9 Bolt Machined Posi Cones... $45 shipped
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I have a set of Machined Posi cones for a 9 bolt. I was going to use these, but don't have the time and I need the money.
I machined off .25 inch off the outer lip, then I machined the inner surfaces till the grooves were gone. These should work great.
Edit: I am asking $25 shipped to the 50 states.
Car: 89 Iroc Z-28
Engine: 5.7 350 TPI.
Axle/Gears: Borg Warner 9bolt 2.77
Re: 9 Bolt Machined Posi Cones... $60
since you machined them im taking it that you are going to have to use shims now?
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
That is correct. In order to rebuild a 9 bolt, you are going to have to shim it either way. I have quite a few shims ill throw in. I remember finding shims for like $30 or so...
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
very interesting, how much life do you think those cones will have?
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Depends on alot of things... How bad your carrier is worn, how often you burnout in the rain (9 bolt killer) and how well you shim everything.
Car: 89 Iroc Z-28
yea i found out the hard way how to kill a 9bolt posi cones in the rain, how much for everything shipped to freeland michigan 48623
I'll take them if you have paypal and are willing to ship international. Of course I understand 45 shipped is a no go w/ int. shipping so how about 40 + actual shipping?
Car: 85 trans am
Engine: 383 stroker
Transmission: 5 speed
Axle/Gears: 9 bolt rear 3:70
i this all the cones needed to rebuild? if so i am very interested. price shipped to 19702 thanx
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
You may need some shims... Ill give you all the shims I have which should be enough.. not positive though.
$45 shipped.
I mean I spent alot for a full set of shims, and I got the cones... I just don't need these, and want them to go to good use.
$45 shipped.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
The cones haven't been used since I machined them.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Bump... Make an offer. I guess nobody is rebuilding their 9 bolts..
Car: 1966 El Camino Custom
Transmission: 200R4
Does it matter which series of carrier is being used? Will this work with all series?
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I am pretty sure it works with both 2 and 3 series carriers.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
TTT... These are just taking up space... I will include all the shims I have to help you rebuild your 9 bolt posi.
Car: 87 T/A
Engine: TPI 350 ci
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
My Paypal is XXX . They are boxed and ready to go.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
knight72
Aug 10, 2015 09:32 PM
