project update
Old Oct 3, 2005 | 10:15 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
project update
Well ere is my next project. I bought the 91 RS Convertable back in may and it sat for 4 years with the back window broken out. So far the only bad rust on this car is the passenger side wheel well has a hole the size of my fist and the driver side front floor board is becoming soft other than that it seems to be pretty solid SURPRIZINGLY. The seats were grey leather but the rear seats are in my opinion junk. The carpet was still soaked with water and mold when I took it out after sitting in my garage since may with the top down. As for my plans for the car is to repaint it maroon inside and out, I have a fresh engine here on the stand waiting to go in, totally rebuild the suspension and add lowering springs, 4th gen leather seats, new carpet, and for wheels I am thinking on something like the BOZE wheels like what Kandied91Z had on his car. And here are the pics. In the third pic you can see where it had a new clip put on.
Old Oct 3, 2005 | 10:16 PM
AaronIROCZ's Avatar
pic2
AaronIROCZ's Avatar
pic3
Old Oct 4, 2005 | 11:07 AM
911rsq's Avatar
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
Looks good man..... You might want to make sure that the front end is squared up before proceding too far.....
I bought one like that with the front end "replaced" on one side and it was WAAAAAAAAAAAYYYY out......
Good Luck !!!!
Old Oct 4, 2005 | 12:59 PM
AaronIROCZ's Avatar
That is my next step after I get it all apart
Old Oct 4, 2005 | 11:29 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
i wish i had a place to take my car down nothing and restore it. one day
Old Oct 4, 2005 | 11:51 PM
911rsq's Avatar
Transmission: yes
The spot that gave it away on my car was right behind the heater box in the engine compartment. There was a HUGE ripple in the sheet metal that was hidden by the box. There is a factory bend there, but this was obviously wrong.
I can see in that third pic that there is a bend there, but I can't tell if it looks like the factory bend or if it is what like happened on mine......
Old Oct 5, 2005 | 07:59 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Ya deff have it checked out. Looks like a great start and should be awesome when done.
I picked up a 91RS vert to use for parts and it didnt look THQAT bad untill I pulled the int. and carpet.
found the floor wrippled all the way back to the center console area
http://www.cecoatings.com/images/Car...3/DSC00327.JPG
cut it up for parts. used em all to make my Z a vert now.
Old Oct 5, 2005 | 10:28 PM
AaronIROCZ's Avatar
So far everything is checking out ok. Till I got a hold of my weatherstripping that seals the top on top of the windsheild, I was carefully loosening it and then it tore in to. Now hopefully hawks still has one left or I am in for a long extensive search for one.
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
mattcanty
Oct 12, 2015 11:08 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
