L98 Aluminum heads/roller rockers/guide plates/pushrods
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Aluminum L98 heads for sale. approx 15,000 miles since rebuilt. I ran these on my 305 and it ran awesome. 13.7@100.5 on the stock chip. do a search for my screen name for more details. Only selling the heads because I installed my 383 and no longer need them. Heads are painted black because I wanted to disguise them on my 305. They are in perfect condition, ready to be cleaned and bolted on. Needs nothing. Asking $450 OBO
extruded 1.5 ratio roller rockers for sale as well. $65
Hardened pushrods for flat tappet cams and lifters. $30 OBO
Send a PM with any questions. I need to sell this stuff.
Car: 1985 Trans Am
Transmission: 700-R4
Re: L98 Aluminum heads/roller rockers/guide plates/pushrods
damn what else was done to the 305 to run in the 13's? Id buy these if i had the cash...
free bump good luck
free bump good luck
Car: 86 IROC
Engine: 383
All the 305 had was ported stock TPI parts. 214/224 duration flat tappet cam. edelbrock headers, and these heads. It was easily making 300+hp.
The heads are off of a 1990 Corvette.
Car: 89 RS.. 91 1/2ton 1500
Engine: 305 tbi
Transmission: 5 speed manual
What is the length on the push rods??
mrtater
mrtater
Car: 86 IROC
Engine: 383
Car: 86 IROC-Z, 98 Z28
Engine: 370 LSx, LS1
Transmission: T56's
Axle/Gears: 3.73, 3.42
I'm tempted to buy the rocker arms and pushrods. Ive got a set of aluminum L98 heads on my 86 LB9, would those rocker arms and pushrods be a straight up replacement, and work? Any clearance issues with the stock height valve covers?
Car: 86 IROC
Engine: 383
The rockers are non-guided so you would need hardened guide plates(which these heads have) and hardened pushrods(which I also have) they will fit under stock centerbolt valve covers with no issue. However you can't run hardened pushrods with with the stock guide plates because they arent hardened, you'll wear grooves in them.
Car: 89camaro rs
Engine: 350tbi (needs carb!)
Axle/Gears: 32x in process
ahh man ,
if you were close enough for for local pick up and if i had the cash on hand then those heads would of been gone.
bump for the clean aluminum vette heads
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
damn I would have picked up those heads for my '91
High I want to get some of these for my 305 TPI and try atleast to get what you got, a nice 13.7 with hooker shorty's, Edelbrock high flow base plate + SLP runners and K&N intake, with the 214/224 cam and these heads, I was wondering if these heads are the same as the new GM performance ones part number 12556463 ?? 163cc intake 58cc chamber/ 1.94'' intake, 1.50'' exhaust?? would these heads (12556463) fit on my 305 TPI with no problems?
[quote=1MeanZ;3592414]Aluminum L98 heads for sale. approx 15,000 miles since rebuilt. I ran these on my 305 and it ran awesome. 13.7@100.5 on the stock chip. do a search for my screen name for more details. Only selling the heads because I installed my 383 and no longer need them. Heads are painted black because I wanted to disguise them on my 305. They are in perfect condition, ready to be cleaned and bolted on. Needs nothing. Asking $450 OBO
Hi, are these the same exact thing as the ZZ4 heads?, and would these bolt directly on to the 305 TPI with no problems? also what brand is the 214/224 cam you had? do you think i should go for the same ? since you got 13.7 out of it?
Yeah I think the ZZ4 heads have different valve springs for the hotter ZZ4 cam (not that hot but hotter than the stock 1990 Corvette cam) I have the Corvette heads and they came with the stock springs, bought a set of ZZ4 valve springs and they have a green line painted on the valve springs. Don't have the specs but the ZZ4 springs andle the higher lift cam I was told.
Dave
Dave
ya i need some help ya im a noob but please, ok I want to get Trick flow 56cc heads/Cam combination for my 305 TPI but i kinda wanted to keep the internals stock cause of the budget, my stupid question is if i got a cam with higher lift in the range of .462/.469 218/224 duration at .050 to go with these heads, wont the higher lift send my valves into the stock pistons?
sorry for the resurection.
I have a set of just done 113 L98 heads. these are the sort after alum vette heads.
"In 1988 GM switched the Corvette to the 10088113 casting "D-Port" aluminum cylinder heads. These were good for just over 350hp before you had to start working them."
new springs, seats, valves, retainers, all redone, still in the plastic bags from the machine shop. $700
