Misc Parts if anyone needs them.
Old May 12, 2008 | 07:28 PM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
TPI TV cable for 700r4.
Roller Cam Retainer plate with bolts.
3.42 gears for 10 bolt.
3.23 gears for 10 bolt.
Refurbished Oil Pan for 1pc seal.
Overhead console for z28 t-top car.
Upper & Lower TPI cold air induction for z28 MAF cars.
No reasonable offers refused.
Old May 12, 2008 | 09:30 PM
lopezisgod's Avatar
Car: 86 iroc-z, 78 z28, 91 z28
Engine: 355-carb, 350-carb, 350-TPI
Transmission: 5speed, at, 5 speed
Axle/Gears: 3.42, 3.42-stock, 3.42-1LE
Re: Misc Parts if anyone needs them.
.. what you want for the overhead console..
and do you have pic?
my email.. is.. lopezisgod@gmail.com
Old May 13, 2008 | 06:29 PM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
I will try and post some pictures by the weekend.
Old May 15, 2008 | 07:12 PM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Overhead Console. Oil pans.
Attached Thumbnails Misc Parts if anyone needs them.-im000814.jpg   Misc Parts if anyone needs them.-im000815.jpg
Old May 15, 2008 | 07:14 PM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Wonder bar. Tpi Distributor cover extension. Roller pushrods.
Attached Thumbnails Misc Parts if anyone needs them.-im000816.jpg   Misc Parts if anyone needs them.-im000817.jpg
Old May 15, 2008 | 07:16 PM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
TPI TV cable. Power Adder air cleaner.
Attached Thumbnails Misc Parts if anyone needs them.-im000818.jpg   Misc Parts if anyone needs them.-im000820.jpg
Old May 15, 2008 | 07:17 PM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
And this gently used L98 5.7" Rod.
Old May 15, 2008 | 08:07 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
how much for the rod?
Old May 15, 2008 | 08:37 PM
Alaska Hwy 1Le's Avatar
Car: 91' Z28 1LE R7U
Engine: 350 ZZ6
Transmission: 6 Speed T56 Magnum
Axle/Gears: 3:42 posi G80/GU6
Are the 10bolt 3:42's in good shape? how many miles? I think I'm gonna need them. My rearend is making noice but the local mech says my gears are fine and it only needs bearings. I have all the bearings and crush sleave now. I'm just waiting for some 28spline axles and when I get them we will put it all back together. Hopefully it will be ok but I think it sounds more like gear noise. How much BTW? If the price is right maybe I'll just get them anyways.
Thank you.
Old May 15, 2008 | 08:44 PM
Engine: 350 ZZ6
I am 75%sure that I need your 3:42's for the ten bolt. My local mech sez that my gears are ok (They look OK) and only the bearings are buggered. I already have the bearing kit and am just waiting for EV-104 28splines. When they get here we are gonna throw it back together and I really hope the noice is gone. How many miles on your gears and how much do you want? If the price is right maybe I'll just get them. I think he's wrong cuz it's quite whiny.
sorry for 2 posts I thought the frst didn't make it.
Last edited by Alaska Hwy 1Le; May 15, 2008 at 08:45 PM. Reason: Automerged Doublepost
Old May 16, 2008 | 04:08 PM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
I can't be sure of the mileage on the 3.42 gears(for 10 bolt). They show minimal wear, and are not chipped, broken or pitted. The pinion gear has good bearings on it, but may as well change them out if you got new ones. $45 shipped to the lower 48 states.
Taking offers on the connecting Rod !
Old May 16, 2008 | 05:01 PM
irocbrninrubber's Avatar
Hello, i am interestedin the cam retainer plate, how much? by any chance do you have the spider and wishbones?Thanks.
Old May 16, 2008 | 07:00 PM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
I have the Roller Cam Retainer plate with factory torx screws, also the cam gear factory torx screws as well. $15 shipped to the lower 48 states. No spider tray retainer or dogbones. Paypal?
Old May 16, 2008 | 07:37 PM
Engine: 350 ZZ6
I am in northern B.C. Canada. Would you ship them here? My wife can do the PayPal thing.
Old May 16, 2008 | 08:18 PM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
International shipping is extra. Can do it for $60 total. PM me for my Paypal info if interested.
Old May 16, 2008 | 08:31 PM
91TTOPZ's Avatar
Car: 1972 GMC
Axle/Gears: 4:10
How much for the 3:23 10 bolt gears are they stock, I have a 10 bolt with the 2:73 so I would need a spacer if they are not the thick gears. What condition and how much shipped to 55318.
John
Old May 16, 2008 | 09:11 PM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
John
John, Gears out of a factory rear(G92 car). You would need the spacer. Excellent condition with normal wear. No chips, pits or broken teeth. $45 shipped to any of the lower 48 states.
Paypal is good. Thanks Dean
Old May 16, 2008 | 09:20 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
How much for the air filter.. looking for one for my gf's eclipse.
