True Duals w/ Purple Hornies installed
Old Aug 2, 2005 | 04:36 PM
WhiteHawk's Avatar
Car: 1991 Firebird
Engine: 350,Dart Heads,Weiand In,Roller Cam
Transmission: 2400-Stall, 700R4 w/ Kit
Axle/Gears: 4th Gen 3.42 disc (I wish)
Sounds Here:
In car burnout than WOT
Video of installed and idling:
Idle Video under Car (right click save target as..)
Hedman long tube headers, 3" Hedman extenders (pass side modified), 3" Purple Hornies
Use Lock washers on the header bolts, mine came loose twice
Old Aug 2, 2005 | 06:02 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Transmission: 5 Speed
it looks to me you bolted the exhaust hangers straight to your floor? doesnt that cause excess noise or vibration?
Old Aug 2, 2005 | 07:08 PM
84firebird383's Avatar
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
He's got a stroker motor with whats essentially an open exhaust.Don't you think it will have excessive noise and vibration no matter where he puts the hangers?Besides, where else would he put them?
Old Aug 2, 2005 | 08:13 PM
WhiteHawk's Avatar
Car: 1991 Firebird
Its got rubbers my friend
I can't tell if there is a vibration due to the bolts or if its just the V8 stroker with dual 3" pipes causing the rumblin...its a car alarms worst nightmare.
Old Aug 3, 2005 | 01:22 PM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
I notice your collectors are right under the crossmember, how is your ground clearance?
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
I bet you can't hear yourself think.
Looks really good
Old Aug 3, 2005 | 03:25 PM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
I like it Simple & clean install. Good job!
Old Aug 3, 2005 | 03:43 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Looks like its time for a new fuel filter! Sounds good BTW!
Old Aug 3, 2005 | 05:18 PM
WhiteHawk's Avatar
Car: 1991 Firebird
Sucks...but I live Michigan and I rarely scrape, if that tells ya anything.
Old Aug 3, 2005 | 10:30 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Sounds good man!
Old Aug 4, 2005 | 01:12 AM
3.492rs's Avatar
Car: 89 IROCZ
Engine: L98 4150 carb
Transmission: Transgo 700-r4
Axle/Gears: 10 bolt/3.23
EEK!!RUST!!!KILL IT!, btw sounds good
Old Aug 4, 2005 | 10:58 AM
WhiteHawk's Avatar
Car: 1991 Firebird
Whahahahahaha! The car is doomed already. This is my toy 3rd gen. In the future I want a real sweet RS with low miles and NO RUST! Especially when I get older with more money I can do stuff right.
Old Aug 4, 2005 | 01:42 PM
vrtc350's Avatar
Car: 81 Corvette
I feel you. I'm in the same boat. All money goes to the drive train.
Old Aug 4, 2005 | 05:29 PM
WhiteHawk's Avatar
Car: 1991 Firebird
Correct. I don't mind putting money into the suspension and drivetrain because it all will bolt onto another 3rd gen. Like a paintjob and all the other materialistic BS is a waste of money for this ride.
Old Aug 4, 2005 | 09:10 PM
84-350berlineta's Avatar
Car: 84' Camaro Berlinetta
Engine: 383
Did you have to have pipes custom bent from the headers to the mufflers, how long are they?
Old Aug 4, 2005 | 11:06 PM
3.492rs's Avatar
Car: 89 IROCZ
doen't look that bad just sand it and paint/gel coat it
Old Aug 5, 2005 | 07:27 AM
vrtc350's Avatar
Car: 81 Corvette
Mine has holes in the bottom. Not through the floor board yet, but it won't be long.
Old Aug 7, 2005 | 03:47 PM
WhiteHawk's Avatar
Car: 1991 Firebird
No I didn't get them custom bent. I just installed the header extenders and bolted them on. I did have to do some fabrication to the passenger side extender by shortening it and rewelding it. Other than that it was a pretty straight forward install.
Old Aug 7, 2005 | 10:30 PM
nick05's Avatar
Car: 1987 camaro
Engine: 358
I know you used a x-tension right off of the headers but did you also use the to bring your mufflers closer together...like turn them side-ways or somthin?
Old Aug 8, 2005 | 09:59 PM
WhiteHawk's Avatar
Car: 1991 Firebird
Oh yeah, the header extenders had too big of an s curve so I turned them inward to bring them up and in the process it brought the mufflers to the center more.
See in this pic how they are turned inward and if you were to have them straight down it would be way to low.
Old Nov 13, 2011 | 10:06 PM
Verhagen82's Avatar
Car: 82 Firebird
Engine: Boosted LSX
Transmission: Built 4L60E
Axle/Gears: 4th Gen 3.42s
Re: True Duals w/ Purple Hornies installed
wow this is a dead thread but Id love to see it...
(the links dont work anymore )
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
