A.I.R. Diverter Valve
If I install a smog pump delete pulley and cap of my air injection at the manifolds and cat, can I remove the A.I.R. diverter vale and unhook the harness with out any effects on the stock ECM, or will it set off a code and check engine light? thanks guys!
'92 RS Heritage Pkg, 305TBI,automatic... CURRENT MODS..Melling 207:214 roller camshaft, Large snorkle air cleaner w/ K&N filter, Injector spacer, ACCEL super coil, Taylor wires,power pulleys, 6* timing advance, flowmaster catback exaust, hollow cat, '95 Z28 exaust tips, P245/50/ZR16 tires, Edelbrock strut tower brace, Edelbrock panhard rod, frt & rear urethane swaybar end links, urethane sway bar bushings, subframe connectors, urethane track bar bushing, KYB shocks, F41 factory performance handling package,Z28 tranny centrifical governor, and more to come soon!
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Yes, the ECM only switches power to the solinoids, it doesn't look for a return voltage or signal to make sure they are there or operating.
------------------[*]my Formula Homepage [*]Collision P/Ns & Diagrams
"Always do sober what you said you'd do drunk. That will teach
you to keep your mouth shut."
355tpipickup
Sep 13, 2015 11:35 PM