Old May 17, 2008 | 08:17 PM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
How's $20 bucks sound?
Old May 17, 2008 | 08:33 PM
Engine: 350 ZZ6
My wife should be home in a coupla hours to paypal you $60 for the 3:42's thanks!
Old May 17, 2008 | 08:43 PM
Jim R's Avatar
Car: 1986 T/A GTA
Engine: LB9
Axle/Gears: Don't know
Is the TPI dist cover alum or plastic, if alum how much ?
Old May 17, 2008 | 08:55 PM
karl's-92'-z28's Avatar
Car: Too many cars
What brand is the wonder bar?
Old May 17, 2008 | 11:01 PM
Engine: Vortec 357
what are the dimensions of the cone and the neck.
Old May 18, 2008 | 01:15 AM
Engine: 350 ZZ6
It's done you should have a notification from paypal.
Old May 18, 2008 | 07:43 AM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
No Paypal notice as of this post (for the 3.42 gears)
I will measure the diminisions of the Air Filter thingy. Get back to you.
The Wonder bar is a Factory GM unit off 87 Iroc.
TPI dist cover is plastic.
Old May 18, 2008 | 09:25 PM
Jim R's Avatar
Car: 1986 T/A GTA
Engine: LB9
Thanks but I'm looking for a alum TPI dist cover.
Old May 18, 2008 | 10:50 PM
dv8's Avatar
dv8
Car: 88 IrocZ Vert
Engine: 5.0 TPI
is the cam retainer still available??
Old May 19, 2008 | 07:23 PM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Yes.
Old May 19, 2008 | 07:55 PM
Engine: 350 ZZ6
I have the paypal confirmation to your address did you get it yet.
Old May 19, 2008 | 08:00 PM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Yes, Your item has been shipped. Thanks.
Old May 19, 2008 | 08:06 PM
Engine: 350 ZZ6
COOL!!! Thank you very Much.
Old May 19, 2008 | 09:03 PM
dv8's Avatar
dv8
Car: 88 IrocZ Vert
Engine: 5.0 TPI
would you take 10 shipped for the retainer plate??
Old May 20, 2008 | 06:45 PM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
I can do $15 through Paypal. PM for paypal info.
Old May 21, 2008 | 11:31 AM
dv8's Avatar
dv8
Car: 88 IrocZ Vert
Engine: 5.0 TPI
for 6 bucks more they are new on e-bay. 15.99 plus 5 shipping..
Old May 21, 2008 | 07:13 PM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
So if you bought from me you would save $6. Who's the crazy one?...Mine also comes with factory torx screws for the retainer plate and the 3 factory torx screws for the cam gear. FYI. $10 plus $5 shipping is fair.
Old May 22, 2008 | 11:20 PM
dv8's Avatar
dv8
Car: 88 IrocZ Vert
Engine: 5.0 TPI
you made a great point I didnt know you were including the cam bolts.
send a request to miknjan@msn.com for paypal.
this is for the retainer & cam bolts
Mike
Old May 22, 2008 | 11:44 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
What are you looking to get for the wonderbar shipped to 44072?
Old May 25, 2008 | 11:09 AM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
$35 shipped.
Old May 25, 2008 | 10:34 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
If you could PM me with your paypal information (or post it here), Ill be sending you $35.
Old May 26, 2008 | 02:38 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Upper and lower cold air induction? Are you talking about the two-filter unit that goes on top of the bumper cover near the leading edge of the hood? If so, how much? Pics? How much for the rod? I have heard the curved ones will give you more power! I heard about it on a mu**ang website. (You know those guys are never wrong.)
Old May 26, 2008 | 02:37 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Money sent for wonderbar
Old May 26, 2008 | 07:09 PM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
This is the one I have.
Old May 30, 2008 | 07:21 PM
Engine: 350 ZZ6
I just got the gears today!!!! Thank you very much!
PS: Did you sell the connecting rod yet?
Old May 30, 2008 | 08:36 PM
ScotSea's Avatar
I am interested in the black oil pan and the TPI TV cable. Got a price in mind?
Thanks, Scot
Old May 30, 2008 | 10:10 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
I received the wonderbar, thanks!
Old May 31, 2008 | 04:29 PM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
You can have both for $40, plus $5 shipping.
Thanks, Scot[/QUOTE]
Old May 31, 2008 | 06:47 PM
ScotSea's Avatar
PM me your name and address, and I will get the MO out to you.
Thanks, Scot
Old Jun 5, 2008 | 07:00 PM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Still have a few items.
3.23 gears
Orange Oil pan (1 pc seal)
Overhead Console (ttop)
TPI induction
TPI Plenum Extension
Roller Pushrods....
And the connecting Rod(I thought that would sell right away?)
Old Jun 6, 2008 | 05:12 PM
miked8205's Avatar
Want a title? Post!
how much for the 3.23 shipped?
Old Jun 6, 2008 | 07:20 PM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
$38 shipped
