Pics of bottles installed in fender wells.
Old Dec 28, 2001 | 06:20 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Transmission: gear jammer
Axle/Gears: 4.11
I got no idea how I'm going to mount the bottle for my n2o. I can't use the trunk b/c I got a battery back there now. Its just a 10# bottle. I didn't think would be that hard.
Old Dec 28, 2001 | 09:50 PM
MouseCamaro305's Avatar
l've never seen a bottle mounted in the fenderwell, l think you mean the spare tire copmpartment, what l think you should do is maybe switch the battery into the spare tire compartment, and mount the bottle in the trunk well. if you mount the bottle in the spare tire compartment it will be difficult to access when you either need to exchange bottles, or get that one filled. the battery is less of a maintenance item and can stay in there for months on end, if you do decide to put the battery in there, make sure the area is well ventilated and the battery is mounted well to keep it away from being shocked and damaged.
Old Dec 29, 2001 | 11:59 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
he is right about the mounting scheme of putting the battery in the spare tire well and the bottle in the drivers side similar compartment. it is the most ideal from a weight transfer point of view. I found from expirience that an opposite arangement was more practical on the 1985 I used to have. the bottle in the spare tire well (because it has to go in and out all the time) with its larger opening. and the battery (which did not need to be messed with) in the less accessable driverside compartment.
Old Dec 30, 2001 | 11:15 AM
Free Bird's Avatar
Axle/Gears: 4.11
How did you mount your battery? I got a battery box from Summit. It won't fit in those side compartments.
Old Dec 31, 2001 | 01:32 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I broke the rules for sleeper perposes, I got a fake (just empty) demonstration battery from a parts house and put it up front just for looks (and it gives me a spot for jumpstarts/charging and mounted an optima in the previously mentioned area with a simple battery tray. you must remove that whole portion of the interior and then reinstall it, thats why I went with an optima.
Old Dec 31, 2001 | 02:22 PM
Free Bird's Avatar
Axle/Gears: 4.11
I was thinking of gutting a battery and putting my silonoides there.
Old Dec 31, 2001 | 02:55 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
now your thinkin' my way
tecustomz
Aug 16, 2015 02:28 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
kyleb24
Aug 15, 2015 08:24 AM
fonzie85
Aug 13, 2015 11:50 AM
sonu1975
Aug 11, 2015 08:38 AM
