[IN] Parting out 91 Z28 L-98 AFR heads T-5 HSR
I am parting out the drivetrain of my 91 Z28. I have a lot of aftermarket parts, as well as some extra things laying around in the garage. I will probably be posting more stuff over the next few days. Basically everything off of the car has under 5K miles on it. e-mail or pm me with any offers. My e-mail is biganswer7@hotmail.com
$1200.00 L-98 with factory TPI setup, adjustable fuel press reg, accel 24lb inj, LT4 cam, bored .030. 12k on rebuild
SOLD $1000.00 AFR Eliminator 195cc heads
SOLD $400.00 Holley Stealth Ram intake w/fuel rail/adj fuel press reg, incl. Russel braided fuel lines/converter fittings
$225.00 BBK twin 58mm throttle body
$1200.00 World Class T-5 with everything to convert (clutch pedal assy, Centerforce 2 clutch/press plate, new Daiken flywheel, new 5-spd starter, slave cyl)
$150.00 Pro 5.0 Shifter w/hammerhead shiftknob
$100.00 Hedman headers w/y-pipe for single cat
$250.00 Flowmaster 2.5" cat-back system
$1000.00 327 shortblock balanced with Eagle H-beam rods and bored .040 over w hyperutectic pistons
$200.00 882 casting heads w screw in studs/guide plates
$75.00 Performer RPM SB manifold
$1000.00 18" Chrome Iroc's w/like-new ripken raptor tires
$400.00 Tokico Illumina 5-way adjustable shocks/struts
$175.00 Eibach Sportline springs
Added 2/16
$200.00 Comp Cams Pro Magnum 1.6 Roller Rockers
$175.00 Comp Cams Hyd Roller Lifters
$75.00 Comp Cams 1-piece Heat treated pushrods
Added 2/16
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Re: Parting out 91 Z28 L-98 AFR heads T-5 HSR
Where in indiana?
How much for the complete dash w/ HVAC & Interior harness? Dont need dash pad
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Im interested in the HSR, where in Indy are you, Im in Chicago so if not to far I could check it out in person. thanks
Car: 1991 Formula Firebird
Engine: L98 with headers/exhaust
Axle/Gears: 3.23 10-bolt
No one has made any offers on anything yet. I have lots of stuff to sell. Whatever is'nt gone by the end of the month will be put on auction
Car: 1987 Monte Carlo SS
Engine: Vortec headed 350
Transmission: '89 WC T5
Is this a bolt in deal for a stock system? (87 Iroc) Is there a spot for an O2 sensor?
Do you have any pics?
If there is any response to this, I will then provide my email address via PM
Car: 90 chevy camaro convertible iroc
Engine: 305 tpi
Transmission: 700r4 with hurst dual gate shifter
how much would shipping be for all this to21740 and also can you send me pics to rsconv92@yahoo.com
The headers/y-pipe are a bolt up to stock setup, and they do have the o2 bung. There are no emissions tubes however. I will try to get some pictures sent to everyone interested.
The AFR's are 64cc chambers, and are complete with valves/springs. They do not come with rockers, however I do have a set of Comp Pro-Mag 1.6 rollers that I was running with them that I will be getting rid of too.
I have had several questions on shipping for the exhaust system, and it looks like it is going to be around the $150.00 range. On anything that sells, if I over quote for shipping, I will refund the difference, and if it is more than I quote, I will cover the diff.
Car: 85-Vette
Engine: 406ci
Transmission: TKO-600
Axle/Gears: 3:45
They are the new AFR Eliminators comp version?
What lift are the springs good for?
What size studs 3/8 or 7/16" ?
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
I still have not removed the exhaust system from the car. I will e-mail pictures to everyone interested as soon as I do. Sorry for the delay.
Car: 89 IROC-Z
Thanks! Be sure to grab some pics of that shifter too, id gladly give you $250 for what i posted above.
Edit, what kind of hammerhead **** does it have on it? Does it say B&M on the top? Thanks
Engine: 305 tpi
free bump waiting on pics of the headers also
Car: 89 IROC-Z
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
Will you sell the clutch & PP . How much and miles on it . 10512
Engine: 305 tpi
Car: 87 GTA
Engine: 385 sbc
