testing MAF? Please read.
Old Oct 29, 2001 | 08:14 PM
cursedz28's Avatar
my buddy has an 89 iroc that I smashed into a mazda 626. I gave him the front of my car and my Glasstek 4" cowl hood. His air cleaner would not clear the front of the hood so just to get his car on the road I removed it running just the sensor zip tied so it wouldnt hit the belt. It ran fine for a couple of days but now it doesnt run at all. However it doesnt throw any codes. I unplug the MAF and I get code 33 and the car runs fine. Is ther a way to test the MAF or for a short in the connector. I need to fix this I feel like an *** .
Old Oct 29, 2001 | 08:42 PM
Vader's Avatar
Cursed,
You can test the MAF with a DMM if you fabricate your own jumpers or back-probe the weatherpack connector:
The connector for the MAF sensor is as follows:
You'll want to check the signal at the "C" connection, and ground at the "B" connection.
A 350 should show a voltage slightly above those on this 305 at a similar RPM.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Oct 29, 2001 | 08:54 PM
cursedz28's Avatar
thanks fo the pics and schamatic only problem is that the car will run for about 2 second before cutting out. I can not get it to stay running with the MAF plugged in.
Old Oct 29, 2001 | 10:15 PM
Vader's Avatar
Have you tried disconnecting the battery to clear the ECM? It may revert you to the base lookup tables long enough to get running for diagnosis.
Later,
Vader
Old Oct 29, 2001 | 10:29 PM
cursedz28's Avatar
nope. But I will now.
BumpaD82
Feb 26, 2016 02:57 PM
87hellbird
Sep 14, 2015 05:08 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
