Parts for sale Chicago cheap!
Old Jun 8, 2008 | 07:40 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Everything I have must go. The project is nearing completion and I need to clear this stuff out.
All prices below are base price and best offer is available for every item. Just ask Ill probably slash the price.
-Camaro hatch glass with defrosters. Tint adhesive needs to be removed. Other wise good shape no cracks or chips. FREE
-416 Heads. Stock valves and springs. Painted oranged but paint is chipping. Casting # 14014416 $70
-New motors mounts. I got lazy and never put them on $25 for the pair
-350 block 4 bolt. Standard bore, stock stroke, stock dished pistons. This engine came out of a dualie truck. Has the four bolt mains and the internals are in great condition. price is for the bottom end only. If you want the 416 heads make me an offer on the combo. Just the bottom end of the block $250
-Flowmaster muffler with chrome tips. 2.5 inch in dual 3 inch tip out. Great condition $50
-Hedman S bend style header extensions. 2.25" New but have surface rust from sitting in garage. 20 for the pair
-$10 or FREE
I have a box full of stuff that is useless to me. All accesories.
2 x AC compressors ( one is for serpentine) everything below is non serp setup!
1 x Power steering pump
1 x Water pump
1 x Starter
Gaskets for exhaust manifolds or headers. and more gasktest for water pump etc.
Ill ship the smaller stuff but the bigger ones are pickup only. Im the NW burbs of Chicago. Once again everything is best offer and Ill go very low on these because they are taking up much needed space.
Old Jun 8, 2008 | 10:25 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Re: Parts for sale Chicago cheap!
How many miles on the block... is it put together... Im definetly interested. I just bought a "rebuilt shortblock with 0 miles" that had copper on the mains and wear on rod,main and cam bearings.. so Im returning this to its owner for a refund and Im looking for a complete shortblock. Did you make it to thirdgen fest? Get that rear crash bar on. thanks, Sean
Old Jun 8, 2008 | 10:40 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Yeah we made it to thirdgen fest only a few typical thirdgen hickups lol. Crash bar worked great, thanks! No idea how many miles are on it but the cylinder walls look good. they arent scratched up or anything. I pulled the oil pan and everything looked pretty clean. I dont think it was ever rebuilt. The block is in one peice. Let me know if you want some pictures.
Old Jun 8, 2008 | 11:24 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
yeah pics would be great if theres anyway for ya to pop off a cap or two to mak sure there in good condition I would greatly appreciate it. thanks
Old Jun 9, 2008 | 02:00 AM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
I will take the power steering pump if is not leaky.
BTW where in Chicago are you located?
Kevin
Old Jun 9, 2008 | 09:25 AM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Im in Des plaines. Right by maine west HS if you know the area. Never used the PS pump. If you want it you can take it for free since Im not sur eif it leaks or not. Looks pretty clean, like it didnt leak in the past though.
Old Jun 9, 2008 | 05:24 PM
bonesbrakr's Avatar
i can use a AC compressor for a serpentine system. It is going on a 89 firebird and will need to be shipped to NJ zip code 07508. The one i currently have has the bolt hole for the AC lines stripped and dont feel like heli coiling.
Bill
Old Jun 10, 2008 | 07:31 AM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Let me check if one of them are for serpentine setup. Ill post back. Thanks
Old Jun 10, 2008 | 07:28 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Updated info on the accesories. One AC comp is for serpentine evertyhing else is non serpentine. Pics available upon request
Old Jun 10, 2008 | 08:13 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
pm sent.
Old Jun 10, 2008 | 09:07 PM
bonesbrakr's Avatar
If the serpentine AC compressor is good how much shipped to NJ zip code 07508???
Old Jun 10, 2008 | 10:01 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
$30 shipped to nj
Old Jun 12, 2008 | 09:15 AM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
ttt
Old Jun 12, 2008 | 11:28 AM
specvgini's Avatar
Car: 1991 Formula
Engine: 5.7
i'm thinking about the heads you have. right now i have 74cc heads that suck, would the 305 heads work on my gen 1 block? would i gain some power with the 305 heads?
Old Jun 15, 2008 | 08:53 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Ive read on this site that if you put bigger valves on these heads and put them on a 350 they will have the smae flow #s at the vortecs. So yes they should be a noticable gain compared to the 74 cc's.
