Cyberdyne Oil and Water Gauges
Car: 92RS
Engine: LQ4
Transmission: 4L80E
As the title states. Red Heat display. Gauges come with senders. Used for about 3 months. Located in Plymouth Township PA.
$30 for the oil pressure
$20 for water temp
$45 for both
$20 for water temp
$45 for both
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: Cyberdyne Oil and Water Gauges
Are these just plug and play? Or us there some sort of other thing need to make them work?
Thanks.
Thanks.
Car: 92RS
Engine: LQ4
Transmission: 4L80E
The oil pressure and temp. senders will need to be replaced with the Cyberdyne senders. Also you will need to supply 12v to the gauges, along with a pod to hold them.
Car: 92RS
Engine: LQ4
Transmission: 4L80E
That is correct. I have the temp and oil pressure senders for the gauges.
Here is a pic of the gauges in action:
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
