Alston subframe, lakewood shocks, radiator, stealth intake,and a bunch of other parts
Old May 23, 2008 | 12:01 PM
scorchmaster's Avatar
Car: 1984 z28
Engine: BBC
Transmission: TH400
Alston subframe connectors, never welded, comes with bolts and nuts. $120 + shipping
Lakewood 50/50 shocks, only a few hundred miles on them. $50 + shipping
Hurst 5 foot long shifter cable, BRAND NEW. $30 + shipping
Stock replacement radiator, used for 20 miles, in next to mint shape. There are 4 fins bent to get my fan installed, that is the only thing wrong with this. Comes with a lifetime warranty from autozone. $50+shipping
Weiand Stealth intake manifold, painted a burgundy color, has one bolt hole in the thermostat stripped, needs to be fixed. $25+shipping
Summit vacuum canister with gauge, fittings and bracket. $20 + shipping
1" aluminum 4150 carb spacer. $10 + shipping
30% reduction crank pulley, short water pump, made from aluminum. $15+shipping
Straight bolt pattern starter, used for 2000 miles, still works great just had it tested. $20+shipping
Bowtie front grille, red in color with a license plate holder which can be taken off. $15+shipping
Rear brake line, (The one connecting the one rear line to the two on the axle) this is next to brand new. $15+shipping
Mark Williams chromoly driveshaft center piece, does not have the end yokes, just the middle chromoly piece. $20+shipping
Old May 23, 2008 | 12:07 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
Re: Alston subframe, lakewood shocks, radiator, stealth intake,and a bunch of other p
interested in the pulleys, send pics to my pm please. Will these fit a 305?
Old May 23, 2008 | 12:23 PM
Car: 1984 z28
Engine: BBC
Transmission: TH400
The brownish spot on the middle is just the reflection off my hand
yes it will fit a 305
Last edited by scorchmaster; May 23, 2008 at 12:24 PM. Reason: Automerged Doublepost
Old May 23, 2008 | 01:24 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Interested in the carb spacer and the bowtie front grill. Could I get some picks and will you ship to canada. Thanks
Old May 23, 2008 | 01:52 PM
Engine: Vortec 357
do you have any pictures of the short water pump pulley as well? consider them sold ill transfer money into my paypal account if thats what you take but it will take a few days. Also is that intake setup up for electric or mechanical gauge unit senders?
Old May 23, 2008 | 02:02 PM
Car: 1984 z28
Engine: BBC
Transmission: TH400
The intake thing you're looking at is a plug, but it did have an electrical sending unit in it at one time.
I only have the short crank pulley, I was just stating it was made for a short water pump, sorry for the confusion.
Old May 23, 2008 | 02:06 PM
Engine: Vortec 357
can i use this crank pulley on a basic 305 w/ a stock water pump or would i have to change out the water pump? I may be interested in the inatke as well but i will need to have to think about it.
Old May 23, 2008 | 02:32 PM
Car: 1984 z28
Engine: BBC
Transmission: TH400
if the stock water pump is short style, then no you dont have to change it out.
Old May 23, 2008 | 06:49 PM
Engine: Vortec 357
Ok ill have to ask around and see what the difference is. ill you know in a day or so
Old May 23, 2008 | 10:36 PM
karl's-92'-z28's Avatar
Car: Too many cars
Could you post pics of grill please
Old May 23, 2008 | 11:08 PM
Drac0nic's Avatar
Is the intake for 87+ pattern or 86 and earlier?
Old May 23, 2008 | 11:13 PM
Stephen's Avatar
Car: 87 GTA
Shipping on the SFCs to 78605 please?
Old May 24, 2008 | 02:53 AM
Car: 1984 z28
Engine: BBC
Transmission: TH400
subframes are sold, intake is for pre 86, grille pics will be posted tomorrow
Old May 24, 2008 | 02:55 AM
6SIX6's Avatar
Car: 89 IROC
So will you ship to canada???? as I said before im interested in the grille and spacer. Thanks
Old May 24, 2008 | 04:03 AM
Car: 1984 z28
Engine: BBC
Transmission: TH400
sorry, yeah I'll ship to canada
Old May 25, 2008 | 12:32 PM
Car: 1984 z28
Engine: BBC
Transmission: TH400
my camera wont connect to my computer anymore, it keeps crashing. I'll try again to get you those pics.
Old May 25, 2008 | 01:19 PM
all4u's Avatar
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
post pics of vacuum canister with gauge and maybe I can come today or tomorrow to get it. I am in Des Plaines so I can drive to you.
