NW Indiana and South Chicago Suburb Looking for club members to have gatherings, cruises, and to help each other out.
Stuff for sale
Old Feb 2, 2007 | 03:27 PM
91CamaroRS305's Avatar
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
Stuff for sale
Ok my fellow Chicagoland-ians, got some goodies for sale. I dont have pics of it all yet but can get them, but heres the stuff!
Doors are gone, I stripped them for parts cause they will work in my truck.
Competition Engineering weld-in subframe connectors, WITH the crossmember to switch over to a 4 link/ladder bar setup. It is missing one of the side pieces that can be easily made, I want to keep the car in a "stock" setup suspension. Jegs part number 247-3017...going for $230
$120 OBO
Another set of weld in sub frame connectors.
SOLD Thanks Tom!!!
99% complete Gray interior pieces, missing a cover for the hatch lift arms, and 2 plastic screws, includeds front seat belts. All pieces are in good condition, no cracks, but a few scuffs. $50 OBO
3.23 gear still on open rear GM diff, wasn't original to the car so I don't know the mileage.
$45 OBO
Rear hatch W/O glassGONE
Stock Camaro shifter with cable $15 OBO
Complete Serpentine setup WITH Power steering cooler lines $30 OBO sale pending
Stock oil cooler setup where coolant runs thru it from an 88 IROC $20 OBO
2 700R4 drive shafts, both with yokes, on needs new rear U-joint $15 each OBO
Dash gauge bezel from an 88 IROC, black, no crack/chips near mint $10
Camaro console lid, needs new latch, no cracks $15 OBO
Camaro radio/heating control bezel, no cracks, near mint $10 OBO
ADDED!!!!
2 Holley Blue Pumps one with mounting bracket, used as a Nitrous pump for less than a season, the other works but needs rebuild $75 OBO
2 FRAM Fuel filters (one has a cracked piece where the fittings go the other is good) $40 OBO
Hooker Competition shorty heads WITH mandtel bent y-pipe. I cut a section of the y-pipe off where it usually bolts to the converter, it was cut so I could fit in a muffler and turn down. I will sell if everything works out with a set of long tubes I am looking to pick up. The y-pipe is less than a season old, but my valve cover gaskets leaked so it has oil stains on it, y-pipe itself was $220 when I bought it Looking for $175 OBO
Selling the cam out of my engine, one of my rod caps ruined the bearing on the crank so I am not going to sell the whole engine. But the specs are below, has less than 40 passes on it at the track, and around 1000 miles IF that. Car drove very well in traffic, had manual brakes so I don't know much about the vacuum it pulls, ask any questions. Selling with the lifters and I will number them accordingly, cam is still in the engine sitting on my stand. Looking for $75 OBO
ROUGH IDLE, PERFORMANCE USAGE, GOOD UPPER RPM TORQUE AND HP, BRACKET RACING, AUTO TRANS W/3000+ CONVERTER, 4200-4600 CRUISE RPM, 10.5 TO 12.0 COMPRESSION RATIO ADVISED.
Grind Number: 302 H06
Operating Range: 3400-7000 RPM
Duration Advertised: 302° Intake / 302° Exhaust
Duration @ .050'' Lift: 246° Intake / 246° Exhaust
Valve Lift w/1.5 Rockers: .500'' Intake / .500'' Exhaust
Lobe Separation Angle: 106°
Max Lift Angle: 102° ATDC Intake / 110° BTDC Exhaust
Open/Close @.050'' Cam Lift: Intake - 21° BTDC (opens) / 45° ABDC (closes)
Exhaust - 53° BBDC (opens) / 13° ATDC (closes)
Feel free to pm me, reply here, or call my cell at 773 844 9749, quickest way is my cell...thanks!!
Old Feb 2, 2007 | 05:05 PM
paulbuiltbird's Avatar
Car: 1989 Formula 350
Engine: 350 fuel injected
Axle/Gears: 9 bolt w/370 gears
might be interested in the serp set-up
Old Feb 2, 2007 | 05:07 PM
hmmmmm.....familiar name.....lol
let me know what you need paul
Old Feb 13, 2007 | 11:52 PM
still have it all....and soon to be more.....help me build the new race car!!
Old Feb 14, 2007 | 03:53 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I need the front spoiler only. Will you seperate?
Old Feb 14, 2007 | 08:22 AM
the front spoiler is the only thing damaged, it has 2 breaks in it, but it is fixable if you are good with fiberglass and the plastic they used
Old Feb 21, 2007 | 11:09 PM
i added some stuff and looking to trade for heads, a nos setup, big stall
Old Feb 22, 2007 | 04:11 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Hey Mike,
Do you still have the 700R4 shaft witht he good U-joint? Let me know.
Steven
Old Feb 22, 2007 | 07:29 PM
Steven
Yeah I got it still, you need one? Make me an offer, I dont need it and it is just chillin in the rafters of my garage.
Old Feb 22, 2007 | 10:24 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Check your PMs Mike
Old Feb 22, 2007 | 11:05 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
sent PM
thanks
Old Feb 23, 2007 | 12:28 AM
pm's have all been responded to.
Old Feb 23, 2007 | 01:08 AM
Bluejae's Avatar
Car: 1988 Formula 350
Engine: L98 350 TPI
Transmission: 700-R4
You have a pm.
Old Feb 23, 2007 | 11:06 AM
responded blue jay
Old Feb 24, 2007 | 03:22 PM
what comes with the serp setup? maybe I can buy it from you before you haul it to the swap meet.
Old Feb 24, 2007 | 10:23 PM
All the brackets, power steering pump with lines and 2 gear boxes both with cooler lines (I think I have some new hoses too, I will double check), AIR pump with pulley, working AC compressor, crank pulley, working alternator, working water pump, tensioner....everything minus the belt, I shortened it over the years and threw the original one away. I have 1 1/2 sets, cause I have an extra pass. side bracket from another engine that I will throw in too, incase one bracket cleans up better than the other.
