS1 rotors, stock rims-ls1-c5-bracket-compare
Old Feb 25, 2006 | 04:00 PM
ebmiller88's Avatar
Next is a pic of how the bracket and carrier look with the inner pad installed:
Attached Thumbnails C5 calipers, LS1 rotors, stock rims-ls1-c5-bracket-fit
Old Feb 25, 2006 | 04:01 PM
ebmiller88's Avatar
Oops..
Old Feb 25, 2006 | 04:02 PM
ebmiller88's Avatar
Now with the trimmed up C5 caliper installed...no clearance issues whatsoever:
Attached Thumbnails C5 calipers, LS1 rotors, stock rims-ls1-c5-combo-caliper
Old Feb 25, 2006 | 04:10 PM
ebmiller88's Avatar
Old Feb 25, 2006 | 08:22 PM
ebmiller88's Avatar
Now for the wheel fitup issues. This setup will fit into 16" Formula wheels (pictured) and 16" Iroc and Z28 alloy wheels with no problems and plenty of room, about 1/4" between the caliper and the rim. The GTA wheels however, still have interference. The stiffening ribs on the back of the C5 caliper contact the wheel and will need to be ground down to get them to clear the ridge on the back of the GTA wheel. Other than that they seemed to fit fine but once I ran into that interference, I didn't go any further with the GTA wheel today so I don't really know if they'll need a thin spacer behind the wheel or not.
Ed
Attached Thumbnails C5 calipers, LS1 rotors, stock rims-ls1-c5-combo-web
Old Feb 27, 2006 | 12:24 AM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
While Ed is busy fitting up parts, I'll throw in a comment or two about brake bias with this setup.
If you sit down and do the math with the piston area and lever arm length, you'll note that the C5 calipers will shift the brake bias about 5% more to the rear, compared to LS1 calipers, all else being equal.
What that means is, this brake setup should go together well with either the 1LE/LT1 PBR rear discs, or the old Delco-Morraine iron calipers. However, if you already have LS1 brakes on the rear, and mount the C5 calipers on a 12" front rotor, you'll end up with a LOT of rear brake bias.
Just to throw out some numbers, here's the approximate % of brake force on the front wheels with some common combos.
1LE front & rear = 65%
LS1 front & rear = 65%
LS1 front, iron rear = 71%
LS1 front, 1LE rear = 72%
C5/12" front, iron rear = 66%
C5/12" front, 1LE rear = 67%
C5/12" front, LS1 rear = 61%
(figures neglect proportioning valve effect and weight transfer, also assume same pad cf on both ends for simplicity. The point of the exercise is to look at how the figures compare to one another, rather than worrying about the absolute values.)
So IMHO, if you have LS1 rear brakes, and want to use the C5/12" setup up front, you'd better plan on adding an aftermarket proportioning valve to dial out some rear brake. (EDIT: I consider that the 65% F/R setups -- 1LE and LS1 pure -- as being about the max permissible rear bias, IOW *just barely* OK. By that I mean that people occasionally have problems with either rear wheel lockup or wheel hop, with those setups. Not saying that everyone experiences that, since it can be avoided or cured by the right prop valve, suspension setup, or pad selection -- but it happens often enough to indicate that's about as much rear bias as most F-bodies can effectively tolerate, IMHO.)
Also, if you prefer less pedal effort, especially on a non-track car where caliper spread isn't a concern, the LS1 calipers might be a better choice. I'm pointing this out, since some people seem to complain that the 1LE setup requires too much pedal effort -- if you're one of those people, you'd probably be happier with the LS1s than the C5s, since the larger piston on the LS1s provides much more hydraulic assist.
All IMHO, and YMMV of course
Old Feb 27, 2006 | 02:04 AM
vernw's Avatar
Good info, thanks, John!
Old Feb 27, 2006 | 09:54 PM
ebmiller88's Avatar
The C5 caliper pistons are very close in diameter to the C4 caliper pistons. The LS1 pistons are larger, therefore will have different pressure than the C5 and C4s will.
Ed
Old Mar 9, 2006 | 12:23 PM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
Originally posted by Dave_Jones
... Just to throw out some numbers, here's the approximate % of brake force on the front wheels with some common combos.
All IMHO, and YMMV of course ...
Will the C5 caliper not work with the C4 rotor?
thx
RP
Old Mar 9, 2006 | 02:01 PM
palric's Avatar
thx
RP
Old Mar 10, 2006 | 07:12 PM
ebmiller88's Avatar
Yes, a C4 front rotor can be used with a C5 caliper. There's a bit of room to be taken up by the pistons and pads but it works. Here's a setup I did for a MCSS using a 13" HD rotor and C5 caliper:
Attached Thumbnails C5 calipers, LS1 rotors, stock rims-13-inch-c5s-bgs10
Old Mar 10, 2006 | 07:53 PM
ebmiller88's Avatar
OK, here's pics of the final setup going to Chris B. up in 'Sconsin:
Attached Thumbnails C5 calipers, LS1 rotors, stock rims-c5-ls1-kit-complete
Old Mar 10, 2006 | 07:58 PM
ebmiller88's Avatar
Old Mar 10, 2006 | 07:59 PM
ebmiller88's Avatar
One thing I learned doing this setup for him is that C5 pads WILL NOT work with Ls1 carriers..they are a tad too long, the pad material is too tall and will hang over the top end of the rotor, and the lower side of the pad will interfere with the carrier should you decide to shorten them to get them to fit. I didn't get a pic of that but I will in the future. Here's the pad fitup:
Attached Thumbnails C5 calipers, LS1 rotors, stock rims-c5-ls1-pad-fitup
Old Mar 10, 2006 | 08:00 PM
ebmiller88's Avatar
New coated bracket and carrier fitup:
Attached Thumbnails C5 calipers, LS1 rotors, stock rims-c5-ls1-bracket-fitup