Old May 25, 2008 | 03:22 PM
CARMOND's Avatar
Want a title? Post!
Could you send me your phone #.I would like to get the shocks & the vacuum canister
Old May 27, 2008 | 03:28 PM
Car: 1984 z28
Engine: BBC
Transmission: TH400
Old May 27, 2008 | 09:14 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
pic of the driveshaft, and length, please.
Old May 28, 2008 | 12:37 PM
3rdgenmaro's Avatar
Car: 88 IROC
Transmission: 700 r4
do you still have the vac canister and manifold spacer? If so how much to ship to 24330? Thanks
Old May 28, 2008 | 12:57 PM
Car: 1984 z28
Engine: BBC
Transmission: TH400
spacer is pending right now, not sure on the canister as no one has responded back to me. But shipping on the canister to you will be about $15
Old Jun 1, 2008 | 12:37 PM
Car: 1984 z28
Engine: BBC
Transmission: TH400
spacer. subframes and radiator is gone
Old Jun 3, 2008 | 04:29 PM
Roadkid91's Avatar
Car: 1987 Trans Am
Engine: LB9
Is the driveshaft stock length? will it work with my 700R4 and Borg Warner 9 bolt?
Old Jun 3, 2008 | 05:15 PM
Car: 1984 z28
Engine: BBC
Transmission: TH400
I'll measure it and let you know.
Old Jun 6, 2008 | 11:26 AM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
rear 50/50 shocks still avail.?
Old Jun 6, 2008 | 11:35 AM
all4u's Avatar
Car: Firechicken
Is the vacuum canister still available? If so, let me know and I will come by on monday and pick it up from you. I am down the street in Des Plaines.
Old Jun 6, 2008 | 11:40 AM
Car: 1984 z28
Engine: BBC
Transmission: TH400
The driveshaft center will be good for any other car besides a thirdgen, it's kind of short about 38-39". Maybe or maybe a thirdgen with a t56 with a S60 rear end
50/50 shocks are available.
All4u: I tried calling you about it a while back but I never got a hold of you. I still have it and your nitrous brackets you didnt pick up
Old Jun 15, 2008 | 07:14 PM
Car: 1984 z28
Engine: BBC
Transmission: TH400
back up top
Old Jun 22, 2008 | 07:42 PM
Car: 1984 z28
Engine: BBC
Transmission: TH400
back up
Old Jun 26, 2008 | 01:24 PM
Car: 1984 z28
Engine: BBC
Transmission: TH400
i cant believe I still have this stuff. Offers?
Old Jun 27, 2008 | 06:25 AM
88 350 tpi formula's Avatar
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
what is left
Old Jun 27, 2008 | 08:28 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by 88 350 tpi formula
what is left
Old Jun 27, 2008 | 09:29 AM
Car: 1984 z28
Engine: BBC
Transmission: TH400
Turbo400 custom made driveshaft (complete). Will hold big hp, paid $450 for it a few months ago, it was in the car but didnt drive. $250
__________________
Old Jun 28, 2008 | 12:16 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
PM sent
Old Jun 28, 2008 | 08:48 AM
1986chevycamaro's Avatar
Car: 92camaro,86 camaro
you have pics of radiator?
Old Jun 28, 2008 | 08:07 PM
Car: 1984 z28
Engine: BBC
Transmission: TH400
rad is gone
pm sent back
Old Jun 29, 2008 | 12:06 AM
matchbox's Avatar
Car: 87RS/70 novaSS/85 Z28
Engine: 2.8L/468 HP unknown/HO305
Transmission: 700r4,T400,stock
Axle/Gears: stock,fab9,stock
I'll take the grill 98277 you have paypal?
Old Jul 10, 2008 | 07:27 PM
Car: 1984 z28
Engine: BBC
Transmission: TH400
grill gone!
Old Jul 21, 2008 | 04:44 PM
Car: 1984 z28
Engine: BBC
Transmission: TH400
hasnt been bumped in a while
Old Jul 28, 2008 | 11:12 AM
86speediroc's Avatar
Transmission: 94 t56
Axle/Gears: 3:42 10 bolt
still got the driveshaft i'll take it give me a shipping price to 08037
Old Jul 30, 2008 | 09:32 PM
FASTERTHANUMARK's Avatar
Car: 1970 Nova
Engine: 850HP 383
Transmission: TH400 w/ Brake
Axle/Gears: 4.88 12 Bolt
Shocks avail still?
Old Jul 31, 2008 | 07:29 AM
Car: 1984 z28
Engine: BBC
Transmission: TH400
Yeah I still have them.
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
