New way to do ZIF'd MemCals ...
Old Sep 9, 2001 | 12:39 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
No hacking, no soldering, no worry about overusing your ECMs socket (or your MemCal's socket, or your MemCal Adapter's socket).
I thought about this a long time ago but kept forgetting to try it. Today I did and I am glad that I did. Simply put, I combined a low profile ZIF socket and a MemCal Adapter. I don't have any pictures of the finished piece but I combined the following two parts ....
Low Profile ZIF
MemCal Adapter
This specific low profile ZIF presses right into the MemCal adapter and creates a nice tight connection. I used some hot glue as an extra means of ensuring that they don't separate but they hook up well without the hot glue. Press this new adapter (along with the attached MemCal) into the ECM's socket and BAM ... quick, easy ZIF'd adapter with no soldering, no hacking of the stock MemCal and no worry of overusing the ECM's socket. Takes all of a couple minutes to make and it works great. The height of the ERPOM installed in the ZIF is the SAME height as the MemCal installed on the adapter. Its very compact.
Little things ....
1) You'll need to remove the *white* ECM socket clip (not the blue one). Comes out easy with the use of a small screwdriver.
2) Its a tight fit in the ECM but this tight fit also helps to keep the ZIF in place when inserting and removing EPROMs.
3) Although this assembly is very compact the top cover to the ECM still cannot be installed due to that single depression in the middle of the cover. I am going to modify that depression so that the cover can be easily reinstalled.
4) This is for a 730 ECM. Should work with a 165 but I can't say for sure.
Why did I do this? Well, I really like the MemCal adapter approach because it requires no soldering and no hacking of the MemCal. However, this approach requires you to remove the adapter from the ECM every time you want to do a reprogram. This overuses the ECMs socket and eventually wears it out. This new method combines the best of both worlds.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
[This message has been edited by TRAXION (edited September 09, 2001).]
Old Sep 9, 2001 | 02:10 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Axle/Gears: 3.23 Dana 44
That would work but the problem is most people don't have the JET memcal adapter.
Luke
1989 Iroc-Z Blue T-Tops
Lightly Moded:
Headers, Rebuilt B&M 700R-4 tranny, Airfoil, K&N's
Old Sep 9, 2001 | 05:33 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">
[/B]</font>
So long as the ZIF is narrow enough to clear the side of the case.
Old Sep 9, 2001 | 06:35 PM
TRAXION's Avatar
Bruce,
Yeeeeeeup. Works perfectly. With this specific low profile ZIF in place the MemCal adapter's overall width is the same. I can't believe how beautifully this works. Really does seem to be the best of all worlds. I need to get a picture ....
Tim
Old Sep 9, 2001 | 06:42 PM
JERRYWHO's Avatar
TRAXION
Can you give us a part number for the ZIF you found.
Your quote:
I found a company that sells the MemCal adapter for $9.00 so i ordered 5 of them now i just need the ZIF.
Thanks for your help
Jerry
Old Sep 9, 2001 | 07:59 PM
jnjspdshop's Avatar
Would you care to share the place where I can purchase the Memcal adapters for $9.00
Jason "TrickFlow" Zajac
JnJSpdShop@aol.com
Old Sep 9, 2001 | 08:04 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
I'd be in on a GP of memcal adapters for $9 apiece.
Old Sep 9, 2001 | 09:02 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
I'd like to see the picture of your new invention. Allways looking for ways to build a better mousetrap!!
Those low-profile ZIF sockets are junk IMO. Or should I say cheap. I got 2 from Digikey, and both had bridged sockets on both sides of the ZIF. I found that out the hard way. I also had one fail right in my ECM, on a hot day this summer. Good thing I kept my original memcal, with a very low profile 28 pin socket soldered in, as a spare. I use the ZIF socket in my ADS memcal that I have. I'm on my second ZIF now, it seems to be holding up. I'd be looking for a better quality ZIF.
Best ET 14.413 @95.57 without
pulling valve covers or manifolds.
Also with stock 2.77 rear end!!!
