How to: Clean up your TBI Engine bay... cheap!
Old Aug 27, 2005 | 07:33 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
I installed and removed a few things that really made my car look a lot nicer under the hood, for a minimal amout of money.
Mr. Gasket Non-Drop Air Filter............................ $15
APC Open Element Breather............................... $10
(8) 1/4 NPT Brass Plugs.................................... $12
Dayco 98.6" 6 Rib Belt...................................... $20
2 Pack of 5/8 colling system caps....................... $2
Making your engine look a lot nicer than stock...... Priceless
I started by removing the factory air filter snorkel, and breather tube. Capped the vaccum line on the TB, used a uni-bit to drill a hole for the sensor in the bottom of the air cleaner base. Installed air cleaner and breather.
I then decided that the 3 hoses and large vaccum controlled diverter valve for the heater core was hideous and completely unnescesary. I removed the hoses from the diverter valve and traced them back to their sources. I capped the "T" on the passenger side frame rail with the rubber caps i got from the auto parts store, and used a 90* elbow to connect the heater core to the manifold.
Now the A.I.R. system was really bothering me. It was yet another eyesore in the bay. I went to Home Depot, and purchased 1/4 Brass Square Head NPT plugs. I removed the AIR hoses from the manifold collectors, removed the AIR solenoids and smog pump, then removed each tube from the manifold. I applied JB Weld liberally to the threads of the brass plugs to ensure that they would not leak or back out. After installing each fitting, I wiped the excess JB weld off the plug to give it a more professional look. I then used my remaing cap that I got for the cooling system to plug the line from the catalytic converter next to my elbow I just installed to bypass the diverter valve. I then installed my new belt, and I was done.
Top Circle is elbow installed to bypass diverter valve. Bottom circle is rubber cap to block off catalytic converter AIR Tube.
Top Circle is elbow installed to bypass diverter valve. Middle circle is rubber cap to block off catalytic converter AIR Tube. Bottom circle is rubber cap to block off the "T" line that went to the diverter valve.
Circles indicate 1/4 Brass NPT Plugs installed into manifold on Drivers Side.
Here is how the new belt must be routed after deleteing the smog pump.
Here is a picture of the finished project:
Old Aug 28, 2005 | 12:32 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Nice
I gotta do that too the less hoses that go zig-zag across everywhere . .the better .. .I'm a firm believer in the ability of being able to reach as much as possible of the engine parts without any problems .. (read ... such as plugwires and plugs .. without going underneath the car .. just because the AIR system blocks it from top)
Old Aug 28, 2005 | 03:54 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Not too shabby!
My problem is all that has to be reversed with every smog inspection. Otherwise you risk this: "VISUAL INSPECTION: TAMPERED".
Automatic fail.
Durn California.
~kicks can~
Old Aug 28, 2005 | 04:07 PM
demetri's Avatar
Or just spray it with engine degreaser
Old Aug 28, 2005 | 04:46 PM
jimp2001's Avatar
Engine: LO3 305 TBI
Originally posted by Cadillac
Not too shabby!
Automatic fail.
Durn California.
~kicks can~
All I have is safety... no visual or sniffer
Old Aug 28, 2005 | 10:18 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
ive done all that except for the heater hose reroute..it bothers me also...the only extra ive done than that is since i removed smog and emissions i went ahead and blocked off egr valve and removed the distribution block that really cleans it up nice too..you should try that next...I live in tn..not really strict on emissions in my town
Old Aug 29, 2005 | 09:48 PM
Cadillac's Avatar
Your time will come.
Old Aug 30, 2005 | 12:53 PM
jimp2001's Avatar
Engine: LO3 305 TBI
hopefully my time will come when the car is considered a classic and doesnt have to pass
Old Sep 3, 2005 | 12:58 AM
weberflorida's Avatar
Car: 1991 Camaro Z28
Yeah I have done that stuff and it really neatens up the engine bay. Escpecially the heater valve delete and it only cost me like 6 or 7 bucks to do.
Old Sep 8, 2005 | 02:07 PM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
will the heater still work with this bypass done will the engine temp go up at all or what.
Old Sep 8, 2005 | 02:44 PM
Yeah man everything works normal on my car and from what I have read it has worked normal on everyones car that has done it.
Bill
Old Sep 11, 2005 | 09:53 PM
kyle folds's Avatar
Car: 89 Firebird
Transmission: 700
You will have higher A/C temps because the heater core casing will be hot, maybe not enough to be a problem though.
