Damage estimate?
Car: 87 Iroc (summer only)
Engine: 5.0 TPI
Transmission: 5 speed
Damage estimate?
Hey all, my iroc suffered some body damage the other day. I am putting the car away for the winter, but I am trying to see how much I will need to save up to get her fixed in the spring. Thanks for the input.
damaged iroc
damaged iroc
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Fender= $100
Shop shouldn't charge more than $300 to paint and blend it. Maybe they'd fill that gouge for free.
Engine: 5.0 TPI
Thanks. That is cheaper than i thought. Rim came flying off while I was driving. I was in the process of pulling over to fix it too.
This is how the other side looks:
Ronal profile if above pic doesn't work
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
i would go with a new fender install it yourself if posible. and then local paint shop for a paint job.. 300 ish
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
go to your local PAP and see if you can find a pas side GFX, im sure they will let it go for around 50 or so bucks, maybe less
Engine: 5.0 TPI
Originally posted by 911rsq
Looks like we are in the same boat.....
We'll just have to bring our cars back better than before...Member
Car: 88 TA
Engine: TBI 5.7
same happend to the owner of my car the previus owner damaged both fenders the hood the nose radiator core suport driver side headlight ***. he got a $5600 estimate and I bought it for 1000 and I put 500 in parts now i just need to get the car painted. not to bad seeing when i got the car it had 70K miles and runs like a champ. sorry no pics
Engine: 5.0 TPI
Any suggeestions on where I can pick up a new fender?
no green
Jan 9, 2016 09:22 PM
TheCardinal
Interior Parts Wanted
Oct 9, 2015 09:43 PM
