Parting out :1991 Z-28 (updated list)
I parted out a 91 Z-28 a few months back. still have some parts left. here is what I have:
1) Posi 10 bolt rear. drum brakes . comes w/ panhard bar and sway bar. 2.73 posi Gears in good shape $175 B/O
(2) 26 spline axles $30pr.
3) gas door assembly $15
4) 3rd brake light assembly $10
5) black dash panel (goes under sterring column)( has a small chip) $15
6) (2) electirc fans $30pr.
7) console w/ good console lid $60
8) stereo bezel $15
9) heater control unit $20
10) high rise rear spoiler $150
11) Brand new TRW coil springs $40pr (still in the box)
12) gray interior plastics, seat belts and black pillar panels, black T-top panels Prices vary from $10 -40
13) gauge cluster bezel $15
14) front sway bar $40
15) wonder bar $25
16) Flotech muffler w/ pass side tailpipe $25
17) Stock 2.25 Y-pipe w/ new catalytic converter $50
18) Brand new stock aluminum radiator w/ plastic tanks $80 ( Used only in my Monte Carlo in order to start it up no miles on it)
19) hood hinges $10pr
20) hatch weatherstripping $20
21) 700R4 steel driveshaft $30
22) Reman Napa windshield wiper motor $20
23) e-brake handle w/ cable $20
24) rear seat $25
25) driver side ground efx $30
26) rear driver side ground efx $15
Located in Hatboro,Pa
8) stereo bezel $15
15) wonder bar $25
24) rear seat $25
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
Re: Parting out :1991 Z-28 (updated list)
Possibly interested in this stuff.
What color is the seat?
What shape are the ground effects? Do they have all the hard ware?
Are they the factory dual fans?
The seat is a gray tweed. I think I have pics of it. I'll look. the dual fans are factory and the ground efx are in good shape. however one of them is missing a few mounting tabs. The other I believe has all the mounting tabs. Pm me if interested you are not far from me,depending on where in Philly you are. Hood hinges I still have them too.
Car: 1986 Camaro SC
Engine: None
Transmission: None
Okay, I definetely need the hood hinges and most likely the factory dual fans. Do they have the upper and lower mounting brackets. Not sure about the other stuff yet. I am in Upper Darby area, right off I-476.
Engine: Cammed 6.0L LSX
Do you have the mounting bolts for the wonder bar? And does the price include shipping?
1992 Trans Am
May 10, 2023 07:19 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
