Parting out 88 Formula
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
88 Firebird Formula with T-tops.
Body is in okay shape.
Has 4" cowl
4th Gen rear end. 3.42 Posi 28 spline axles. ($500- $250 if you bring another rear to put in it's place)
Complete WC T5 conversion. Aluminum slave cylinder etc. I have both style Flywheels. $600
350 roller block with aluminum heads. (no induction) $200 (you pull it)
Carb setup/ Edelbrock performer RPM, edelbrock 1405 carb, new electric fuel pump and FPR, New air cleaner with top flow filter etc. comes with vac distributor. All for $400
3 sets of centerbolt L98 heads. $50 a pair.
Fiberglass spoiler $50
Set of 16" formula rims with kuhmo tires. $250
V belt setup $100 (comes with aluminum alternator brackets TPI alt, and all others)
Drive shaft steel $25
T-Top bag $25
Anything else you need. Call
Cale
Here are some parts I need if you want to make trades:
700 r4 Aftermarket shifter.
52mm TB for TPI
Upper plenum
Panhard bar
Aftermarket torque arm
Roller rockers
Smog delete pulley
Air foil
251-209-1518
Wil sell entire car as is after I removed the exhaust, and interior for $1000 OBO.
Has 4" cowl
T-Top bag $25
Cale
52mm TB for TPI
Upper plenum
Panhard bar
Roller rockers
Smog delete pulley
Air foil
251-209-1518
Car: 89 Trans-Am
Engine: 5.7 TPI
Re: Parting out 88 Formula
Do you have the Spark control moduel for 350 mounted on firewall? GM 16128261 or will have hkr882401 on it.
Car: 1989 GTA
Engine: 5.7 l98
Transmission: T5, b&m short throw shifter
Axle/Gears: 3.27 borg warner
this is the only pic i could find, if you take apic of the connector part that would help!
Car: 1970 Nova
Engine: 850HP 383
Transmission: TH400 w/ Brake
Axle/Gears: 4.88 12 Bolt
Any pics of the hood by chance? Bolt on/pin on? And who its made by.Thanx in advance
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
hey cale, do you by chance have an msd 6al layin around? i'm in need...
Car: GTA
Engine: 383 HSR
I do but I have it wired in my current setup. Ever thought about using that new digital box from summit
Engine: 7.0L
yeah, actually, i have...
but it didn't work all that well, so i took it back. digital boxes have a bad rap as far as being unreliable...so i'm wanting to use an analog box. the one i'm thinking about now is the new msd box, which is a 6AL-2.
Car: GTA
Engine: 383 HSR
I cannot believe you of all people would take out a CD player. If I recall you are quite fond of music.
Car: 89 RS
Engine: stock TBI 305 atm
OMG, I wish you weren't so damn far away... I'd have the motor out and loaded in my truck in under an hour!
Car: GTA
Engine: 383 HSR
Here is an update: since I am not able to edit the original post.
Has 4" cowl $75 No shipping
4th Gen rear end. 3.42 Posi 28 spline axles. ($500- $300 if you bring another rear to put in it's place)
Complete WC T5 conversion. Aluminum slave cylinder etc. I have both style Flywheels. : SOLD
Carb setup/ Edelbrock performer RPM, edelbrock 1405 carb, new electric fuel pump and FPR, New air cleaner with top flow filter etc. comes with vac distributor. All for : SOLD
Fiberglass spoiler $50 plus Shipping
Set of 16" formula rims with kuhmo tires. $200 (Price lowered)
T-Top bag : Sold
NIB Aluminum Slave cylinder: $75 Shipped
NIB Clutch master cylinder $45 Shipped
Radiator V8 $25 plus shipping
L98 Valve covers $40 Shipped
4th Gen LS1 console for 5 speed. (pretty beat up) $25 plus shipping
T-tops $25 a piece plus shipping
Dual electric fans. $75 shipped.
11" LS1 rear brakes $350 Shipped.
Front bumper : SOLD
Let me know if I can help.
Cale 251-209-1518
T-Top bag : Sold
Front bumper : SOLD
Cale 251-209-1518
Engine: 7.0L
i need to talk with you about getting a clutch master/slave/braided line combo setup at some point in the not so distant future...i'm doing a t5 swap in my 84 'bird.
Car: GTA
Engine: 383 HSR
Not a problem. So happens I have one aluminum slave and one new MC sitting in my New parts shelves.
interested in the dual fans. if you still have them and have all the parts for it to fit on a car the mounting hardware then i ll take em
and do you have any pics of the vbelt set up whats all there
Car: GTA
Engine: 383 HSR
I have no current pics for the vbelt stuff. It is very basic. everything you would get from a basic carbed motor.
Alternator bracket, PS, AC, et cetera.
Let me know what you need.
-Cale
LT1Formula
20
Nov 14, 2015 12:02 AM
