Pics of my custom 4" CAI for the LS1 3rd gen
Old Jul 14, 2005 | 09:50 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
4" semi exhaust pipe for my cold air kit. I just have to finish fitting/welding it and get a 4" to 3.5" reducer to hook up the MAF and then to the 90* elbow.
Tight clearance between the coolant tank and the radiator... this was the hardest part so far.
Another view.
Big *** K&N cone filter. 4" inlet, and about 6" by 10" long.
Filter location beneath "tray" where the charcoal canister used to sit... I think it will get plenty of cold air here.
Better view... I'll have to cut that triangular fender brace apart and make a bent piece to go around the filter on the back side. Should work out pretty good.
Whatcha guys think? This is one of the last things I really have to do besides wiring. Then its time to fill up the radiator and tranny, install the driveshaft, run some heater hoses, flash the PCM and try to fire it up. We'll see. I can't wait!!!
Old Jul 15, 2005 | 09:33 AM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Do you plan to polish or paint the pipe once it's finished? Will the wheel well liner still fit with the fender support tweaked and semi-truck sized filter?
Looks great, btw.
Old Jul 15, 2005 | 12:01 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Looks great, btw.
Probably paint or powdercoated and yet it will all still fit together.
Old Jul 15, 2005 | 05:03 PM
CamaroCain's Avatar
Car: 88 Camaro
Intake looks great, i WAS planning on changing mine up to go bellow the fenderwell to get cooler air like yours. The custom piping is awesome. Good job!
Old Jul 15, 2005 | 05:06 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Thanks man, I can't wait to get it finished... I could maybe make a few more to sell.
Old Jul 15, 2005 | 09:01 PM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
That looks awesome man. I bet that will work well.
The only thing that concerns me is if the filter starts picking up all the crap and moister that it picks up off the road from the tires, rain, ect. If the filter gets saturated enough to wear its sucking moister the MAF sensors wont like that too much. Otherwise I really do like it and would consider it for my car.
Old Jul 15, 2005 | 09:20 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
This car won't see rain... 400RWHP and 315 drag radials won't mix too well. Really though, LT1 CAI kits put their air filters down in this area
Old Jul 15, 2005 | 10:09 PM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
id buy one already have the 4" filter for it too
Old Jul 15, 2005 | 10:53 PM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Thats cool man, I'll have to look into that. That sounds like a sweet setup your running. Do you have dyno number on that or is it just what your hoping for? Out of curiousity would you mind giving me the rundown on your setup? Thanks man.
Old Jul 15, 2005 | 11:24 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
No dyno #'s yet... it's not quite done yet. Just estimates... should be 400-450RWHP... just not sure where yet. LOL Anyways, my mods......
Hmmmmmmmmmm....
-'98 346ci LS1
-stock bottom end with ARP rod bolts
-ported LS6 oil pump from Thunder Racing
-double roller timing chain
-Thunder Racing cam
-stock lifters
-7.4" Thunder Racing hardened pushrods
-stock rocker arms
-titanium retainers
-Comp blue stripe 918 springs
-'98 LS1 heads ported and polished with the newer '99-up valves
-LS6 intake
-ASP crank pulley
-ported stock TB
-ported & descreened stock MAF
-4" CAI setup with big K&N
-stock flywheel
-centerforce dual friction clutch
-LS6 slave cylinder and clutch master cylinder
-stock T56
-Hurst Billet Plus shifter
-LS1 aluminum driveshaft
-4th gen Moser 9" with 4.11s, aluminum center section, and LS1 brakes
-Lakewood LCA's and APHR
-weld in SSM SFC's
-KYB shocks and struts
-Jamex STB
-PST poly frontend rebuild kit
-LS1 front brake conversion
-Wilwood adjustable proportioning valve
-Hurst linelock
-LS1 master cylinder for brakes
-1.25" front bolt on wheel spacers
-17x9" AR220's up front w/ 275/40s and 17x11" in rear w/ 315's
-stock WS6 springs, 1.5 coils cut on front (for lighter LS1)
*I think that's about it for now... maybe a few things I missed but that is about it. This car will be full weight with AC, power seats, PW, PL, PS, etc, etc. I just want to drive it again! Sad thing is that I still want it painted, roll cage, different hood, and lots of other litte stuff.
Old Jul 15, 2005 | 11:36 PM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Damn thats a nice setup man. What are you cam specs? How big did you have the heads ported to? Are those 99 up valves stock size?
Old Jul 16, 2005 | 09:06 AM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Thanks man, its getting there. Its a 230-ish, .575"-ish cam. Heads are worked are pretty good. Stock valves, just the better style. '98 valves suck
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
neekolzun
Aug 24, 2015 04:59 PM
reiderz iroc
Aug 13, 2015 04:57 PM
