[CT] Need HVAC for 87 Iroc
Old Oct 10, 2009 | 02:59 PM
chevelle600's Avatar
Car: '87 IROC-Z/28
Engine: 357 HSR
Axle/Gears: 3:73 w/Eaton Posi
Hello all, i need the HVAC setup for a NON AC car because mine broke in a few spots. this is all for an 87 Iroc z by the way, so it does have vacuum controls
so i need:
Controls for dash
HVAC box under the dash ( i need all of the vents to work too, hot and cold)
and the cable to select between hot and cold.
i can use my exsisting wiring though (i have ac, but i deleted it). i dont need the heater core. and i guess i can reuse all of the ducting. so if anyone can help me out, that would be great.
pm me if you have anything i can use please! and ill try to get back asap
Old Oct 12, 2009 | 11:41 AM
irocgta's Avatar
Car: Iroc Z /Trans Am / Corvette
Axle/Gears: 273/308/323
Re: Need HVAC for 87 Iroc
I have the box which locates under your dash also have outer section with evap, i'll include these parts together for a $150 and for an additional $50 I have selector control , add $50 for shipping and I will send you pretty much all that you need to setup aside from compressor and compressor lines.
Old Oct 13, 2009 | 09:53 AM
Car: '87 IROC-Z/28
Engine: 357 HSR
i NEED the NON AC parts. i have the ac stuff already and i want to get rid of it.
if i cant get anything for non ac stuff, then i may take the under dash box off your hands cuz thats the part i need the most.
Old Oct 13, 2009 | 04:42 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Let's set yopu on the right path here: You HAVE AC originally installed in a 86 IROC. You WANT to install NON-AC parts. Your Options are:
Install a replacement AC heater control.
OR
Install a 82-89v Non-AC heater core box, & install 82-89 NON-AC heater control.
OR
Install a NON-AC control from a 90-92 Camaro. ( Yes - the Yellow letter version )
You could than use the original dash housing and retain the extra air vents, or you could install an 82-89 non-AC dash housing and loose the extra vents. You could install a AC or a Non- AC heater box inside the engine bay doesn't matter. You could also decide to install the additional " forced Air" vent system from the 82-89 set-up or not.
You CAN NOT install an 82-89 NON AC Heater control to a AC heater core box. 82-89 NON AC controls are cable operated and 82-89 AC systems are vacuum. ( They are Not companable.) In the 90-92 cars the heater control is vacuum operated for both the AC and NON-AC systems.
I've got just about any combination of this stuff avaiable for sale. Re-read thru this message carefully and re-post here if you need more info.
Old Oct 13, 2009 | 09:42 PM
irocgta's Avatar
Sorry mis read your post, however if you're still interested in any stuff let me know make offer, whatever thanks..........
Old Oct 14, 2009 | 04:26 PM
Car: '87 IROC-Z/28
Engine: 357 HSR
thanks for all of the info John!
well i guess im going to take the easier route and just find another AC heater core box to replace mine.
so i guess its up to whoever can give me a better deal
thanks everyone!
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Casey Meyers
Mar 2, 2016 10:46 AM
777Shock777
Oct 29, 2015 04:30 PM
Winchester1094
Interior Parts Wanted
Aug 19, 2015 05:01 PM
mustangman65_79
Aug 11, 2015 03:17 PM
