What else used the GM 7.5" 10-BOLT?
Car: 05 GTO, 88 GTA, 98 SS
What other car or truck had this rearend? I want to find some 3.73 gears at a junkyard for cheap. I'll be looking for the 41-11 stamping right? I've heard Blazers and S-10s had the rearend. What should I be looking for exactly? (these gears will be for my 91 Camaro) Thanks!
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
You can find 3.73's in Astro vans...and very rare 4.10's.
The entire rear end won't fit because it doesn't have the torque arm mount and the diff is 4" offset to the passenger side. But the gears will.
Here's some axle codes.
FMA: 7.5", 3.42 open (1985-1987 Astro)
FMB: 7.5", 3.42 posi (1985-1986 Astro)
FRA: 7.5", 3.73 open (1985-1987 Astro)
FRB: 7.5", 3.73 posi (1985-1986 Astro)
FSA: 7.5", 4.11 open (1985-1986 Astro)
FSD: 7.5", 4.11 posi (1985-1986 Astro)
PZK: 7.625", 4.10 open (1990 Astro)
PZL: 7.625", 4.10 posi (1990 Astro)
RHN: 7.625", 3.73 open (1990 Astro)
RHP: 7.625", 3.23 posi (1990 Astro)
RHR: 7.625", 3.42 posi (1990 Astro)
RHS: 7.625", 3.73 posi (1990 Astro)
RHT: 7.625", 4.10 open (1990 Astro)
RHU: 7.625", 4.10 posi (1990 Astro)
TZJ: 7.625", 3.73 open (late 1995 Astro)
TZK: 7.625", 3.73 posi (late 1995 Astro)
UTR: 7.625", 3.73 open ('91-early '95 Astro)
UTS: 7.625", 3.73 posi ('91-early '95 Astro)
VFC: 7.625", 3.73 open (1996-1997 Astro)
VGC: 7.625", 3.73 posi (1996-1997 Astro)
Hope these help
Hope these help
Originally posted by Black_Widdow
Thanks AstroMan! That should be a HUGE help. Those codes should be stamped onto to rear? And all those gears would work? Thanks again
Car: Bee-Bowdy
Axle/Gears: fo-tins
Any of those gears will work if you make sure you get the right size since some are 7.5" and some are 7.625".
Car: 4
Engine: 6
Transmission: 5
Forget the codes, they will only tell you what came in it, not what's there now. In the time it takes to get under a car, scrape the accumulated schmutz of 22 years off the rear end while laying in junkyard mud, write down the code, go home to look it up, and make another trip back to look inside the one that has the code you want only to find that it's already gone (since the junkyards keep a list of the codes, and the employees always seem to have real nice gears in their cars :/ ) you could instead just take the cover off and look.
I've seen 30 or 40 Astros at my local junkyard so I dont think I'll have a problem finding the gears. I'm buying a SLP take-off posi for my car and then I'll get the gears. Any more suggestions/tips?
Damn, that's cool. I can get my SLP take-off posi and some 3.73s for probably $150 or less. How much of a PITA is it to install gears yourself? I hate to spend more on installation than parts! I know I probably cant do it because it has to be aligned all perfectly and crap. How much should it cost me? A friend had gears installed for $200, is that reasonable?
Re: What else used the GM 7.5" 10-BOLT?
Hope these help
Hope these help
Spoiler
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
You have a PM
I have some 3.73's
I have some 3.73's
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
Isuzu Pup trucks have been known to have as low as 4.56 yes they are GM 7.5 rear ends
SeanTimothy
Jan 9, 2004 09:28 AM
