Water Injection system
Old Mar 25, 2002 | 01:32 PM
Bobalos's Avatar
Someone had posted a link to the vendor that made his water injection system. I searched the archives & can not find the post to it.
this WI system had a control center that went into the cockpit that had turn on time & flow & pressure & a bunch of other really cool stuff. anyone recall what that was & who made it? I thought that this person was using here here with a Centrifugal blower & IC but maybe it was a turbo setup.
thanks gents
BW
Old Mar 25, 2002 | 03:15 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Try www.carrollsupercharging.com
Doesn't Willie use this setup?
Old Mar 25, 2002 | 06:21 PM
Bobalos's Avatar
I think that Willie is using the Super Fueler, & not the WI system, but I could be wrong. the Carrol WI system does not look right.
thanks
BW
Old Mar 25, 2002 | 06:25 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
I use the Superfueler and water/alcohol injection. The water injection system is not the one asked about though. mine is the base level kit offered by Carroll.
I have seen the one in question. I do not recall the name of it though. From what I remember, it was a decent system at a decent price. The one fallback I see is that it has too many settings. You really don't need all that extraneous stuff. Mine can be run as a two-stage pump, but even that isn't really necessary. I have mine adjusted to turn on at 3-psig. It seems to work very nicely as I've seen air temperature in the plenum plummet when the water/alcohol is flowing.
Sorry I couldn't help much.
Old Mar 25, 2002 | 07:08 PM
maniacc's Avatar
i think the kit that you are referring to is the SMC kit, it retails for $349 if this is the kit that your looking for, you can contact them via e-mail at schlupsa@kih.net or phone/fax @ 270.522.9376.
the features of this kit are:
clean and easy install
1/2 gallon alcohol tank
in-tank pump
in-car control module with:
pump speed control
boost set point
armed lite
spray on lite
low alcohol warning lite
arm switch
test switch
hope this is what your looking for.
later
larry
Old Mar 25, 2002 | 09:01 PM
Bobalos's Avatar
Thanks gents. Maniacc, that smells like the one that I was thinking of, but as Willie said there is a lot to be said for simplicity. I am going to give them a call & find out if they have a flyer or sales lit. This might go on a Roots application so not sure how this is going to play out.
BW
Old Mar 25, 2002 | 09:47 PM
rhuarc30's Avatar
Try these links
http://home.att.net/~stevemon/AlcoholInjMod.html
http://www.aquamist.co.uk/
http://www.carrollsupercharging.com/other.htm
http://205.147.64.51/techarea/fuelsy...lkyrecipe.html
http://www.webdynamics-nj.com/OnlyGoodStuff
http://www.servtech.com/~racerx/kits
http://www.geocities.com/rad87gn/tech/SteveCkit.html
http://www.angelfire.com/super/buickgn/Alcohol.htm
http://members.bellatlantic.net/~steppa/page6.html
Old Mar 26, 2002 | 12:54 AM
Bobalos's Avatar
Right on Bubba, thanks for the links.
the one that is @ http://www.geocities.com/rad87gn/tech/SteveCkit.html was the one that I was thinking about.
thanks again
BW
Old Mar 26, 2002 | 11:48 PM
Murt TTA's Avatar
Car: 89 TTA
Engine: 3.8L turbo
Transmission: 200r4
Alky Kits
The SMC kit is one of the best and easiest to set up. I am ordering one for my TTA as soon as I get enough loot. You might wanna check at the Alky Tech section on http://www.turbobuick.com they have alot of info in their.
Good luck,
Murt
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