Old Sep 11, 2005 | 09:57 PM
88 Z28 Guy's Avatar
Car: 1989 IROC
Axle/Gears: 3.42 Auburn
I did the same to mine, looks a lot better.
Old Sep 12, 2005 | 08:16 PM
Green92RS305's Avatar
Car: N/A
Engine: Gen I 408
Transmission: N/A
Axle/Gears: N/A
i've done everything there except the heater diverter valve and i'm about to do that as well. thankx for the suggestion cuz i've been wondering for a while how to get rid of those stupid coolant hoses. i yanked out my a/c too so thats not gonna be affected either. glad to see if not the only one who likes a clean looking engine bay
EDIT: i found a pic of my engine bay on my PC, the only big thing left for me to do is get rid of that smog fitting to the cat (gonna get headers/y-pipe/hi-flow cat) and get rid of the evaporator for the a/c system and it'll be the way i want it to look. it'll be purty even if it is slow.
guess the pic don't work
Old Sep 20, 2005 | 03:04 PM
hmmurdock_00's Avatar
Car: 1985 Trans Am
Engine: 305 5.0 LG4
Transmission: 700-R4 Auto
Quick question, you say 98.6" belt, the tech article on removing the smog pump said 96.8". Which is it? Just went out and got a 98.7" closest i could get to the 98.7.
Old Sep 20, 2005 | 03:46 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
heres how i did mine:
i removed everything resembling a TBI SBC:
and replaced it with something else:
ive been getting compliments ever since.
Old Sep 20, 2005 | 04:28 PM
DM91RS's Avatar
Car: 91 RS
MrDude_1
heres how i did mine: LS1 M6
Yep...........that's almost worth getting on I-20 and heading toward the coast and seeing!
DM
Old Dec 12, 2005 | 10:14 AM
88 Z28 Guy's Avatar
Car: 1989 IROC
MrDude, that what i would like to do but dont have the money.
Also i bought a 98 Belt but it was even longer than the stock one it has on the car, i winded up using the stock one which is a 97, so a 96.6-97 would be the best.
Old Dec 12, 2005 | 11:02 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Pshhh, mr doods lsjuan isnt even cammed
it does look good sittin in there tho
Old Dec 12, 2005 | 04:36 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
I would love to do that stuff and show off my shiney Edelbrock valve covers but it would fail inspection out here in Phoenix. Environment police are pretty tough out here.
Old Dec 13, 2005 | 08:16 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
ive had a cam for it for almost a year now...
i still havent gotten around to swapping it in... remember, this is still a 3rdgen.. so even if the drivetrain is killer, i still have the entire rest of the car to modify before it doesnt suck.
Old Dec 13, 2005 | 03:02 PM
Ronny's Avatar
[IMG]TBI.jpg[/IMG]
Old Dec 15, 2005 | 03:09 PM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
Do you think that the open element gave you any horses/ torque over the stock snorkel kit?
Old Dec 19, 2005 | 08:54 PM
Gm Jray's Avatar
Car: 1988 Camaro Iroc-z
Engine: 383 Stroker Built
Transmission: 700r4 built
Axle/Gears: 373's limited 28 spline
Whe you rerouted your belt doesnt that reverse the water pump????
Old Jan 6, 2006 | 02:14 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
I've been looking on the search for a while but, what are those coolant lines on the passenger valve cover for, and what do they do? Just mildly confused on why they were there in the first place and i don't want to have problems that i didn't expect after removal is all.
I'd like to get rid of mine but, i don't understand what they are for.... That and j/w why didn't you remove the cat line completely (i'm planning on removing mine monday probably...) All the rest of my air stuff is gone so far though.
Old Jan 6, 2006 | 03:16 PM
Dewey316's Avatar
Car: 1990 Camaro RS
those coolant lines are for the heater core. They go in thru the firewall to (or from) the heater core.
Old Jan 6, 2006 | 03:26 PM
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
caught that part but, i'm trying to figure out what the heck the valve thing of top of it is for and what the ending affect of getting rid and capping and diverting them is. T/y for the quick response though.
Old Jan 6, 2006 | 03:28 PM
Dewey316's Avatar
Car: 1990 Camaro RS
The valve stops coolant flow to the heater core, when you have the heater turned off. There is really no major effect to getting rid of it. When you take it out, you pass coolant to the core at all times, you can still blow cold air, since you close the door to the heat exchanger, when you turn your temp to cold, it blocks airflow from the core, and gives you airflow from the vents in the cowl.
Hope that helps.
