Power door lock problem
Old Sep 28, 2001 | 11:21 PM
One Eyed Jack's Avatar
Okay, my door locks have always worked fine. Recently, when I press the button, the passenger door lock wiggles, but does not fully lock. I was wondering what is wrong, and why it won't fully lock anymore. I have to reach over and manually lock it, ah what a pain.
And also I have a problem with my driver's side power window. Maybe the two are related... But anyway the window on the drivers side is slower than the passenger side. One time it actually stopped scrolling, and I had to turn off the car and turn it back on for it to work. I'm thinking its maybe a bad ground?
Just wondering what I can do to see what's wrong.
Old Sep 29, 2001 | 01:02 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Not sure about your power locks.
Almost certain your power window motor is bad. The next time it stops working when you press the switch, release the switch, wait about 30 seconds and try it again. If it moves a bit then stops then your motor is toast.
Old Sep 29, 2001 | 01:56 AM
Well the window works fine on daily use. But occasionally it just ceases.
How much is a replacement motor?
Old Sep 29, 2001 | 06:05 AM
Dingo's Avatar
The window track might just be dirty. I would try to cean and relube the track before replacing the motor. I think I've read in the past that the door locks get dirty to.
Old Sep 29, 2001 | 08:03 AM
IROC&ROLL
Guest
Posts: n/a
Your door lock problem is likely a worn rubber bushing at the end of the actuator. The linkage connects to the actuator there. When worn, the lock may only work in one direction, or not at all. I don't know if you can buy just the bushing. The service manual doesn't mention it.
Old Sep 29, 2001 | 09:59 AM
YEAH it unlocks fine... What should I do about it?
And how would I go about cleaning the track? Do I have to remove the window or what? I wanna do it this weekend while its warm. I need to adjust my windows anyway to move them up a fraction.
[This message has been edited by One Eyed Jack (edited September 29, 2001).]
Old Sep 29, 2001 | 01:29 PM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
yeah i have the same problem with my power door locks, my passenger side wont lock very well, and to unlock it, it usually takes a few pokes at the unlock button. how much would it cost to have someone in a shop fix this?
1987 LG4 Camaro z28
Performance
KN airfilter, flowmaster 80 series and catco high flow converter, 180* thermostat, edelbrock performer intake
System
Panasonic CQ-DF200U deck, fosgate speakers (hpc1369, frc2246), fosgate 400a4 amp
Old Sep 29, 2001 | 04:33 PM
Enkil's Avatar
There's a tech article about servicing your power windows.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Sep 29, 2001 | 04:35 PM
Oh, I'll go check.
FOR SALE - email me
Old Sep 29, 2001 | 08:34 PM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by One Eyed Jack:
Oh, I'll go check.
</font>
1 I Jack,
I'll save you the trouble...
Power Window Motor Repair.pdf
You'll need Adobe Acrobat Reader to view the repair guide.
Later,
Vader
Justice and Freedom will Prevail
Old Sep 29, 2001 | 10:05 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
I had similar problems on my '86 IROC. Let's start with the power door locks...
Like someone previously mentioned, it could be an issue with the door lock linkages located inside the door. Take off the door panel (search the archives for info on this) and you'll see where the linkage rod goes. I took some lithium grease and put it all over the linkages, solenoid, everything. I used the "cream" kind, but I hear that the aerosol kind may work better. The door lock still sometimes sticks but not nearly as bad as before.
Windows: To clean the track, you have to take off the door panel too. You'll see the inside the door where the track is attached to the window glass. Just get some more lithium grease and put it on the track and move the window up and down to get a good covering. Again, the aerosol lithium grease may work better than the cream that I used. I would recommend doing this anyway, because it speeds up your windows a bit... I shaved about a full second off by cleaning the track! (I was bored one night, haha)
Hope this helps ya, shoot me an email if you have any questions.
1986 Camaro IROC-Z
Code 23 Paint ("IROC Blue")
305 TPI
B&M Megashifter
Grant GT Steering Wheel
New A/C Motor!
View my website, a work-in-progress
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlackTopKing
Aug 19, 2015 12:13 PM
