fast ratio steering box
Old Nov 24, 2001 | 05:43 PM
Momar's Avatar
I was wondering if someone could tell me how many how many turns the IROC steering box went from stop to stop. Is it possible to tell the ratio by this? If not I have a 85 T/A. It is not the ws6 but it has some sort of performance suspension option under that somewhere. It turns 2.5 turns from lock to lock. Could anyone tell me what it is or if I would be better off with one out of an 87 IROC because I might be able to get a hold of one?
Ben
Old Nov 24, 2001 | 05:54 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
Lock to lock on mine is barely 2 1/4 turns.
'91 RS, 375hp 350
New paint-solid black
ROH Snyper wheels-17x9 wrapped in 275/40/17
ASCD SS hood, High-rise Z-28 spoiler,shaved handles/antenna,
Hooker super comp 1 3/4" headers,dual 3" exhaust,two 1-chamber Flomasters,machined hi-perf GM heads,Holley double pumper 650 w/50cc pumps,Power Plus 360* high rise aluminum intake,Edelbrock Elite valve covers/14x4" open air cleaner,Mallory AFPR,Proform HI-perf HEI disributer with curve kit,Crane 292 cam,Eibach Sportline springs,KYB struts/shocks,completely rebuilt steering linkage,36/24mm sway bars,12.7 steering box,wonderbar,145 gauge cluster,Auto meter gauges,dual guage A-pillar pods,180* thermostat,dual push/pull cooling fans.
75-125 shot NOS system planned.
President-Austin 3rd Gen F-body c.c. - message board at
www.hpsmotorsports.net
See my car and others at www.ride4life.net
Old Nov 24, 2001 | 09:47 PM
DartByU's Avatar
Car: 92 Camaro RS
If I remember right my car turns about 2 1/4 turns lock to lock, and I think my car has the same fast-ratio box as the Z-28's did in 92.
92 Camaro RS 5.0 5-Speed (Quasar Blue)
T-Tops
14" Open Air Cleaner
3.08 Posi-trac
Edelbrock TBI Intake
Crane cam
Ported & polished stock heads 3 angle valve job
HyperTech Chip
UltraFlo cat-back exhaust
74 Dodge Dart Sport 360 (11.2 1/4 mile)
2000 Dodge 1500 Ram Sport
Old Nov 26, 2001 | 09:14 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Momar, does your Firebird T/a have the Y99 suspension option? (It should...) That got you the IROC's WS6 box. I think the F41 option also got the quick ratio box.
There was also an issue mentioned a while ago regarding "wheel size". The theory said (I don't know if it was ever confirmed!) that some boxes had "stops" built in to accomodate larger 16" wheels, which prevented the tires from rubbing the inner fenders on tight turns. Supposedly the 15" boxes don't have such stops. Altho... I thought cars with 16" wheels had less turns lock-to-lock than 2.25, instead of the other way (15" wheels having more than 2.25 turns).
Hey, do you have the casting # from the steering box?
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Nov 26, 2001 | 10:57 AM
Momar's Avatar
I do have y99 and f41 both in my codes. What exactly do they consist of? I do not have the casting number but if needed I can probably just go look at it. My car did origionally have the 15" wheels. I put the 16" wheels off of an 86 T/A on it. If I turn the wheel all of the way it does rub the wheel wells. Also, how did you know that my car should have the y99 option.
Thanks for your help
Ben
Old Nov 26, 2001 | 11:24 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Mine is 3 turns lock to lock, but it is jsut the standard firebird box. I could take a fast ratio box from any year right?
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
"Ponies can run, but birds can fly..."
Amillionoh7
May 24, 2020 08:01 AM
Fast355
Dec 2, 2016 06:33 PM
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
zayne0
Aug 24, 2015 07:22 PM