Old Jan 6, 2006 | 03:42 PM
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
exactly what i was looking for, thanks a lot!
Old Jan 6, 2006 | 04:25 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
is it majorly important to cap that vacuum from that valve?
Old Jan 6, 2006 | 04:46 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Yes, otherwise you have a pretty good sized vacume leak, your car won't run quite right.
Old Jan 6, 2006 | 04:50 PM
Engine: LB9, LB9
how can i cap it?
Old Jan 6, 2006 | 05:07 PM
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
with the 5/8 cooling cap above........
Old Jan 6, 2006 | 05:10 PM
Engine: LB9, LB9
I mean to cap off that vacuum line.
Old Jan 6, 2006 | 09:02 PM
jimp2001's Avatar
Engine: LO3 305 TBI
you can get those caps at any auto parts store
Old Jan 6, 2006 | 09:09 PM
Engine: LB9, LB9
I have some, but I cant cap the line with them, and I dont know where it starts at to cap that way.
Old Jan 6, 2006 | 09:15 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Follow the vac line. and plug it where it goes into the TBI unit, or the manifold. I can't off the top of my head remeber where it goes to.
Old Jan 6, 2006 | 09:41 PM
Engine: LB9, LB9
It goes into this like harness with wires and runs into the firewall....thats why I couldnt trace it to the TB.
Old Jan 6, 2006 | 10:31 PM
88 Z28 Guy's Avatar
Car: 1989 IROC
Well if i cant find a cap to cap off a Vacume line i do it the easy way, i get a piece of flexible vacume line and screw a tight fiting screw into it.
Old Jan 7, 2006 | 12:50 AM
Dewey316's Avatar
Car: 1990 Camaro RS
I'll go look in the morning, when I have some good light, and try to find where in the firewall that would have gone. It has been a few years now since I pulled that stuff out of my car.
Old Jan 7, 2006 | 08:28 AM
Engine: LB9, LB9
Thanks man.
Old Jan 7, 2006 | 04:56 PM
Dewey316's Avatar
Car: 1990 Camaro RS
OK, here is how I did it. I ran the vac line thru my wire loom, up to near the strut mount. I just capped that with a screw.
The more I look at it, I'm not sure if what kind of vacume if any it really see's but hey.
Wire routed up near the wireloom, so it isn't an eyesore.
Pluged with a screw that fits in snugly, then screwd in a bit to ensure it seals.
All tucked away, nice and clean!
There is also a how to that I did for the coolant lines, I did it basicly the same, but mine shows it with all the emmisions stuff still intact.
https://www.thirdgen.org/techbb2/sho...ghlight=heater
Old Jan 7, 2006 | 08:19 PM
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
thats handy as hell dewey thanks!
pictures always speak louder than words for me, unfortunately my new valve cover along with some other ****t i got cost more than i was hoping for it to so it may be a few untill i buy my 5 bucks worth of hose clamps lol (making an excuse to not work on the car).
Old Jan 8, 2006 | 07:06 PM
88 Z28 Guy's Avatar
Car: 1989 IROC
thats exactly how i did mine.
Old Jan 10, 2006 | 07:59 PM
irocwagon's Avatar
Car: camaro84.87iroc,91vert
Engine: Lt1, 383tpi,350tbi
Transmission: t56,T5,T5
Axle/Gears: 4thgenunknown,373,323?
where did you get the brass fittings from, ive been looking for 2 days.
Old Jan 10, 2006 | 10:32 PM
88 Z28 Guy's Avatar
Car: 1989 IROC
Well i got mine from the local hardware store, well i had to use zinc ones since they were out of brass ones but they worked fine.
Old Jan 11, 2006 | 05:27 PM
jimp2001's Avatar
Engine: LO3 305 TBI
got mine from home depot plumbing dept. they have a square head so you'll need a 12 point socket to install them.
Old Jan 11, 2006 | 07:46 PM
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
or a wrench works. For some reason i of course couldn't find that 10 mm socket that i needed at the time. They are super easy to put on even with a wrench because, the airlines will now be gone and outa the way!
Old Jan 24, 2006 | 03:22 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
nice looking. ive been thinking about removing all my emmisions crap. i like how you removed the lines over the passenger side manifold too. why did you just remove the whole cat converter tube instead of just capping it?
Old Jan 24, 2006 | 10:57 PM
Trah84Z's Avatar
Car: 1984 Z28 ~Brown Horse~
Engine: 305 V8
Axle/Gears: 3.23...i dunno...
would it be beneficial to run a breather filter on both sides instead of just one?...