Old Sep 9, 2001 | 10:17 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
<font face="Verdana, Arial" size="2">Originally posted by MikeT 88IROC350:
</font>
The Low Profile ZIF sockets are not junk, there just very small so they are fragile. If you want a better quality ZIP don't get a low profile one. The only down side to this is that you have to leave the MemCal adapter cover on the computer case off. Here are some links.
Low Profile (fragile) ZIF socket:
http://www.jameco.com/cgi-bin/ncomme...&search=102744
Big Stronger ZIF socket:
http://www.jameco.com/cgi-bin/ncomme...&search=104002
Lightly Moded:
Old Sep 9, 2001 | 10:27 PM
TRAXION's Avatar
Mike,
1) You indicated that one failed while in your ECM. How? What happened to it?
2) Bridged pins on both sides? Holy cow. I haven't had that problem with any of the ones that I obtained from Digikey. Hmmmm. Maybe a bad batch?
3) Based on what you said, I totally cracked open one of these specific Low Profile ZIFs and examined its insides (its guts). Looks AOK to me. Scratch one extra ZIF socket that I use to have
Tim
Old Sep 10, 2001 | 09:27 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
<font face="Verdana, Arial" size="2">Originally posted by JERRYWHO:
Jerry
</font>
Yes, please tell us who this company is. I think there would be a number of people interested in organizing a group purchase.
[This message has been edited by Glenn91L98GTA (edited September 10, 2001).]
Old Sep 10, 2001 | 04:24 PM
Sarkee's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Glenn91L98GTA:
Yes, please tell us who this company is. I think there would be a number of people interested in organizing a group purchase.</font>
I'm interested! Put me down for two! (I'm good for it!)
Old Sep 10, 2001 | 04:29 PM
Sarkee's Avatar
<font face="Verdana, Arial" size="2">Originally posted by TRAXION:
With this specific low profile ZIF in place the MemCal adapter's overall width is the same.</font>
Tim -
If the width is the same, then why need to remove white retaining clip? For the ZIF lever? (Why not mount lever in middle?)
Old Sep 10, 2001 | 09:43 PM
Car: 1988 IROC-Z
My very first ZIF was soldering into an ADS memcal. When I burned my first ever prom, I got a solid SES and car would barely run. First I thought bad burn/chip. I then got the same results with the ADS chip as well as the stock GM chip. So I pulled the memcal and took a good look at the ZIF socket. There were 4 sockets on one side, and 2 on the other that were shorted all togethor. I am talking about the top little metal sockets that squeeze togethor when you push the lever. I guess it was a manufacturing defect. I fixed it easily with an exacto knife.
The second failure was actually ocurred when my car sat in the parking lot at work. It was a fairly hot day, and when I attempted to start the car, it would barely run, and SES light. I just pulled the memcal and stuck in my backup, with a GM chip. It ran fine. The short this time was under the ZIF socket itself, on the PCB. I think I concluded that the glue I used got warm and created a short between 2 traces on the PCB. I ruined the ZIF removing it, but the other ZIF that I bought also had some bridges across the sockets. I used a different glue to hold that one down. No failures so far.
I like the ZIF for easy chip changes. I trimmed it down nicely so the clip on the end would latch. The cover for the ECM also fits nicely.
As far as my OEM memcal, I installed a low-profile 28 pin socket. I could even get the blue cover on with a prom in the socket. I mostly use this as a backup. I will put it in permanent when I get the bin settled down. It just takes a little screwdriver, or chip puller to get the eprom out. Makes a real neat install.
I paid $18.00 for 2 ZIF's and shipping from Digikey. Not worth it IMO. I suppose "fragile" is a better word.
89iroc, I didn't see a pic for the bigger, more robust ZIF that you posted. I would like to see what that looks like.
Old Sep 13, 2001 | 01:03 PM
Warlock's Avatar
so where do you get the jet or similar adapter?
Old Jan 7, 2002 | 11:10 PM
dynastydan's Avatar
memcal adapter
Anyone get a line on the Jet style mem-cal adapters?
