Thirdgen Parts 4 sale misc
Old Aug 30, 2006 | 03:04 PM
thirdgenrs's Avatar
Car: 90 RS Camaro
Engine: 383L98
Transmission: t-56
Axle/Gears: 10bolt 3.42/posi
All items obo. i want to get rid of this stuff.
Double roller timing chain has maybe 3k miles on it. perfect shape, will work on any SBC... $20
Cruise control parts... $10 I also have the cable somewhere.
A/C Part...$15
Charcoal Canister $2
Inline High Performance Fuel pump...$30
Chrome Water neck...$10
License Plate Frame...$5
This thing...Free
Factory Flexplate..$5 No cracks
Chrome Timing Chain Cover...$15
MAF style Tpi Rubber Neck...$15
Turn Signal Lights, they have a few cracks in them...$1
Hurst Shift Ball w/ button.. $15
A/C condenser...$15
Dual Fan Setup..On Ebay eBay Motors: Dual cooling Fans Camaro Firebird Iroc Z28 transam GTA (item 110026832278 end time Sep-04-06 22:55:10 PDT)
Rear Drum Brake Setup... $15
700R4 Transmission OD slips in and out, not sure of mileage... $60
Ttop bag, no tears or rips...$20
I also have 2 L98 350 Cranks... $10 each.
3.8L 3800 Series II engine, Had a bad knock when removed. I will part out if needed. Make offers.
Single cooling Fan. $1
Remember everything is OBO.
If not sold this week I will post these items on Ebay
Old Aug 30, 2006 | 05:04 PM
priest1981's Avatar
Car: 86 IROC-Z
Engine: LB9
Axle/Gears: limited slip disc
Do you know the specs on the fuel pump? Is the t-top bag a zipper or velcro type?
Thank you,
Will
Old Aug 30, 2006 | 05:12 PM
thirdgenrs's Avatar
Car: 90 RS Camaro
Engine: 383L98
Transmission: t-56
Thank you,
Will
no i dont know the specs of the fuel pump. all i know its capable of high psi for a motor. the ttop bag is a zipper type.
Old Aug 30, 2006 | 09:04 PM
Drac0nic's Avatar
10 shipped on the water neck?
Old Sep 3, 2006 | 09:52 PM
thirdgenrs's Avatar
Car: 90 RS Camaro
Engine: 383L98
Transmission: t-56
ill do $15 shipped.
Old Sep 3, 2006 | 10:35 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Do you know if the condensor is good, no leaks?
How much shipped to 22152
Old Sep 3, 2006 | 11:12 PM
thirdgenrs's Avatar
Car: 90 RS Camaro
Engine: 383L98
Transmission: t-56
that i dont know for sure. it hasnt been used for probably 3 years.
Old Sep 4, 2006 | 03:27 AM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
timing chain???
can you tell me more about the timing chain? Paypal??Thanks, Nitro
Old Sep 4, 2006 | 03:23 PM
thirdgenrs's Avatar
Car: 90 RS Camaro
Engine: 383L98
Transmission: t-56
what do you want to know? Came off a Parted out IROC, i got it w/ the motor. like i said it only has a few thousand miles on it. as far as i can tell it looks like its in great shape.
Old Oct 24, 2006 | 12:07 PM
thirdgenrs's Avatar
Car: 90 RS Camaro
Engine: 383L98
Transmission: t-56
ttt almost everything is still available.
Old Oct 24, 2006 | 01:11 PM
redlsone's Avatar
how many times have the drums been turned or how many times more can they be turned?
Old Oct 24, 2006 | 01:14 PM
thirdgenrs's Avatar
Car: 90 RS Camaro
Engine: 383L98
Transmission: t-56
never have been turned.
Old Oct 25, 2006 | 02:08 AM
Pat Hall's Avatar
Check your pm's.
Frozer!!!
Jan 19, 2024 04:55 PM
fastrs1891
South Central Region
Oct 20, 2015 09:24 AM
1nastygta
Aug 8, 2015 07:38 PM
3rdgenparts
Aug 8, 2015 07:09 PM
3rdgenparts
Aug 5, 2015 11:57 PM
