[VA] 84 Berlinetta Cluster/V-8, speedo and tach
Old Jul 17, 2009 | 04:58 PM
unclejoe's Avatar
Car: 84 berlinetta
Engine: 305 v8
Transmission: auto
I have an 84 chevy berlinetta camaro... it has the electronic cluster, and the speedo and tach are dead... It has the v8 in it, but i can only find a v6 cluster... does anyone have a v8 cluster, know where i can get one, or know if the v6 cluster will work in it? thx
Old Jul 17, 2009 | 05:27 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 84 Berlinetta Cluster/V-8, speedo and tach
Welcome to TGO. PM John in RI (He's the Berly man).
JamesC
Old Jul 17, 2009 | 05:51 PM
dave mc's Avatar
Car: 87gta 88gta 88marovert
I have one from a 84 V8 car
Old Jul 17, 2009 | 07:38 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
THANX James !
Everything on the V6 Cluster will work in your V8 car, with one exception,..... The Tachometer will not show the correct RPM reading. If you want the tach to be correct than you MUST use the correct replacement cluster. If your car is a V8 than you must use a V8 dash cluster. If your car is a V6 than you need to use a V6 dash cluster. ( V8 clusters show a 4400 RPM 'Yellow line' on the "bar graph" Digital Tachometer. )
The odometer reading can be corrected to match your cars actual mileage too, but care must be taken when playing around inside the cluster. I've got replacement clusters too......... Send me a PM if you need any other info !
Old Aug 13, 2009 | 09:08 PM
John in RI's Avatar
Package Shipped !
$750 L98
Feb 1, 2025 02:25 PM
Lbibb
May 5, 2016 12:00 AM
Linson
Oct 1, 2015 09:50 PM
rusty vango
Sep 29, 2015 02:44 PM
Eric-86sc
Sep 28, 2015 11:37 AM
