Vortec heads and valve springs
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Many of us are opting for the Vortec heads, some are saying they require a lot of machine work. Well here is a hot tip:
If you get the Manley part# 22410 springs and the part# 23652 retainers you will not have to do any machine work. The retainers add .050 to the stacking height so they will be at 1.780. The spings are 130# at 1.750 requiring a .030 shim and this will give about .040 away from the stock valve seals .
The spring coil binds @ 1.150 so that allows for at least .510 lift. They have 320# open at that lift. Oh, and the bonus, they're reasonable, about $80. And now with the SPCD base available WhaaHoo!
NOTE:
You do need to remove the flat wound dampner and cut one coil off for clearance.
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
Cam change:TRW 198/210 ,450/.460 114 LSA
Stock TBI manifolds
'85 IROC Ex.
14.94-92.00 mph
SPDC base and "350" Vortec coming soon!
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
[This message has been edited by Dyno Don (edited October 21, 2001).]
NOTE:
'92 CAMARO RS
B4C Alt.
Stock TBI manifolds
'85 IROC Ex.
14.94-92.00 mph
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Sure, those are the same springs and retainers I'm running on my car with the LT4 HOT cam and L98 heads. Thats how we found them to work with the Vortec heads.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Car: 94 Z28
Axle/Gears: 3.23s
That last note there, you have to pull out a inner dampner and cut a coil off of said dampner right? Just want to make sure I'm clear. I've been thinking about trying to come up with some setup like this or +.050 locks or something...
84z96L31vortec
Aug 20, 2017 12:16 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