Also updated the orginal post with more parts
Old Jun 16, 2008 | 03:12 PM
defaria27's Avatar
Car: 1992 Camaro Z28
Axle/Gears: factory 373
the heads fit on my 350? are they 202? also the headers extentions..are them for the universal hooker headers?
Old Jun 16, 2008 | 10:09 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
I typed the wrong size for the extentions, cant edit the original post again I guess. Theya re for a 2.5 " collector on long tube headers. If your hookers have a 2.5 " collecotr and are long tubes they will work. The heads will fit on all Small block chevys. So yes on your 350. They are 416 heads
Old Jun 18, 2008 | 10:41 AM
defaria27's Avatar
are they in good condition.? are they better than 202?
Old Jun 19, 2008 | 09:30 AM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
I am not familiar with thw 202 heads. I know with the 416s after some work and bigger valve they flow as well as the vortechs. GIve me your email and Ill send pics
Old Jun 19, 2008 | 12:45 PM
firebird896's Avatar
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
are the heads and engine block a pair?
would u recomend a rebuild for the heck of it?
Old Jun 19, 2008 | 04:28 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
202 heads are just a gimmick that shady people do to make undesirable heads seem desirable by putting big valves in them.
Old Jun 20, 2008 | 12:50 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Right now the heades are off of the block so I was plannign on selling separate but if you need both i will definantly cut you a deal. Block looks pretty clean and the guy todl me it ran great when pulled. I pulled the pan and a main cap and it looked good also. If you got the cash then rebuild it otherwise I dont forsee a problem with just throwing it in.
Old Jun 20, 2008 | 07:12 PM
ReddyK's Avatar
Car: 86 Z28
I am interested in a v-belt AC compressor.
Are you around at all during the day?
Thanks,
Steve
Old Jun 21, 2008 | 09:14 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Sorry dude shipped the V belt AC comp last week
Old Jun 24, 2008 | 07:30 AM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
TTT , Still have all the big parts like heads, block hatch, etc
Old Jun 24, 2008 | 10:40 AM
87cmroiroc305ho's Avatar
Car: 1987 chevy camaro iroc-z28 305 h.o.
Engine: 305 high output
the header extenders?? are those for the heads i got, theyd be very very useful, lol, i shoulda asked about them
Old Jun 24, 2008 | 10:00 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Yes I bought the header extenders ofr using with those headers but swapped over to long tubes and bought another set (for the different collector size). However I am not sure how you can run them or set them up for shorty headers. Id check with some guys on the exhaust board first. Dont wanna sell you somethign you cant use.
Old Jun 25, 2008 | 12:44 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Everything left if going to go on ebay tonight(20 cent listing fees woo ). So if you still want an exclusive TGO deal let me know.
Old Jun 26, 2008 | 08:39 PM
Engine: 350/350/LS1
So how did the items go on eBay? I was interested in the block and heads but I wouldnt have the money to pay for em. Wat the link to the eBay, just so I could watch it
Old Jun 26, 2008 | 10:52 PM
jersyboyy's Avatar
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
Hey how many miles on the water pump and power steering pump. Ill take them 10 bucks plus shipping pm me with paypal info.
thanks,
jeremy
Old Jun 27, 2008 | 12:39 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Actually didnt get aroudn to putting them on ebay(got sidetracked). So you can just make me an offer I really just want to get rid of stuff now. Not sure how many miles on the power steering and water pump. Whats your zip? Ill get you a quote
Old Jun 27, 2008 | 01:11 PM
jersyboyy's Avatar
Car: 85 Camaro
08872
Old Jun 27, 2008 | 04:00 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Also the two pumps are NOT for a serpentine/V belt setup. Is this ok?
Old Jun 28, 2008 | 12:07 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
$35 shipped?
Sales pending on the block heads and extensions
Old Jul 2, 2008 | 12:36 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
TTT
Old Jul 9, 2008 | 09:31 AM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Hatch glass has been crushed(in the garbage truck) so that is no longer available. No more serpentine accesories either. Still have misc non serp. accs., heads, block, extention, gaskets, motor mounts.
italiano67
Dec 11, 2016 09:21 AM
fastrs1891
South Central Region
Oct 20, 2015 09:24 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
