ATTN: All 305 TPI supercharger owners. What RPM do you shift at?
Old Mar 10, 2001 | 02:21 PM
theformula's Avatar
I have all stock internals. (stock intake,stock heads, stock cam, stock pistons).
What RPMS do you guys with stock internals usually shift at???
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL (5200rpm limit),Holley 9mm wires,Ac delco R43ts plugs,stock chip,Ford SVO 24# injectors,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Mar 10, 2001 | 05:26 PM
daverr's Avatar
i would shift it at a max 5500-6000
rpm.because u might risk floating a valve at any higher rev.its even worse with boost.
i shift my n/a 305 tpi at 5000 and run 15.2 i tried shifting it higher i barely gained anything to be worth it.
dave
Old Mar 11, 2001 | 12:57 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
If you want to keep that SN92together you better be shifting before 5000 RPM.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
My IROC-Z
EFI Performance Club on Yahoo
Club IROC-Z
Old Mar 11, 2001 | 04:30 PM
Tadder's Avatar
I had the same combo and I shifted at 5000 rpms. I tried to go higher but I did not gain anything. I was running 7lbs. of boost.
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
Armored91Camaro
DIY PROM
Aug 12, 2015 09:41 AM
drathaar907
Aug 6, 2015 04:20 PM
