How to on SCV 4th gen in 3rd Gen
Old Nov 21, 2005 | 11:47 AM
1fastformula's Avatar
Car: 1989 Formula 350 / 2000 Lightning
Engine: GM HO 350 Crate (Vortec headed w/TPI) / SC 5.4 330
Transmission: Rebuilt 700R4 (Raptor Rebuild Kit)
Here is a how to on getting the scv to work with your third gen......
First thing is to solder a jumper wire to the correct pin on the back of the radio....Very easy to do:
The 16th one on the connector. You can tell by the numbered rows labeled by GM on the connector.
Then you need to get your ECM from out of the passenger side dash area and unplug the black connector (VSS buffer) from the yellow harness mounted on the ECM. Find the green wire with the black stripe and connect another wire (long enough to reach your radio bay) to it:
In the pic above I was going to solder the wire to the connector, but solder will not stick to aluminum . So I ended up using the blue wire connector (the one that crimps and connects wire to existing wire) to connect the wire.
Plug the connector back in and reinstall the ECM.
Now get the wire you connected and ran to the radio bay and connect to the jumper wire that is on the radio:
Install radio and go for a test drive.....Pretty damn nice huh??
Here is the radio all done:
I think this would be a pretty good tech article add on...Whatcha think mods
Later
Old Nov 21, 2005 | 11:31 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Re: How to on SCV 4th gen in 3rd Gen
Later
I agree, but I'm no mod. I bet a lot of the people who like to stick with a dead stock appearance would like to know how to get better late model decks to function 100%
Old Nov 22, 2005 | 12:34 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
why did you not go with a cd deck?
Old Nov 22, 2005 | 12:54 PM
2 Reasons....
1. Wanted to go with the Nostalgic Tape Deck look.
And 2.
18.00 Shipped on EBAY
Gotta love it
BTW...I have SIRIUS sat radio also...so really no need for the CD deck.
Later
Old Nov 23, 2005 | 11:55 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
I feel so stupid and tired. But what is scv?
Old Nov 24, 2005 | 01:53 AM
Crayz9000's Avatar
Car: '86 IROC, '87 Volvo 240, '09 Malibu
Engine: LB9 5.0L
Speed Controlled Volume. It was a feature on later 4th gen Delco radios that took advantage of the 4L60E's speed sensor to increase the volume as you drove faster, and vice versa.
Old Dec 23, 2005 | 06:57 PM
redcamz's Avatar
Car: 84 camaro z28
Engine: 305 H.O.
Transmission: 5 speed
hey crayz, so would that work on a 5 speed trans and not an automatic???? i am thinking of purchasing a later delco model with the svc, it would be nice if it works. thanks
Old Dec 23, 2005 | 08:00 PM
MasterEvilAce's Avatar
It works on the M6's too...
Old Jan 24, 2006 | 12:00 AM
redcamz's Avatar
Car: 84 camaro z28
Engine: 305 H.O.
hey 1fastformula, i saw your pic on how to get the green wire with the black strip, but on my 84 ECM there a 4 different harnesses attach to it, and i just did not know which one, and seems like there are no green and black wire, i have 2 harness attach to the side of the ECM and 2 that are directly plug into the ECM. i will try to get a picture later, any help would be aprreciated. i just purchase the later delco radio with the svc. thanks.
Old Aug 29, 2006 | 09:13 AM
Winger4800's Avatar
Car: 2003 Corvette
Transmission: one that has 6 speeds
Will all delco cd decks plug right in to the existing radio harness????
Old Aug 29, 2006 | 09:18 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
That sounds horribly obnoxious.
Old Sep 3, 2006 | 12:58 PM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
if you have any sort of exhaust system, or windows down/t-tops off... it comes in handy..
I had a Pioneer with that, and it did not work VERY GOOD AT ALL, compared to the Delco deck in my friend's 2000 Camaro.... VSS is definitely the way to go... as my Pioneer used a microphone, and I could never get it to work quite right...
what's funny is the new high-end Pioneers don't have it anymore because it was a joke
Warlocksirix
Sep 3, 2015 12:26 PM
cam-mike
Aug 24, 2015 07:23 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
jbd1969
Aug 17, 2015 07:06 PM
