77 pontiac 350 in a 88 camaro????
Old Nov 13, 2001 | 12:42 PM
84,86,88Z28's Avatar
what would i need to do this??should everything be just like a chevy 350 basically??thanks alot.
Old Nov 13, 2001 | 01:09 PM
SoCo80p's Avatar
no, you will need to get a adapter kit from jim butler perfromance, also a trans adapter plate, other then that a little rewireing and its a bolt-in.
Old Nov 15, 2001 | 02:25 PM
yea i was wondering what diff wiring i would have to do??also,would a chevy 700r-4 tranny bolt up no problem???thanks
Old Nov 15, 2001 | 05:20 PM
SoCo80p's Avatar
really with the engine its just the alternator location, starter and other little things, mostly just extenting a few wires and what not, not too bad of a challenge, you will need a trans adapter plate, but i do have one if your interested, a TCI unit (best one) used for 2 weeks like new, you can have it including shipping for 50$, let me know if you want it.
Old Nov 20, 2001 | 09:54 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Axle/Gears: 3.23 Posi
200R4 will bolt up to the poncho's. i dont know if the length is different compared to a 700 though. exhaust, i dont have any idea.
Wide Open Till You See *** ...Then Brake
89 T/A Clone
406 in progress
TH700R4 3.42 Posi
Old Nov 21, 2001 | 01:05 PM
Guest
Guest
Posts: n/a
The length of the 200-4r trans is different, although I cant remember if its shorter or longer... I'm thinking its longer.
As for the 350 Poncho, I really wouldnt waste time with that swap. By the time you get all the adapters, make the various little parts work and such, you will still only have a 350, and a heavy one at that. Not to mention the extra cost involved for the parts to do the swap. The 350 chevy is a bolt in and doesnt weigh as much, it will end up costing you less and it wont be any hassle.
Old Nov 21, 2001 | 05:07 PM
well c the problem i have is this,i have 3 camaros,i had a 2.8 in it,and thats what i wanted to put this engine in,just b/c i have it sittin here,but i also have a 350 chevy,i am rebuildin, however,i also have a s-10,2wd and short bed,i want to drop a 350 in,but i figured the chevy would be easier to put in,but i dunno,would anyone want to trade chevy 350 for our my pontiac 350??it has a 4 bbl intake and all on it,just rebuilt,however will need to put new gaskets and seals insince it was never put into ne thing when it was rebuilt.thanks alot for all ur time.
Old Nov 23, 2001 | 12:15 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
a 4bb poncho 350? does it have 6X heads? if so, then you have 350 HO, a rare motor, keep, DO NOT get rid of it, unless the price is right.those motors have a smaller bore than a 400, but use the 400 heads. Because of the valve size, the bores are notched to fit.
$150.00 2.8 Auto.
short block now
turbo eventually, 3.4 may be in the future
USAF-Giving the enemy the oppertunity to die for their country
Old Nov 23, 2001 | 03:57 PM
SoCo80p's Avatar
76' 350 4bbl had the 6x-4 head which was a smogger head, but flowed outstandingly, thats not a 350 HO they were used ONLY on 68-69 tempest customs and firebirds with the 350 HO option which had #18 or #48 heads, both are EXTREAMLY rare.
Old Nov 23, 2001 | 04:04 PM
SoCo80p's Avatar
also you can check to see if it is really a 350 by looking on the block on the driver's side on the engine by the motor mount will be cast right into it eather "350" "400" or "455" if its a 2bbl engine then most likely its a 350, but if its 4bbl you might have a nice piece there
jhawkeye
May 25, 2022 06:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Mutillator
Jan 2, 2016 06:44 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