I am not taking it to the swap meet because I just got the engine pulled a few hours ago and didn't feel like taking it off, so it is still on the engine sitting on my stand, so let me know, I have one guy in oklahoma that is interested but I told him you have first dibs. Call my cell tomorrow and I am sure we can work something out, I will be at the swap meet all day for the most part.
Old Feb 24, 2007 | 10:46 PM
sounds good I'll take it. I will get in touch and we can work something out.
Old Feb 24, 2007 | 10:49 PM
Cool, sounds good to me!!
Old Feb 25, 2007 | 11:47 AM
niceroc's Avatar
Car: 87 iroc
Engine: 454 .030 over
Transmission: th-350
Axle/Gears: 9 bolt
will u take $40 for the normal SFCs?
Old Feb 25, 2007 | 02:16 PM
Yeah that works, let me know when you want to pick them up or have me meet up with you some where.
Old Feb 26, 2007 | 12:27 AM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
fyi, those driveshafts will work with a t-5 also.
Old Mar 4, 2007 | 06:45 PM
I added some more....and some people contacted me about parts, let me know if you still want them!!
Old Mar 5, 2007 | 03:23 AM
slim64's Avatar
Car: 64 Impala, 86 Z28 Camaro, 00 C5 FRC
interested in the rear hatch with the spoiler, is the 3rd brake light still intact in the spoiler with all the wiring?
now i just need to find a non-rear defrost rear hatch without a 3rd brake light on the glass...
Old Mar 5, 2007 | 08:47 AM
Bluejae's Avatar
Engine: L98 350 TPI
Thanks for remembering me on the serp setup.
Old Mar 5, 2007 | 10:51 AM
I will have to double check on the spoiler about the wiring, but I know it had a light in it, just don't remember if I kept the wiring.
No prob, the guy that was going to meet me at the swap meet was going to meet me afterwards, I am waiting on an email if he really wants it, otherwise it is yours.
Last edited by 91CamaroRS305; Mar 5, 2007 at 10:52 AM. Reason: Automerged Doublepost
Old Mar 5, 2007 | 07:48 PM
hey Mike, don't want you to think I'm leaving you hanging on those parts
I said I would buy. If you want to set something up soon I'm game with that or if there is going to be a get together soon we can settle up then. let me know what you think.
Old Mar 5, 2007 | 08:42 PM
Lets see if there is a gathering when Jer comes back, otherwise we can work something out
Old Mar 7, 2007 | 05:28 PM
Added some stuff at the bottom....some pumps and stuff
Old Mar 12, 2007 | 04:20 PM
Camaro-please?'s Avatar
Car: 88 Camaro Sport Coupe
Your Radio Can I have it is it stock does it work?
Old Mar 12, 2007 | 05:01 PM
its just the plastic bezel piece that out lines the radio/heater controls, no radio, sorry!
Old Mar 12, 2007 | 10:06 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Dont wanna jack your thread Mike, but I got a stock radio in my garage if you pick it up you can take if for free. Should work fine Im near Ohare
Old Mar 12, 2007 | 10:16 PM
Deal!
Old Mar 13, 2007 | 01:28 AM
no prob with the hijacking....but when you coming to pick up this driveshaft?
Old Mar 13, 2007 | 09:55 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
I gotta find time, now that im back in school . Ill give you a call when I can find time thanks for waiting Mike
Old Mar 13, 2007 | 10:10 PM
No prob Steve.....I will be up in des planes this weekend, I am trailering Steve P (xxxman, or whatever his name on here is) Camaro out of his moms driveway to build an engine for it, so let me know what day is good for you and we can meet up
Old Mar 14, 2007 | 08:25 PM
T-rocZ88's Avatar
Car: 79 cutlass
Engine: sbc
Axle/Gears: 12bolt
hey mike.........first off the center link worked GREAT..fixed my problem, THANKS!! second do happen to have the rear latch for the back glass?, if you do is it motorized? again
the locking mechanism not the actual latch
Old Mar 14, 2007 | 09:00 PM
No prob Troy, glad to help
As for the hatch latch, I have the motorized one out of my car with the latch, I may need it if my new project doesn't have one, which I will check tonight if it needs it and pm you tomorrow with whether I will be getting rid of it or not.
Old Mar 16, 2007 | 08:27 PM
T-rocZ88's Avatar
Car: 79 cutlass
Engine: sbc
Axle/Gears: 12bolt
ok sounds good
Old Mar 24, 2007 | 09:38 PM
Re: Stuff for sale
Updated, thanks for doing business with me and good luck with the engine swap!!!
Old Apr 22, 2007 | 07:14 PM
Re: Stuff for sale
updated with some stuff.......and paul let me know what works so we can meet up so you can get this serp setup.
Old Apr 23, 2007 | 12:58 PM
Re: Stuff for sale
I am usually open on mon-wed, almost anytime after like 5:00PM or on weekends. Are you usually available during weekday nights? I work in Schaumburg and it wouldn't take too long to get to the city from work so let me know. also do you have any black interior parts? and the heater controls?
Old Apr 24, 2007 | 12:00 AM
Re: Stuff for sale
No black interior pieces, I am looking for some myself LOL, but I will look on heater controls, I think I have one some where.....and if everything works out tomorrow I will have a job at Strange Engineering in Morton Grove so I will be up that way quite often.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
New2Chevy
Sep 28, 2015 12:35 AM
raymondandretti
Exterior Parts for Sale
Sep 5, 2015 05:02 PM
UMI Performance
Sponsored Vendors
Sep 4, 2015 09:22 AM
