Bottle Placement
Old Jan 14, 2002 | 07:20 PM
HotZ's Avatar
Bottle Placement
I have a question about mounting the bottle in the spare tirewell. People say the I wont be able to get to the open and close valve. If this is right could I just put a remote bottle valve opener on it so I wouldnt have to worry about it? Any help you guys can give me would be greatly appreciated.
thanks in advance.
Old Jan 14, 2002 | 09:55 PM
Omar's Avatar
You can open and close your bottle, but it just means you will have to get out of your car to do it. Either that, or crawl onto your back seat and reach over.
Yes, you can purchase a remote bottle opener, and open the bottle from the comfort of your own seat. If you use NOS' remote bottle opener, it is basically a solenoid. The negative is that some people have reported slow leakage. I use it and I have ZERO leaks. Maybe they didnt seal it correctly? I dont know.
NX makes an actual bottle opener. It replaces the wheel on the bottle, and using a motor, it actually opens and closes the bottle. The negative to this? If you use a bottle heater, such as the one made by NX, that relies on bottle pressure, you will be in trouble. However, if you use NOS' bottle heater, which relies on temperature, then it wont matter.
Decisions to make.....
Old Jan 15, 2002 | 06:25 PM
HotZ's Avatar
thanks. anyone have anything else to add?
Old Jan 15, 2002 | 06:48 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
Mine is mounted in the spare tire well.
NX has a new valve that allows the use of the pressure transducer for their bottle heater when the valve is open or closed. Or as mentioned you could use a temperature switched heater instead of a pressure switched heater.
The "leakage" problem with the solenoid type remote valves is not around the fittings, but is slow leakage past the internal seals in the solenoid. If you close the manual (actual) bottle valve off at night, or when not using the system for a long time, and only use the solenoid valve for short term on/off modes, then that is not a problem. The longer you leave pressure on the solenoids, the harder it is on them and the more they will bleed off, whether at the bottle for bottle valving, or at the engine to control system activation. Used at the bottle, they can also be an added flow restriction for high HP aplications.
Old Jan 15, 2002 | 07:18 PM
HotZ's Avatar
How do you like your bottle mounted in the spare tire well? What kind of kit do you have? Is your kit hidden?
Old Jan 15, 2002 | 11:10 PM
IROCKZ4me's Avatar
Works good for me. No one can see it so they don't suspect anything. I have kept the car stock looking from the outside, with the exception of subwoofers & amps and digital dash & pod gauges the interior is stock looking too. The amps & subs didn't leave much room for a bottle anywhere but the spare tire well but I would have put it there no matter what anyway.
Nitrous Express
Is your kit hidden?
Just on the surface. I didn't bother hiding the under hood stuff on this car. By the time anybody is looking under the hood they can tell it's not exactly stock anyhow, and they have probably already seen it doesn't run like stock. It would be easy enough to hide the under hood nitrous parts though, just a couple of solenoids, and a nozzle.
Old Jan 15, 2002 | 11:53 PM
Xtreme Racer 86's Avatar
Car: 1986 Trans Am
Engine: 383 Stroker
Transmission: TH700R4
I was going to mount my nitrous bottle in the spare tire compartment, but I eventually went with the dip behind the gas tank, the only bad thing is that you have no room for any storage or speakers if you want to throw in a subwoofer. I have the GM EFI wet system from NOS. If you can get it in the spare tire compartment go for it, I just hear that its a pain in the @$$ to mount it there
What supercharger did you go with? The only one that I know that will work with an 86tpi is the paxton., do you know of any others that will work if you still have the stock ECM and MAF??
Old Jan 16, 2002 | 12:51 AM
IROCKZ4me's Avatar
Paxton SN92-HO
It's not an issue with the MAF or ECM. It's an issue with the accessory drivebelt and mount system.
The '88-'92 had a single serpentine belt, and different accessory mounting locations & brackets.
You can use any kit (Paxton, Procharger, Vortech, etc) designed for the '88-'92 on a '85-'87 if you retrofit the later style accessory system onto the engine.
Old Jan 16, 2002 | 04:07 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
What makes you say that? Pressure keeps the solenoids closed, they have to open against pressure.
Old Jan 16, 2002 | 11:44 AM
BahamutRS's Avatar
My friend had his bottle mounted between the rear seats, but then again, he didn't care if anyone saw it. Other than that, I'd say the dip in the trunk, but then it sucks if you want subs.
Old Jan 16, 2002 | 08:23 PM
IROCKZ4me's Avatar
originall posted by Apeiron:
Exactly.
Continuous long term (over)exposure to the pressure causes (over time) the same type of damage (distortion) to the seals that short term over-pressurization does. This seal distortion can restrict nitrous flow when the solenoid is open and can cause an excessively rich condition and surging. It can also cause the solenoid to act "sticky" and not open and close as quickly or completely. Closing the bottle valve between uses (and then purging the line is a good idea) will lengthen the life of the seals.
Old Jan 18, 2002 | 12:57 AM
Car: 1986 Trans Am
Engine: 383 Stroker
IROCKZ4ME is changing the accesories and belts hard to do? is it something you can do yourself or is it best to leave it up to a shop. I have decent knowledge of my car, but I'm no ASE mechanic. Also what is your opinion on getting a supercharger? Do you like paxton, vortech, ATI?
By the way, you have an awesome ride.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
dusterbd
Sep 29, 2015 08:40 AM
Fox118
Sep 1, 2015 04:07 PM
ken3983
Aug 23, 2015 07:31 PM
