amp
Old Jan 11, 2006 | 06:36 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
amp
price is really not the issue...but not over 300 bux ill say...i donno....they are punch one series subs from rockford fosgate....have two 12...need one amp to power them...dont need no crazy insane bass...but it has to hit...and hit hard...
thanx if ya cna help
Old Jan 11, 2006 | 11:25 PM
1991 RS/SS's Avatar
Car: 1991 Camaro RS
Engine: 383 LT1
Axle/Gears: 4.10
The RMS power handling on those is 150 watts each. I need to know the impedance (ohms) of the sub for anybody to make a proper recommendation.
Old Jan 12, 2006 | 05:59 PM
Charged350's Avatar
Car: 87 IROC Z28
i dont have any paper work for them...wouldt it be on the sub itself sumwhere....but my cuz had only one of them hooked up to a 750 watt sony amp...sounded mean....
Old Jan 12, 2006 | 10:09 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
A bunch of things. First, you have this thread going in two spots. Give people some time to get back to you.
Here's your other thread: https://www.thirdgen.org/techbb2/sho...hreadid=340218
[/rant]
Anyway, the reason why both 1991 RS/SS and I asked about the sub's impendence is because we want to help you choose the best amp for your application. All amps are stable down to a certain load but that load varies with amp. Most are 2 ohm stable some are 1 ohm stable. Check out the bottom of the woofer and the sticker on the motor should tell you something (look for either a 2 or a 4).
If your subs are 2 ohm woofers then you can wire for either 1 or 4 ohms. If they’re 4 ohm you can wire for either 2 or 8. Your best bet is going to be to wire as low as possible, but again not all amps are 1 ohm stable.
Here are a few sub $200 amps that will put out more than enough power to pound your subs to their demise if you so choose.
http://www.ikesound.com/product-product_id/2821
http://www.ikesound.com/product-product_id/2307
http://www.ikesound.com/product-product_id/3918
None of those are top of the line but then again you’re not looking for that much power output, especially if you were satisfied with your friend’s sony amp. Any of those amps I just linked to will kick the poop out of it. Sony is overrated junk that can’t put out half of its rated power.
Honestly, go out and pick up a cheap amp. Any of those amps is overkill for your application.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
