SPOHN TH400 RETORFIT KIT
Car: 87gta 88gta 88marovert
I bought this new from SPOHN for a project car. No time any more to complete it so it's all up for grabs. This kit is for installing a TH400 transmission short tail only into a Third Generation F-Body. The kit includes the transmission crossmember required to install the TH400 transmission into any Third Generation F-Body. The crossmember is made of sturdy mild steel construction and utilizes the OEM sub-frame mounting holes to allow for an easy direct bolt-in installation. It coes with an NHRA approved driveshaft safety loop built onto the crossmember. Also coems with a crossmember mounted adjustable torque arm. These was bolted in to the car and has some scratches and scuffes. The car nevery came off the jack stands. OVER $400 BUCKS NEW PLUSE SHIPPING SAVE BIG MONEY MAKE AN OFFER MOST GO
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Transmission: Powerglide
Axle/Gears: 3.55
Re: SPOHN TH400 RETORFIT KIT
i need everything now how much for all of it. i know you said 400 new and it is used. do you have all the hardware or parts. im thinking arround 300.
does it come with the driveshaft too? were are you located?
who made the driveshaft. is it the spohn top gun the one for a ton of power. its goiing in a turbo camaro.
Last edited by mattsv8_03; Jun 25, 2008 at 04:35 PM. Reason: Automerged Doublepost
Car: 89 Camaro rs.
Axle/Gears: 3.55
ill do 300 as long as shipping will be to 43207 columbus oh isint too crazy.?
also im interested in the shaft. i have the moser 9" rear and need the top gun shaft. does it have the 3150 joints front and rear.
I would think the arm and member will have to be sent in tow boxes. I would think 35.00 will cover it. The drive shaft was made for the th400 short shaft trans and the moser 9" rear. I will have to check on the u joints I dont recall what I orderd right now.
Car: 89 Camaro rs.
Axle/Gears: 3.55
my car is a 89 camaro with the moser 9" rear and 35 spline axles. 1350 yoke.
id guess it would have to be the same as yours. id love to get the driveshaft unless your keeping. it ill have to buy one anyway. but i cant afford to do the shaft for about two weeks untill i get paid again. the tq arm and mount i can do
where do you want me to sent the money from paypal?
i have to borrow it from a friend untill friday. i dont get paid untill friday if you want me to just wait untill then. its from a bank card so the transfer is faster.
Last edited by mattsv8_03; Jun 25, 2008 at 05:28 PM. Reason: Automerged Doublepost
Car: 89 Camaro rs.
Axle/Gears: 3.55
i proably could put some donw on the shaft.
how much did you want for it?
Want a title? Post!
Car: Camaro Iroc-z 1986
Engine: 406 Small Block Chevy
Transmission: Th350
bro i am interested in the kit and also wana know if you wana sell the driveshaft with it give me ur number i can pick it up tomorrow i am around weschester area here is my email send me ur contact info dare2race@aol.com thanks
mattsv8_03
