Swaybars
Old Sep 12, 2007 | 12:41 PM
Camaro5690's Avatar
Car: 1985 Camaro/89 Merkur XR4Ti
Engine: 5.0 305 LG4/2.3 Turbo (180hp/205tq)
Transmission: TH700R4 with Shift Improver Kit/T-9
Axle/Gears: 3.42LT1 Rear/3.64
Swaybars
Ok heres the deal. I feel like a total idiot. But I have a 1985 Sport Coupe. Did these come with a rear sway bar? If they didnt then why not? And if they did WTF wheres mine? Any help would be appreciated.
Old Sep 12, 2007 | 12:42 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
Re: Swaybars
Base model cars didn't have rear swaybars in the early years.
Old Sep 12, 2007 | 12:49 PM
Camaro5690's Avatar
Re: Swaybars
well....that sucks. I guess I need to go find a car in a scrapyard and get some parts then eh?
Old Sep 12, 2007 | 01:11 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Re: Swaybars
Get the front and back bars from the doner car as they need to be matched unless you are mismatching them for a specific reason.
In the alternative, you could just look up the various combinations from the factory and get a rear which is the same or close to what you need to match the front bar.
The thing to avoid is getting it totally wrong and making the car too loose or oversteer which means that the back will want to come around all the time.
In addition, bars are matched to spring rates but that probably isn't going to be an issue for average street applications.
Old Sep 12, 2007 | 01:14 PM
Apeiron's Avatar
Engine: 383 Carb
Re: Swaybars
You'll also need the brackets that mount the rear swaybar endlinks to the frame.
Old Sep 12, 2007 | 10:36 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: Swaybars
From what I've read so far '86 was the first year the Sport Coupe,and Berlinetta,came standard with fron and rear bars(basically RPO-F41 became standard).
As Apeiron noted you'll need the rear brackets to mount the rear bar ends links to the frame.And as George noted it's best to get them from the same car for compatibility front/rear for balanced handling.
Old Sep 13, 2007 | 05:20 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Swaybars
As I understand it, the holes for the brackets will be there, but you may need to tap them. There was a recent link involving this topic.
JamesC
Orr89RocZ
Apr 25, 2016 08:28 AM
grafx
Aftermarket Product Review
Dec 10, 2001 12:27 PM
TBIWorks
Dec 4, 2001 01:35 PM
TBIWorks
Nov 29, 2001 01:03 AM
Trevor 91 Formula
Feb 7, 2001 02:06 PM
