In-line fuel pump pics??
Does anyone have a good photo of an in-line [external] fuel pump installation? Something that shows the location and the brackets/mounting hardware and fuel lines etc??
Here is my Aeromotive A1000. Its bolted to the side of the spare tire well. The second filter could be inline, just like the pre-filter, but I wanted to keep it as far from the exhaust that I could. The second filter is mounted to the trunk bottom, about 10 oclock in the pic.
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Did you sump the tank ? I need to convert to external one aswell . I am sick of the intank one and need a bigger one for the new turbo setup.
Great pics !
Great pics !
Great pics !
Great pics !
Car: 1989 IROC-Z
Now that was a description ! I really appreciate that ! Hopefully alot get to see this post .... sounds like what I am looking for !
Glad I can help. Just wish I had some pics though. This was the ONLY alternative for me, as I did not want to go with a fuel cell, and its not practical to sump the bottom of the fuel tank, because of the exhaust crossover. If you go this route, refer to your old intank assembly, so you can bend the new 5/8 line exactly like the original. When I ordered the two ft long 5/8 stainless line, I told ClassicTubes what I was doing, and they even AN flared, and put a female fitting on the line, as I did not have an AN flare tool as yet. AN flares are at a differnt angle.
If you ever look in a Jegs catalog, in the Mustang section, they have an intank assembly you can already buy that you can just drop right in a Mustang tank. If you do yours this way, thats basically what youll end up with.
Car: 1989 IROC-Z
what do yuo think of the Aeromotive A1000 . I have benn lookngi at it . Noisy ? Some others here didn;t like the aermotive stuff.
Car: 1989 IROC-Z
You got any recomendations ? Other than the A1000? Just getting a feal for brand names . I need the flow that the A1000 provides for the boosted setup next year
Car: 2000 BMW M5
Not true on the noisy pumps being the only choice. I have a Walbro and it is as quiet as a stock in tank pump. It is a very very quiet inline. Solid mounting makes loud pumps way worse too -- isolating does help.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Twin Walbro 255's should do fine for 600hp and you can keep them in the tank. about $160 -200 for the pair.
We put a pair in my friends 95 Supra with a T78 turbo kit.
Car: 87 IROC - 67 Camaro
Engine: 383 TPI - ZZ4 TPI
Transmission: 700R4 in both cars
Axle/Gears: 3.27 - 3.36 posi in both cars
PerthZ28:
The pump is a Bosch good for up to 550HP. It's mounted in my 67' Camaro 18" from the tank under the trunk. I had no choice in using a in-line because there is no room in a 67' Camaro fuel tank. It's been working fine for 6 years and app. 75000 miles. I have a stock ZZ4-TPI with the fuel pressure set to 50 lbs. My car is a daily driver.
A good rule of thumb with in-lines is to mount them close to the tank because in-line fuel pumps are better pushers than pullers.
Car: 82 Ponitac Firebird
Transmission: 4L60e/TCI TCU
Hi,
My 1982 Firebird has been running an inline pump since the engine was first put in back in 98. The pump is mounted in the area where the fuel filter is located. The pump is the same type of pump that is used inside of the tank. Its rated for 75PSI. I have never had a problem with the pump!
Not a good idea, in fact that's a very bad idea. Your new pump would have to pull gas through your old dead pump in the tank. Won't work!!!
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
