Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
My 1st time to the track
Old Jul 9, 2005 | 09:26 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
Here is my car:
85' Z28 LB9 WC T5 w/ 3.42 posi
headman shorty's tp a 2.5" cut out
Ported upper and lower TPI w/ SLP runners
1.6 comp magnum roller tips
Smog delete
AC delete
Hurst short throw
Center Force Clutch
8.5 mm MSD wires
crane AFPR @ 40psi
Timing @ 6 degrees
NGK plugs
K&N filters and free mods
Best run:
rt - .775
60ft - 2.230
330ft - 6.203
1/8 ET - 9.509
1/8 mph - 75.47
1000ft ET - 12.304
1/4 ET - 14.678
1/4 mph - 95.31
I am fairly pleased with the outcome. I think my modifications to the TPI helped my top end. I need to work on my launch. That2.2 60 ft was my best all day and it was on a set of pretty well used BFGs. I was abe to turn 2.3 60 fts on my 235 firehawks. I have spohn lCAs, panhard rod and relocation brackets waiting to go on. How do those damn L98s get 2.0 60 fts on street tires?! grrrr
Old Jul 10, 2005 | 12:52 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Those are decent times for the first time at the track. With your mods and practice, low 14's should be in sight. Work on the 60' times. Good luck
Bump that fuel pressure up. 40 is a bit low. Most mild modded TPI's like 47-48.
Old Jul 10, 2005 | 01:07 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
you probly could crack a 13 second run with that trap speed if you get your 60 down. there's lots of improvements left in that car, just keep tryin!
Old Jul 11, 2005 | 12:37 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Both 9d1burd's car and mine had transmission issues, mine were the worse of the two. I blew out my driver side header gasket on #1 and #7 too. Absolutely nothing left. Car overheated. It just wasn't a good day for me. With all that, I was still turning 14.6's @ 91mph. Way to slow for whats been done, but with the problems I had I can't really expect much better.
Winger4800 drove Formul8's old car to 13.3's @ 99mph all day long. 89 Formula 350. Same mod list, but with a performance built transmission and 9.5 Vig stall. Stock long block, bolt ons, suspension, and drag radials up the wazoo.
________________________________________
Mike, congrats on your car, it definitely has major potential with heads/cam if you ever decide to do it. A set of AFR heads would make serious power for you.
You made serious progress from your first run to the last.
Old Jul 11, 2005 | 02:43 PM
I am pretty much done with modding my car for now... the only things that I may do in the anywhere near future would be switching to the 89' MAF computer and begin computer tunning. Suspension and other mods to increase traction are also on the table. I figure what good is more power if i can't break 2.2 60' as it sits now? Somday i may do some porting to the heads and get a bigger cam, but i cant see that happening for a while. I guess my goal is 13s with computer and suspension tuning.
Old Jul 12, 2005 | 12:29 AM
Get some steel 1.6 roller tip rockers and throw them on there. That will help a bit with that cam, and it will bring your lift to about .430"/.441" with slightly more duration because of the rockers. It will help a bit.
Old Jul 12, 2005 | 08:12 AM
hehe... i already do bill. i thought i mentioned that
Old Jul 12, 2005 | 12:11 PM
V6camaroman's Avatar
hey nice times man. very good lookin car. its identical to mine exept i have t tops. im in the middle of a 700r to t5 swap as well. 14.6 is a pretty good time for a mild mild 305. i was going to ask you. when you rebuilt your 305 i remember looking at the thread you had about it. what type and color of paint did you use on your lower and upper tpi intake? it looks very close to stock and thats what i want on mine. was it rattle can?
Old Jul 12, 2005 | 12:23 PM
Here is my car:
Smog delete
AC delete
Hurst short throw
8.5 mm MSD wires
crane AFPR @ 40psi
Timing @ 6 degrees
NGK plugs
My bad.
Old Jul 12, 2005 | 12:59 PM
I guess, it would apear that i did a rebuild as i had th whole motor out and all.... however there are only 56k on the car and I just happen to yank the thing out because i was doing the t5 swap and a bunch of oil leaks were pissing me off so..... i guess the rest is history...... back to your question
As far as the intake goes... i started with a pretty standard grey primer then a silver/grey aluminum color (cheap autozone brand) Then the thing that made the finish look stock was a mistake. I used a cheap lacker clear coat it was horible (Duplicolor) it wouldnt come out of the can consistantly and it looked slightly splochy. Fortunatly that inconsistancey gave it a nice cast aluminum look.
Old Jul 12, 2005 | 01:41 PM
For that perfect aluminum color check out your nearest autozone. And get either the 1200* or 500* ceramic paint in "aluminum"
VERY close to aluminum. So close to aluminum in fact that I couldn't even tell that I painted the plenum when I put it next to my bare AS&M SS runners.
If anyone saw 9d1burd's (Tim) engine bay then you were looking at a painted plenum and bare runners.
Old Jul 12, 2005 | 02:51 PM
Looks like "HO" Scale... hehe
Old Jul 14, 2005 | 02:20 PM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
Hey Smurfn, do you know the elevation there?
Old Jul 14, 2005 | 02:29 PM
i wana say somewhere around 600-700 feet
Old Jul 14, 2005 | 03:30 PM
650ft
http://racefan.com/showtrack.asp?id=1133
Old Jul 14, 2005 | 07:13 PM
AT9305RS's Avatar
Car: 91 Bird
Engine: 3.1 w00t
Transmission: 7hundo
Axle/Gears: bent
i can personally vouch that Smurfn's TPI pulls like a mother up top......exactly where it shouldnt, lol
yea mike we will go to the track again and have a REAL battle of the 305's
Old Jul 15, 2005 | 08:16 AM
the kicker is, i ran these times and the damn car still runs like ****. I know I have an exhaust leak. I have yet to set the TPS and IAC and i think i may have a vacuum leak (eratic idle when cold, and a high idle whe hot) The vacuum leak wouldnt really surprise me at all. I may need to cut my own custom gaskets for the runners.
Old Jul 15, 2005 | 09:46 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
His car was pretty quick that day, especially for conditions. Track elevation is like 620-650 feet as mentioned, and it was HOT that day. Track temps had to be over 100*F easily.
Old Jul 19, 2005 | 04:20 PM
TBI92Camaro's Avatar
Car: 92 Mustang Coupe/89 Camaro RS
Engine: 5.0 carb'd/305
Transmission: T5/T5
Axle/Gears: 3.73 and stock TrakLok/stock GM
Your car pulls damn hard at the end of the 1/4 man!!! A 9.5 should bel ike a 14.9-15.1 and you knocked down a 14.6!!!
Get those 60 ft.s down. The BFG's should have gotten you some 2.1 60 fts. Try "slipping" the clutch a little out of the hole then get into it. I cut a few 1.95 60 fts on BFG's with blown shocks and a slipping clutch in my mustang...so yeah its possiblei ndeed. Goodl uck!
Old Jul 28, 2005 | 05:38 PM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
Thirdgen89GTA, got a pic of that paint? I can't seem to find it anywhere in the store.
Old Jul 28, 2005 | 06:10 PM
The paint code is DH 1606 high heat aluminum, made by Dupli-Color.
I also found out the 500* stuff is almost the exact same shade as the 1200* stuff.
We gave 9d1burd's Edelbrock headers several coats of the black 1200* ceramic paint and its holding up well, even now after a few months.
If I were ever to paint an engine bay part again I'd use this stuff if I wanted to do it cheaply. Powdercoating is better, but thats way more expensive.
Azrael91966669
DIY PROM
25
Jun 20, 2017 04:04 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
