Dripping fuel
Old Jul 18, 2005 | 11:56 AM
SkullLeader's Avatar
Car: '87 Iroc Z
Engine: TPI 305
Transmission: Manual
Dripping fuel
Why would I be dripping fuel from underneath the vacuum canister, just behind the driver side headlight? Does a fuel line run in that area?
87 tpi 305, manual tranny
And one more thing, how do I check the fuel pressure, I think it might be too high.
Old Jul 18, 2005 | 03:28 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
That's where (about) on my IROC the charcoal cannister is...check to see it it full of fuel...should be assecible from poppong the hood,,,will have an electrical connector a a few lines going to it,
Old Jul 18, 2005 | 11:42 PM
Car: '87 Iroc Z
Engine: TPI 305
So it should be full of fuel or no? I thought it was a vacuum canitster, but it is a charcoal canister, huh, learn something new everyday.
Old Jul 19, 2005 | 12:29 AM
CRZYTRN-92Z28's Avatar
Car: 1992 Z28
Engine: 350 L98 w/ D-1SC
Transmission: POS 700-R4
Vaccuum canister is below the charcoal canister. The vacuum canister looks like a huge black softball. The charcoal canister has a crap load of lines going to it and is shaped like a coffee can. You may have a leak at the charcoal canister. Start there.
Old Jul 19, 2005 | 09:51 AM
Car: '87 Iroc Z
Engine: TPI 305
Before this happened I was idleing at around 1500 rpm, but now I'm idleing at about 2500, and I'm getting a code 45. We tryed to adjust the IACV but it didn't do anything. Do I need to replace the IACV or does it sound like my problem is elsewhere. Oh and yes the canister was full of fuel.
What else could cause a high idle, and what should the idle speed be?
Thanks guys.
Old Jul 19, 2005 | 11:08 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You need to replace the cannister...don't believe it can be drained. It's there to absorb fuel vapors from the tank. At certain times of operation, the solenoid will open and the vapors are supposed to be sucked out and reburnt through the throttlebody...could be your solenoid is not operating.
It should not be full of fuel.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
TheExaminer
Aug 26, 2015 04:59 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