Old Jan 8, 2002 | 05:36 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
TTT
Looking for that $9 memcal adaptor......
Old Jan 8, 2002 | 06:58 PM
dynastydan's Avatar
$9 memcal adapter
$9 would be great, but I'd just like to find out who manufactures the piece. Interesting, that the thread stopped when people started asking the important question. Where did you get it.
Dan Plaskett
Old Jan 8, 2002 | 10:16 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Axle/Gears: 9", 4.33:1
I am a little confused here.... I just don't understand what the huge attraction to the ZIF setup is .
Soldering a flash PROM right into a memcal and using an adapter to plug the memcal directly into the burner has got to be the best setup oout there. And soldering and desoldering the legs of the PROM into the memcal is not that hard so the PROM can be replaced if necessary. But really, the lifespan of an EEPROM is extremely long making the actual replacement of the EEPROM on the memcal a non-factor..... So why the big hassle with the ZIFs and adapters?
Old Jan 8, 2002 | 11:00 PM
dynastydan's Avatar
Attraction to Zif setup
I guess part of the attraction is that not everyone uses the pocket programmer and can plug the flash prom into an adapter. I for one use an old Data I/O 201 and 25 eproms so burning chips and plugging them in and out becomes an issue. I've had my memcal in and out at least 50 times. The pocket programmer seems to be a great way to do it, but sometimes you just use what you've got. Also, I don't always want to drive around with the burner, ECM and computer laying around on the floorboard.
Old Jan 9, 2002 | 05:40 AM
Sarkee's Avatar
So why the big hassle with the ZIFs and adapters?[/B]
Eh??? Hassle???
The attraction for me was being able to program several EPROMs at once; put one in, drive it, log the run; put another slightly different in, run, log; compare...
- Not have to return home to change to original configuration when I make a change with unexpected consequences...
I also carry a spare chip w/OEM configuration with me...If I do have a problem, I still have a working chip that I know will not harm anything...
Buying spare MemCals can get expensive...
Old Jan 9, 2002 | 07:30 AM
Craig Moates's Avatar
Car: 87 T/A
So would you guys like me to get some JET-type adapters made also?
Should be easy enough, just need to find a right-angle IDE header long enough to grab the MEMCAL.
Now if someone would please get me that photo of the backside of the JET adapter, we'll get going!
-Craig
Old Jan 9, 2002 | 10:19 AM
poorboy8's Avatar
Car: 79 Camaro RS
Engine: 355, carb, alum heads, XE262
-Craig
That would be awesome Craig.
As for how to get the one like traxion was using, seems like a simple answer to me. Find someone with a Jet chip for your particular car that doenst want it anymore, buy it, remove the jetchip install your own.
Old Jan 9, 2002 | 10:28 AM
Car: Death Mobile
Engine: 666 c.i.
That is about the only practical use I have for those "off-the-shelf" piggy-back eproms. That's exactly what've done with my ADS Superchip - pulled the eprom and re-installed a Flash Prom.
Then I have my Memcal with a known good BIN for a "backup" as you never know when the BIN you just burned turns out bad after some driving.
Old Jan 9, 2002 | 04:32 PM
Sarkee's Avatar
...Yes!!!...
...Yesyesyes!!!...
Old Jan 9, 2002 | 08:33 PM
dynastydan's Avatar
I'd definately be in for that.
Old Jan 9, 2002 | 09:28 PM
Car: 1988 IROC-Z
I second these comments by Sarkee. But Trax's "new and improved" Jet-adaptor is also a good idea, as long as you have one of those adaptors. I wouldn't pay $49 for one, however!!
I have 3 EPROMS that I rotate thru burn cycles. When I have 2 that are used, or not desirable anymore, I just take them into work and erase them on my lunch break, so that I always have some blank PROMS around. If I make a bin that I don't like, I can easily pop out the chip, and put the last bin in. I also keep a spare in the glovebox, just in case. If you are using those trick "flash" Proms, then you might use a different memcal method. You could still have 2 or more chips, for easy swapping, but they do cost a bit more. But since I got my 3 Eproms for free, I won't be changing ove to the EEPROMS very soon.
