MAF screens
Old Nov 12, 2001 | 09:23 PM
britered86transam's Avatar
MAF screens
hey will i have any problems if i remove my MAF screens?
Old Nov 12, 2001 | 09:30 PM
breathment's Avatar
hmm, u will if ur MAF stops working.. SOme people have reported their MAF's stop working, some say that if u remove the front screen the air flow isn't as smooth and wont go through the sensor correctly. others say nothing has happend at all. I just took off the screen after the sensor, and left the air cleaner side screen on, i noticed maybe a little difference at higher RPMS.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Old Nov 12, 2001 | 09:35 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
You might have a problem removing the screens. I did this with my car and I had a code 34 pop up. My car didnt run all that good either. The engine is designed to have the screens there, so I would not recommend removing the screens. Some people dont have a problem with the screens removed, but some do like I did. Really not worth it to me, as you might have to buy a new one if you have a problem. 300 bucks. OUCH!!!!!!
1989 iroc-z 350 TPI, auto trans, leather int. t-tops, edelbrock headers and cat back system, SLP cam, crane double roller chain, 4 wheel disc, and aftermarket hood. Iroc-z's forever, Ford Mustangs NEVER
Old Nov 12, 2001 | 09:36 PM
so whut happens if the MAF stops working?
and i should leave the screen rihgt before the filter on and take off the screen closest to the plenum.....i have an 86 tpi trans am
Mark_ZZ3
May 24, 2018 01:02 PM
racereese
Oct 3, 2015 03:46 PM
Eric-86sc
Sep 28, 2015 11:37 AM
Shane87irocz
Sep 22, 2015 06:21 PM
