Third Gen F-Body exhaust sound clips!
Old Aug 31, 2005 | 05:57 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Thirdgen Fbody exhaust clips.
I made this thread in attempt to make it easier to browse through the clips.
First off, exhaust sounds on the main page.
[Cut Outs]
Clip One - 305 with 1.6 rockers, and an open element. [305q_ta86]
Clip Two - 350 TPI, Hooker 2055's, open Y pipe. [IROCThe5.7L]
[Dynomax]
Clip One - 91 305 TPI, all stock. SLP 1 5/8" headers and Y, 3" magnaflow cat, 3" I-pipe, Dynomax Ultra Flow, Walker Dynomax tailpipes, and Megs round angle cut tips. Oh, and a Vortech S/C. [madmax ]
Clip One, Clip Two - Vortec 350, GMHPP roller cam 235 dur .480 lift, Jet-Hot coated Hedman Hedders, test pipe, Dynomax cat-back. [1tinindian]
Clip One - 305 tpi dynomax catback, gutted cat. [89_fireform ]
[Flowmaster]
Clip One - 350 TPI, stock manifolds/Y-pipe/I-pipe, catco high-flow cat, 43083 3" in dual 2 1/2" out 80 Series muffler. [IROCThe5.7L]
Clip Two, Clip Three, Clip Four - 350 TPI, coated hooker 2055's/ypipe, 80 series muffler. [IROCThe5.7L]
Clip Four - 305 TBI, 80 series muffler. [Cadillac]
Clip Five - 350 TPI, headers, catco high-flow cat, 80 series muffler. [BDK]
Clip Six - 350 TPI, hooker shorties/y pipe, american thunder 3" catback (80 series muffler). [Orr89RocZ]
Clip Seven - 305 TPI, 43083 Flowmaster 80 series with 3.5" tips, stock manifolds, stock I-pipe. [Zepher]
Clip Eight, Clip Nine - LT1 shortblock, LT4 heads with 10.8 compression, comp cams 224/230 "XR" roller, Holley 650 double pumper on top of a GMPP LT4 intake, Hedman LT hedders with dual 3 inch 40 series flowmaster exhaust. [f-crazy]
Clip Ten-Hooker comps, no cat, and 2 chamber 40 series. L98 with crane 268 cam. [3rdgenZ]
Clip Eleven-Heddman shorty headers and y pipe, no cat and FlowMaster 3" cat back with a series 30 muffler. [5speed]
[Flowtech]
Clip One - 305 LG4, edelbrock open elem, high-flow cat [BDK]
[GMMG]
Clip One - 350 SLP 1 3/4" ceramic coated headers, custom 2.5" y pipe, 3" catco cat into the 3" GMMG catback [Justin89Formy]
Clip Two - 350 SLP 1 3/4" ceramic coated headers, custom 2.5" y pipe, 3" catco cat into the 3" GMMG catback [Justin89Formy]
Clip Three - 350 SLP 1 3/4" ceramic coated headers, custom 2.5" y pipe, 3" catco cat into the 3" GMMG catback [Justin89Formy]
Clip Four - 350 SLP 1 3/4" ceramic coated headers, custom 2.5" y pipe, 3" catco cat into the 3" GMMG catback [Justin89Formy]
[Hooker]
Clip One, Clip Five - 10:1 compression 355 with Dart heads, Edelbrock performer RPM roller cam, Edelbrock performer RPM intake, Holley 650 double pumper, Full MSD ignition, Hooker Supercomp shorties, 3inch Hooker Supercomp catback. [f355bird]
Clip Two - 350, hooker long tubes, 3" ypipe and a hooker aerochamber. [fb305svs]
Clip Three - Carbed 350, Hedman Long tubes to an "off road" y-pipe (custom), 3" hooker Aerochamber cat-back with magnaflow tips. [speedingpenguin]
Clip Four - Minirammed 385 CID.[ws6transam]
Clip Five - Minirammed 385 CID.[ws6transam]
[Magnaflow]
Clip One - 385 ci- Holley Stealth Ram, Accel 58mm throttle body, edelbrock tes headers, 3" Magnaflow catback. [89formula350b2l]
Clip Two - 385 ci- Holley Stealth Ram, Accel 58mm throttle body, edelbrock tes headers, 3" Magnaflow catback. [89formula350b2l]
Clip One - A4 LB9, Comp Cams 12-262-4. [roachjuice]
Clip Two - A4 LB9, Comp Cams 12-262-4. [roachjuice]
[Moroso Spiral Flow]
Clip One - 383, Hooker LTs, true dual 3", and turndowns before rear. [SnkSknrZ28]
[Nascar Boom Tubes]
Clip One - 89 IROC T56 Twin Turbo [askulte] -> His thread
Video [askulte]
[Pacesetter]
Clip One - 305LG4 with 87+ TPI heads 87TPI converted to Speed Density, Crane Cams 2050 Camshaft, SLP Dual CAI, MSD 6A, Heddman Shorty headers, custom y-pipe, 3" Cat, 3" Pacesetter Stainless Steel Cat Back. [Zepher]
[Powerstick single chambered tube]
Clip One - 350 TPI, hooker shorties/y pipe [Orr89RocZ]
[Ravin]
Clip One, Clip Two, Clip Three, Clip Four - L98, Ravin Catback. [MetalliCamaroRS]
Clip Five, Clip Six, Clip Seven, Clip Eight, Clip Nine, Clip Ten - L98, Hooker 2055's, LT1 intake, 52mm Holley Throttle Body. [MetalliCamaroRS]
[SLP Loudmouth]
Clip One - 305 TPI, blue racer cam, edelbrock TES headers, stock 3" cat, and the loudmouth cat back with a 16" dynomax bullet muffler. [Member Unknown]
[Spintech]
Clip One - 350, Edelbrock shorties, spintech pro shootout, 3 inch single dumping under rear seat. [EvilCartman]
Clip Three - Holley 650 DP, Pro Topline Vortec Heads, Crane Powermax 2031 208°/214°, Comp Cams Pushrods, Comp Cams 1.6 Magnum Roller Rockers, Hedman Hedders with Y-Pipe, 3" Spintech Exhaust (4441 muffler). [Nebu]
Dead link? Want to post your clip? PM me and i'll post it up.
sweet_87_iroc
Sep 25, 2015 10:01 PM
db057
Aug 22, 2015 08:17 PM
midias
Aug 22, 2015 01:42 AM
89lsc
Aug 14, 2015 04:58 PM
gta power
Aug 13, 2015 06:15 AM