I think it is best that you leave the MEMCAL installed into the ECM, and change the PROM out using the ZIF's. The less wear and tear on the ecm pins (or memcal) the better. You could always replace the ZIF if needed.
Old Jan 10, 2002 | 11:40 AM
Mojo's Avatar
The JET adapter looks handy. I'm really hamfisted when it comes to soldering, and I'm always having memcal problems.. The question is, how does that thing plug in and keep the limp circuit? Any pics?
Old Jan 10, 2002 | 11:41 AM
Mojo's Avatar
Oh, I think I get it. Where can one be purchased?
Old Jan 10, 2002 | 01:07 PM
TRAXION's Avatar
IMHO the main problem is that you end up wearing out the socket on the ECM and the socket on the MemCal. For EVERY chip burn you need to remove the memcal from the ECM (wear on ECM = 1, wear on memcal = 1) and then burn the new image on the flash prom (wear on ECM still equals 1, wear on memcal now equals 3), and finally put the memcal back into the ECM (wear on ECM = 2, wear on memcal = 4). So - you end up with A LOT of wear and tear that you don't need. When I burn a new image all I have to do is remove the Flash PROM from the ZIF, program it, and then put it back into the ZIF. There is no wear and tear on the ECM or the MemCal. Furthermore, I can carry spare EEPROMs with me and just slap them into the ZIF whenever I want.
Tim
Old Jan 10, 2002 | 06:14 PM
Sarkee's Avatar
Traxion has pics on his site -
http://www.picturetrail.com/gallery/...2145&uid=96398
Right now, everyone seems to be keeping mum on where to buy one...But Craig Moates is working on a similar project...Give him an email and express your interest...
Old Jan 10, 2002 | 10:43 PM
Car: 87 T/A
I want to get some PCBs printed up just like the JET ones in terms of functionality. Also want to get some printed up for just adapting a hacksawed MEMcal cleanly from ECM to ZIF.
I'd like to place the order this week coming up, and get some parts from Digikey for the angle header while I'm at it since I need some other stuff anyhow.
Any questions? If the adapters work, I'll make what's left available to the folks here for whatever the cost might be. It won't be 50 bucks to be sure.
-Craig
Old Jan 11, 2002 | 05:22 AM
Sarkee's Avatar
So, that sounds like you're just making a batch for your own use...
If I could be so bold, when you're done, could you release the source and parts numbers for others who might want to build some for themselves???
Old Jan 11, 2002 | 08:23 AM
KAOSRacing's Avatar
I'm interested in one of the memcal adapters. Just let me know when and how much.
Old Jan 11, 2002 | 11:41 AM
Mojo's Avatar
I'd even be willing to pay the $50... I just need to find a seller! $50 is small potatoes compared to how much I have into the car... I stopped counting around 45k.
Old Jan 11, 2002 | 12:52 PM
Engine: 4.0L
$45,000!!!
On what? And BTW why are you still fooling with the stock computer system after all that cash?
Old Jan 11, 2002 | 03:11 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
So far I've found the best way to get the Jet et.al. adapter is to buy them on eBay. Occasionally you'll find one for about $20. More than I want to pay, but...
Note that some other model ECMs will work for this purpose. I believe that the '95 C/K truck uses a plugin memcal like ours.
Old Jan 11, 2002 | 06:41 PM
Mojo's Avatar
Originally posted by John Millican
$45,000!!!
It's a Vette. Parts are $$. Shoot, I have 4k in the paint, 18k under the hood... Everything has broken at least once. Keep doing it for 10 years and it adds up! That aside, I've upgraded to a '730 from the old '870.
Old Jan 11, 2002 | 09:14 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
I can now believe you:
I've had my ol' 1984 Trans Am for twelve years now: I spent $12K on it in terms of purchase price ($6500) and replacement / parts upgrades, as of 1997. Then in 1999, I spent $2100 on suspension and brakes. Then, in 2000 I spent $2400 on engine upgrades. Then, in 2001, I spent $2600 on wheels and 1LE brakes. Now, for 2002, I already have $4300 into a stroked, Minirammed engine, and I havent yet bought cylinder heads! It'll be a $6500 engine upgrade for sure when I'm done.
So, what's that add up to? ...About $25,000, and it'll still have 17 year old paint...
Old Jan 14, 2002 | 05:07 PM
Matt87GTA's Avatar
Well, in response to those that responded to me on my questioning the usefullness of the ZIF setups:
I guess I can see how it would be nice to have the ZIF when you pull out of the driveway with a handful of different setups to try out. Myself - I keep it to one (well.....) change at a time.... I confuse myself easily .
I can definately see the wear issue coming into play in the long run - especially on the ECM itself..... Pin-fitness definately becomes an issue as the memcal gets older and is installed and removed a bizillion times as well.... I think this is the most compelling point for using the ZIF setups.
As for carrying an extra chip goes, I have two memcals with AT29C256 EEPROMs on them and I rotate them into the ECM (Hey, that cuts the memcal's wear factor in half!! ) as I do mods - always keeping the one I previously was successfully running in the center console as a back-up. I guess buying spare memcals does get expensive.... But you really only need to buy one extra one and they aren't all that expensive..... You can find them around here for under $10 from junkyards and they run about $37 from the dealer if you know someone that works at one (or is sufficiently "hooked up" ).
All in all I guess the ZIF setup is a bit better in the long run.... I kinda wish they would put longer legs on those ZIFs though..... They are a pain to solder....
Old Jan 15, 2002 | 07:47 AM
TRAXION's Avatar
Just slap that ZIF into a hypertech adapter. It press fits fine. Use some hot-glue for some extra piece of mind. This is my preferred setup. You still have the stock memcal, you have an easy install, and you have the benefits of using a ZIF.
Tim
Old Jan 15, 2002 | 10:32 AM
Mojo's Avatar
Trax,
We'd love to use the hypertech adapter. Problem is, nobody seems to know where to buy one!
Old Jan 15, 2002 | 01:45 PM
v8power's Avatar
I am a little confused here about the Adapter how exactly does this thing work?
from the pictures it looks to plug in on the botton of the mem cal now what it wont fit in to the ecm.
second if these adapters are so hard to find. what would be the interest in making them I work for an electronics manufaturing company and I do some board layout and design . for those little boards I can see it costing more than 15 bux to make each
what does the back look like this might clear it up for me I dont see how that thing is useful....
Old Jan 15, 2002 | 01:53 PM
v8power's Avatar
Old Jan 16, 2002 | 11:32 AM
Mojo's Avatar
The underside of the adaptor has the female socket that plugs into the ECM. The memcal and the ZIF plug into the top side that is shown.
Old Jan 16, 2002 | 03:39 PM
v8power's Avatar
so does it fit into the 165 ECM it looks too wide
Old Jan 16, 2002 | 04:26 PM
Sarkee's Avatar
The 165 and 730 (or 727) MemCals are physically identical. The only difference is in the attached chips.
The 730 MemCal I have here (AUJP) also has a small circuit board suspended over the limp-home chips. I'm not sure what that does, but the plastic carrier is the same as the 165.
Old Jan 16, 2002 | 05:10 PM
92Z's Avatar
92Z
I believe the circuit above the limp home chips is the knock module. In '91 and '92 the knock module was put on the memcal instead of a seperate module in the engine compartment.
BTW, I'd also be interested in one of those JET-style memcal adapters.
Old Jan 16, 2002 | 06:39 PM
Car: 87 T/A
So is the MEMcal header pinout the same (in terms of size and pin count) on the 165 and 730s?
And if someone could get me a pic of the underside of the JET or Hypertech adapters, it would be helpful.
Old Jan 16, 2002 | 07:22 PM
JJ63's Avatar
Car: 92 Trans Am
Engine: 350 tpi
Transmission: 5 Speed
You can see a little of the female socket in this picture.
http://www.jetchip.com/domestic/largepic.cfm?pic=chips
